#151
It's one of those strange Usenet phenomena.
How do start a big argument on Usenet? Ask a simple question. |
#152
![]() "Brien K. Meehan" wrote in message oups.com... It's one of those strange Usenet phenomena. How do start a big argument on Usenet? Ask a simple question. It would be fun to see this worked out on 'Mythbusters'. Mike |
#153
If the belt were moving backwards at the speed of the aircraft when it
touched down, it would be similar to landing with that much tailwind, basically, your ground speed would double you airspeed at touch down. Oops, my bad. I meant apparent (to the conveyor) groundspeed. Jester |
#154
![]() cjcampbell wrote: Saw this question on "The Straight Dope" and I thought it was amusing. http://www.straightdope.com/columns/060203.html The question goes like this: "An airplane on a runway sits on a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward. Does the airplane take off?" (Assuming the tires hold out, of course.) Cecil Adams (world's smartest human being) says that it will take off normally. I confess to having difficulty understanding the difference between a conveyer belt and a treadmill, although it seems important to some folks. Cecil does not seem to be arguing that prop wash or jet thrust are generating enough lift by providing downwash over the wings. He claims the airplane will take off normally -- that is, the airplane will move forward just as in a normal takeoff, developing airspeed as it goes. He also claims that this will not take any extra thrust. He likens the situation to someone on rollerblades on a treadmill who is holding onto a rope fixed to an object at the front of the treadmill. No matter how fast the treadmill is moving, it takes the same energy to pull yourself to the front of the treadmill as it would if the treadmill was stopped. The only difference is that the wheels would turn twice as fast. Cecil appears to be saying that the airplane cannot be prevented by the conveyer belt from moving forward, no matter how fast the conveyer belt moves, because the thrust is generated independently from the wheels. The airplane will accelerate and take off, using the same length of conveyer belt as it would an ordinary runway. The only difference is that the wheels will be spinning twice as fast at rotation as they would otherwise, thus the caveat "assuming the wheels hold out." I am not sure I understand why Cecil thinks this. If I understand him correctly, the drag of the treadmill against the wheels does not increase just because the treadmill is moving. Okay, I guess I can believe that. Still, it seems counterintuitive to me that if a plane is sitting on a conveyer that is moving backwards at exactly the same speed (I assume they mean groundspeed here) as the airplane is moving forward that the airplane will move forward at the same speed as if it was not on a conveyer at all. |
#155
![]() Flyingmonk wrote: It's surprising and refreshing that this thread, with so many posts, hasn't (yet) degraded into a flame-fest. ![]() Amen to that! The Monk Shockingly, no one has even called anyone a Nazi yet, nor has anyone called me a troll for posting this and then departing for the weekend without checking back to see if there were any replies. :-) |
#156
I hope none of you people are pilots!
#157
All right, dammit, you're a Nazi and a troll. And I'm taking off for a
couple of days. Satisfied? {;-) Jim "cjcampbell" wrote in message oups.com... Flyingmonk wrote: It's surprising and refreshing that this thread, with so many posts, hasn't (yet) degraded into a flame-fest. ![]() Amen to that! The Monk Shockingly, no one has even called anyone a Nazi yet, nor has anyone called me a troll for posting this and then departing for the weekend without checking back to see if there were any replies. :-) |
#158
"Jane! Stop this crazy thing!"
#159
"Montblack" wrote in message
... ("Michael Ware" wrote) You are taking the statement 'a conveyer belt that moves in the opposite direction at exactly the speed that the airplane is moving forward' to mean that somehow there is a force being applied to the mass of the aircraft, equal and opposite the thrust generated by the propellor. The only place the treadmill can exert any force an the airplane is the only place the treadmill is touching the airplane: the wheels. Any motion of the treadmill belt will be translated into rotation of the wheels. This will not prevent the aircraft from moving forward, through the air and taking off. That's one of the best so far. THE AIRPLANE WILL NOT MOVE. (That's my vote) The rotating wheels + gravity (Thank you Sir Isaac!) ANCHOR the plane to the treadmill. Plane/prop move forward, treadmill/wheels fall back. The plane is attached to the wheels. Try it in front of you with a ruler and a magic marker. That airplane is doing 150 mph down that runway, only the runway is really a treadmill which is matching that speed. End result is = to an Olympic sprinter on the same treadmill - I can stand next to him for his entire 10 second (27 mph) race. Lordy. BDS answered this pretty well. But, imagine that the plane is held still by a rope secured in front of the conveyor. That rope is attached to a strain guage that measures the force, in kg, say, that the moving conveyor exerts on the plane. This will increase with the speed of the conveyor, but let's use a reasonable number and we will see that the force is minimal since it's only whatever is converted to heat in the wheel bearings. Probably less than a few hundred watts. The amount of power required to move the plane forward will be more than required on a stationary runway by only this much. Dig? Montblack 83.7 (I thought some of double-digit people needed to be heard from. g) moo www.mensa.org |
#160
Still, it seems counterintuitive to me that if a plane is sitting on a conveyer that is moving backwards at exactly the same speed (I assume they mean groundspeed here) as the airplane is moving forward that the airplane will move forward at the same speed as if it was not on a conveyer at all. Then you may not be ready for this: http://www.mste.uiuc.edu/reese/monty/monty.htm moo |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
