Flew into Nashua last Sunday for business, topped off the tanks right
after setting down. When I came back from business on Thursday, found the right tank down quite a bit. I was going crazy looking for the leak and checking the drain for seepage, until the line guy pointed out that he filled the tank back up exactly 5 gallons--which happens to be the volume of a standard gas can. He said he'd seen it happen to another plane on the line, both tanks down 5 gallons. It was parked pretty much in front of the tower, but it is a low wing parked in a line of high wings so I guess it made the easiest siphon target. I've never given any consideration to gas theft but I think in the future I will top off right before taking off, as at least thirsty tanks will make a less attractive target! Hank Rausch N9906T |
"Hank Rausch" wrote:
Flew into Nashua last Sunday for business, topped off the tanks right after setting down. When I came back from business on Thursday, found the right tank down quite a bit. I was going crazy looking for the leak and checking the drain for seepage, until the line guy pointed out that he filled the tank back up exactly 5 gallons--which happens to be the volume of a standard gas can. He said he'd seen it happen to another plane on the line, both tanks down 5 gallons. It was parked pretty much in front of the tower, but it is a low wing parked in a line of high wings so I guess it made the easiest siphon target. I've never given any consideration to gas theft but I think in the future I will top off right before taking off, as at least thirsty tanks will make a less attractive target! That has happened here in AZ, too. Acquaintance with a 421 was down *20* gallons. It's a gaited airport, but it was at a tie-down near the self-serve fuel station -- maybe somebody just got confused (har!). Imagine seeing a twin, or any other airplane, and just helping yourself. Unbelievable. |
I would ten times over risk gas theft over water condensation overnight in
half-full or nearly empty tanks. Jim "Hank Rausch" wrote in message oups.com... I've never given any consideration to gas theft but I think in the future I will top off right before taking off, as at least thirsty tanks will make a less attractive target! |
half-full or nearly empty tanks. I have a Mooney so filling the tanks is a rare event (7 hours of gas is way more than I need and I don't like pulling a yaht around with a Corvette). I generally keep only about 10 gallons per side when parked. I park outside and have yet to see any water in the 6 years I've had the plane. Maybe the fact that a Mooney technically doesn't have fuel "tanks" makes it different. -Robert |
"RST Engineering" wrote: I would ten times over risk gas theft over water condensation overnight in half-full or nearly empty tanks. There's not enough water in 20 gallons of air to matter. How much water is there? In *extremely* wet conditions (saturated air at 20 deg. C) there are only 14.7 g/kg of water in the air. A cubic foot of air at SLP weighs about 34 grams at 20 C. 10 gallons is ~27 cu. ft., so that gives about 900 g. of air and about 14 g. of water. Not a problem. -- Dan C172RG at BFM |
20 gallons is ~27 cu.
"Hank Rausch" wrote in message I've never given any consideration to gas theft After 102 years of powered flight, you'd think locking gas caps would be available. |
"RST Engineering" wrote: I would ten times over risk gas theft over water condensation overnight in half-full or nearly empty tanks. But, if you fill it up, and they siphon it out, don't you still have the same problem? |
After 102 years of powered flight, you'd think locking gas caps would be available. If you hook up a tube to the fuel drain and the vent is working properly, a locking cap won't make a difference. |
half-full or nearly empty tanks. But, if you fill it up, and they siphon it out, don't you still have the same problem? First thing that came to my mind as well when I read that. The Monk |
| Theft among friends | bumper | Soaring | 8 | July 29th 05 06:51 PM |
| Theft From Baggage-Continental | [email protected] | Piloting | 73 | April 2nd 05 09:17 AM |
| A-10s at Nashua, NH (ASH) today? | William W. Plummer | General Aviation | 0 | May 15th 04 05:03 PM |
| Good News! Arrest in plane theft case | Jamie Rogers | Piloting | 10 | November 8th 03 07:43 AM |
| Nashua Festival, Avidyne and WSI | Doug Vetter | Owning | 9 | September 24th 03 03:45 AM |
