bad cylinder
Old February 2nd 06, 03:04 PM posted to rec.aviation.owning
Default bad cylinder
Instead, just add this to your website list:
www.acronymfinder.com
Cheers,
John Clonts
Temple, Texas
N7NZ
Old February 2nd 06, 04:22 PM posted to rec.aviation.owning
And ECI currently forced to replace thousands of cylinders doesn't mean
a thing, eh... Interesting...
denny
Old February 2nd 06, 04:33 PM posted to rec.aviation.owning
Lycoming had an AD on cylinders in 1976 and that AD has since been
canceled...In fact, the only current AD's regarding cylinders for
Lycomings that I can find on a quick search are against ECI and
Superior...
I don't have an axe to grind here... I'm interested in facts...
denny
Old February 2nd 06, 04:50 PM posted to rec.aviation.owning
"Denny" wrote in message
ps.com...
Superior...
denny
Not sure who you are talking to as you have not seen fit to include anything
other than your response. Lycoming has had numerous ADs on crank shafts
(the numbers are still growing). Continental cylinders have been junk for
decades. There was (and still is) an AD on some Continental cylinders that
requires retarding timing to reduce power to prevent cylinder cracking.
They kept promising the problems were fixed but each generation was as bad
as the last. The reason ECI and Superior came to be is in part due to what
Lycoming and Continental were producing. The ADs against ECI and Superior
are insignificant compared to some of the Lycoming ADs. ADs don't tell the
whole story, in fact as far as long term reliability is concerned they tell
you almost nothing. Only when a problem becomes a safety factor does it
have a chance to become an AD. Cylinders wearing out in a couple hundred
hours will most likely not generate an AD.
Old February 2nd 06, 04:59 PM posted to rec.aviation.owning
Cylinders in Lycoming engines usually last quite a long time. My
rebuilder says that he almost never sees a failed Lycoming cylinder
from a 320, 360 or 540. This is true regardless of the brand of
cylinder. I have had excellent results from Lycoming branded cylinders.
Unfortunately, ECI just had a bad mandatory replacement (not covered by
their warranty) on their Lycoming engine cylinders (ouch!).
If it were me, I'd use the same cylinder that the engine has on its
other cylinders. Nothing wrong with Lycoming cylinders. Some of the
coated cylinders are better if you live where its wet and dont fly
often as they are less suceptable to corrosion. I don't think its a
huge issue. Any of the new cylinders are going to be pretty good.
Old February 2nd 06, 05:15 PM posted to rec.aviation.owning
Hm...too many duplicates of the same abbreviation, e.g. ATM.
Doesn't look like there's any editorial review.
But useful just the same...thanks
Bad cylinder Denny Owning 17 September 12th 05 06:04 PM
Unusual ECI Cylinder [email protected] Home Built 4 July 7th 05 01:27 AM
Path of an airplane in a 1G roll Chris W Piloting 47 July 4th 05 10:53 PM
Path of an airplane in a 1G roll Chris W Aerobatics 20 June 29th 05 09:35 AM
Path of an airplane in a 1G roll Chris W Home Built 22 June 29th 05 09:35 AM
