#71
![]() Jesse needs to learn how to capitalize, punctuate, and separate his sentences into paragraphs in order to make his posts readable. \ Yep. That would be a very good start. There is more to it than that, though. -- Jim in NC |
#72
cjcampbell wrote:
Saw this question on "The Straight Dope" and I thought it was amusing. http://www.straightdope.com/columns/060203.html The question goes like this: "An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" (Assuming the tires hold out, of course.) Cecil Adams (world's smartest human being) says that it will take off normally. Assuming the increased tire friction doesn't cause a problem the aircraft should take off but have twice the normal tire rotation speed when becoming airborne. That's because the thrust is produced by the prop and it will accellerate the aircraft into the relative wind. The conveyer belt is just an entry to confuse the issue. For a car the situation would be completely different since it produces forward motion by the tires which contact the moving conveyer belt. The car wouldn't move at all. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - |
#73
The answer is an obvious YES. I don't know how this thread got as big
as it did :^) The Monk |
#74
"Darrell S" wrote in message
news:rT6Ff.24873$jR.14387@fed1read01... [...] For a car the situation would be completely different since it produces forward motion by the tires which contact the moving conveyer belt. The car wouldn't move at all. It might. As "Doug" points out, the presentation is ambiguous as to the reference point for the speed of the vehicle. If one uses the ground (and stationary portions of the treadmill) as a reference, then the car would move, just as the airplane does (it would have to in order to comply with the description given in the problem), and the car's speedometer would register a speed twice its actual speed relative to that reference. Pete |
#75
Robert M. Gary wrote:
Only if there is an 80 mph tailwind. If the plane is rolling 80mph against a conveyor going 80mph back the difference would be zero. BUT-what is the total friction force from the wheels? Certainly it's less than the thrust from the engine--I mean, that's what wheels are designed for, to have as little rolling friction as possible. So let's add this up... forces acting on airplane are thrust, aerodynamic drag, and an essentially negligible amount of drag from the wheels. Add it up, and since the thrust is greater than the drag (as it would be on a normal takeoff) the airplane accelerates. As I said in another post, since wheels are designed for minimal friction, just pretend that they are frictionless, and therefore not even there (anti-gravity airplane). What is the conveyor belt going to push against now? |
#76
Why dont we look at it from another direction !!!
If the treadmill is moving at 60 MPH in one direction and the trust is set to pull 60 MPH in the oppisite direction, the plane would be neither moving forward or back. so the only thing that is moving is the wheels, the wings are not generatring any lift becuase they are not moving in a positive direction, the wings dont know that the wheels are going like a bat out of hell !!! the wings still things its standing still. you WILL NEED TO HAVE FORWARD MOMENTIUM to generate lift..... the only lift the wings will get is downwash from the prop. and i used the word STUPID not to offend anyone, but i am right in what i said about the aircraft. but its really fun to talk about this after over 75 messages posted... ![]() |
#77
Because it is interesting, and evokes thought.
"Flyingmonk" wrote in message oups.com... The answer is an obvious YES. I don't know how this thread got as big as it did :^) The Monk |
#78
"cjcampbell" wrote:
"An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" One critical detail is missing that makes in impossible to say "yes" or "no": Is the forward speed of the plane above the stall speed? The plane could, after all, being moving forward at 10 mph. Nothing in the problem statement above precludes that speed, or any other. HOWEVER, the question on the web site asks "_Can_ the airplane take off?" The answer to that one is, using the most common meaning of the word "can," essentially "yes". What a difference substitution of one word makes! ;-) |
#79
![]() "Flyingmonk" wrote in message oups.com... The answer is an obvious YES. I don't know how this thread got as big as it did :^) Obviously, the answer is not so obvious! What surprises me is that there are more than TWO opinions!!! :-) You would think that the airplane would either take off or it wouldn't!?! Anyway, reading/participating in this thread is much more interesting than reading the usual flames in various newsgroups. It's surprising and refreshing that this thread, with so many posts, hasn't (yet) degraded into a flame-fest. ![]() The Monk |
#80
![]() "The Flying Scotsman" wrote so the only thing that is moving is the wheels, the wings are not generatring any lift becuase they are not moving in a positive direction, the wings dont know that the wheels are going like a bat out of hell !!! the wings still things its standing still. you WILL NEED TO HAVE FORWARD MOMENTIUM to generate lift..... Man, you are about as dumb as a fence post, or bag of rocks, or.......PLONK -- Jim in NC |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
