#141
"Gary Drescher" wrote:
"Don Tuite" wrote in message .. . but what is the point of the original question in that case? Is it just to trap a sloppy reader into thinking it's all about a crackpot VTOL methodology? I think the more interesting point is to notice the implications of not transmitting force through the wheels. Even people who know that planes and cars differ in that way may fail (at least at first) to draw the appropriate conclusion about what happens to the treadmill plane when it applies takeoff power. Totally irrelevant. The answer is the same for a glider being towed to take-off by a ground vehicle (except that you would want to change the rear end or wheel size of the vehicle to cut the final drive ratio in half, so that it could attain the doubled wheel speed necessary to attain the needed forward speed.) --Gary -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#142
The mistake is in not realizing that the air that the propeller acts upon is
unchanged regardless of the speed of the conveyor belt. Therefore, the propeller will be able to pull the airframe forward on the conveyor regardless of how fast the conveyor moves, because it is putting a force on the airframe relative to the air, not relative to the conveyor belt. The same thing would happen if you attached a rope to the nose of the airplane and stood on the ground ahead of the conveyor so that you were not standing on the moving belt. Start the conveyor and the airplane stands still while the wheels spin with the conveyor belt. Now pull on the rope and you can move the airplane forward even though the conveyor is moving backwards and the wheels are spinning like crazy. The mistake I made in comparing it to a seaplane on a river is that the floats are attached to the airframe - where they go, the plane goes. No so with wheels. Wheel rotational speed has nothing to do with how fast the airframe moves in this scenario. BDS |
#143
![]() "Helen Woods" wrote in message ... Nice article explaining this: http://www.avweb.com/news/columns/191034-1.html C'mon Helen! .....How can reading that article in 5 minutes possibly be as much fun as arguing about the problem in a public forum over the course of 2 days??? ....Huh?!? Omigod! ....What's happened to me!?! :~( |
#144
"alexy" wrote in message
... "Gary Drescher" wrote: I think the more interesting point is to notice the implications of not transmitting force through the wheels. Even people who know that planes and cars differ in that way may fail (at least at first) to draw the appropriate conclusion about what happens to the treadmill plane when it applies takeoff power. Totally irrelevant. The answer is the same for a glider being towed to take-off by a ground vehicle (except that you would want to change the rear end or wheel size of the vehicle to cut the final drive ratio in half, so that it could attain the doubled wheel speed necessary to attain the needed forward speed.) I don't think we're in disagreement. My point is just that (even assuming frictionless wheels) you have to make some changes (such as the ones you proposed) to a typical ground vehicle to imagine it running normally at twice its usual speed (even if the relative wind is merely at the usual speed). The airplane, in contrast, just takes off normally from the treadmill without needing to be modified. --Gary |
#145
AES wrote:
If you tie a 100 foot rope to the tail of an airplane (or some other part of the airframe), attach it to a good strong post, and run the propellor up to whatever rpm is available, is anyone claiming the airplane can then lift up say a feet off the ground? (Assuming the tail doesn't tear off) (and, a conveyor belt under the airplane is optional) That completely changes the situation. The plane couldn't take off with a regular runway if you secured it to a fixed post. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - |
#146
("Michael Ware" wrote)
You are taking the statement 'a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward' to mean that somehow there is a force being applied to the mass of the aircraft, equal and opposite the thrust generated by the propellor. The only place the treadmill can exert any force an the airplane is the only place the treadmill is touching the airplane: the wheels. Any motion of the treadmill belt will be translated into rotation of the wheels. This will not prevent the aircraft from moving forward, through the air and taking off. THE AIRPLANE WILL NOT MOVE. (That's my vote) The rotating wheels + gravity (Thank you Sir Isaac!) ANCHOR the plane to the treadmill. Plane/prop move forward, treadmill/wheels fall back. The plane is attached to the wheels. Try it in front of you with a ruler and a magic marker. That airplane is doing 150 mph down that runway, only the runway is really a treadmill which is matching that speed. End result is = to an Olympic sprinter on the same treadmill - I can stand next to him for his entire 10 second (27 mph) race. Montblack 83.7 (I thought some of double-digit people needed to be heard from. g) |
#147
"cjcampbell" wrote:
"An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" (Assuming the tires hold out, of course.) Now, there are two references to motion in the problem, and the correct (IMHO) solution is based on both of those motions being from a consistent frame of reference, i.e., relative to the ground. The incorrect (IMHO) solution seems to depend on reading these two motions as related to inconsistent frames of reference, to wit: "An airplane on a runway sits on a conveyer belt that moves relative to the surface of the earth in the opposite direction at exactly the speed that the airplane is moving relative to the surface of the conveyer [Not sure how those who read it this way fit the word "forward" into their interpretation.] This reading leads to the conclusion that the plane is standing still, but flies in the face of what really would happen if such a device were built, given how a plane's propulsion is provided -- i.e., this reading of the problem assumes facts inconsistent with what conceivably could happen were such a device built. (BTW, many seem to focus on this practical aspect of propulsion, but that misses the pure logic of the thought experiment, it seems to me.) But think about the opposite inconsistent reading of the statement: "An airplane on a runway sits on a conveyer belt that moves, relative to the airplane, in the opposite direction at exactly the speed that the airplane is moving forward relative to the ground." That inconsistent frame of reference seems just as justifiable as the other, and is in fact MUCH easier to imagine actually implementing! I think we should do something to make sure that all future airports are built with runways that work like this third interpretation of the stated problem! g -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#148
BDS, aren't you glad you used initials rather than your name?
"BDS" wrote Nevermind - I finally get it. DUH!! BDS |
#149
"Michael Ware" wrote: Are you saying 1) the rope is tight, or are you saying 2) you are giving the plane a 100' running start? "AES" wrote in message ... If you tie a 100 foot rope to the tail of an airplane (or some other part of the airframe), attach it to a good strong post, and run the propellor up to whatever rpm is available, is anyone claiming the airplane can then lift up say a feet off the ground? (Assuming the tail doesn't tear off) (and, a conveyor belt under the airplane is optional) Didn't think of that -- and maybe your response is tongue in cheek -- but I had in mind "rope is tight". |
#150
"Flyingmonk" wrote in message
oups.com... Already rephrased my statement. Sorry, I missed that. Even having been told it exists, I still can't find the post with the rephrasing, but I'll assume it essentially retracts the claim that an airplane can fly from prop wash alone. |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
