Closing IFR flight plan at uncontrolled field
Old February 6th 06, 05:02 AM posted to rec.aviation.ifr
Default Closing IFR flight plan at uncontrolled field
This is the first time I've heard anyone say there's no big hurry.
I guess it depends on your location and the associated amount of
traffic and ATC workload. In my neighborhood, there is ALWAYS traffic
waiting. In fact, there's too much traffic get ATC to wait for a
relay.
Also, in my neighborhood, you get a 2 minute departure window with an
IFR clearance. If you ask for 3 minutes, you still get 2 minutes. If
you ask for 5 minutes, you're told to call back when you're ready to
depart.
Old February 6th 06, 08:29 AM posted to rec.aviation.ifr
The point is that in some parts of the country, Kansas,
Oklahoma, Nebraska for example, all airports with IFR
traffic above a few dozen per week, have remote ATC
frequencies. At other airports with sporadic IFR levels
that justify an IFR approach but not maintaining a remote
ATC outlet, there will rarely be more than one or two
operations per hour at any airport. The only time you don't
have time to land and walk inside to a telephone [if your
cell doesn't work] is if there is another aircraft waiting
for you to cancel so they can depart or land. If they are
in-flight, they will be happy to forward your cancellation
to ATC. If ATC has a strip for a waiting departure or
arrival, they will usually say so and ask for the quickest
cancellation and give instructions.
Often, departing aircraft will be able to depart in Class G
airspace under VFR at such remote uncontrolled airports.
When they are in radar contact with separation from the
other traffic, they will be issued a clearance.
VFR flight plans need to be cancelled within 30 minutes of
the ETA as amended, IFR has the same S&R time frame for
beginning a communications search. But you certainly have
five or ten minutes to land and taxi in and call on the
land-line.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Brien K. Meehan" wrote in message
big hurry.
amount of
ALWAYS traffic
wait for a
| relay.
window with an
minutes. If
you're ready to
| depart.
Old February 6th 06, 11:47 AM posted to rec.aviation.ifr
If your airport is in a TRACON area, I'm
sure you'll have a remote outlet.
Not always true. Plenty of airports inside TRACON areas with no RCO.
Old February 6th 06, 11:56 AM posted to rec.aviation.ifr
On Sun, 05 Feb 2006 20:09:20 -0500, Roy Smith wrote:
Ron Rosenfeld wrote:
If possible, you can also have an overflying a/c relay a cancellation to
ATC.
Have you actually done that? It's my understanding that ATC won't accept
an IFR cancellation via an aircraft relay.
I haven't done it recently -- not for the past three or four years.
However, I have done so in the past (just once or twice) and I've been on
both sides of the relay -- once I was the a/c waiting for the cancellation
so I could get in.
Maybe it's controller/location specific.
Old February 6th 06, 03:07 PM posted to rec.aviation.ifr
ATC.
I did this just a few weeks ago, as I was next in line for the approach, the
aircraft on the ground was unable to raise ATC on the radio, and I relayed the
cancellation and was immediately cleared for the approach.
Well, "immediately" is relative. There was a sort of three-way handshake to
verify the cancellation.
Something like:
Me: ATC, Nxxx is trying to call you to cancel IFR.
ATC: Verify you're relaying for Nxxx trying to cancel IFR.
Me: yes
ATC: Please call Nxxx and ask them to verify cancelling IFR.
Me. Nxxx, please verify for ATC that you wish to cancel IFR.
Nxxx: Affirmative cancelling IFR.
Me. ATC, Nxxx confirms cancelling IFR.
ATC: Advise Nxxx cancellation received.
Me; Nxxx, ATC advises cancellation received.
Nxxx: Thank you.
ATC: Nyyy cleared RNAV rwy 21 approach...
Old February 6th 06, 04:44 PM posted to rec.aviation.ifr
Something like:
Me: yes
Nxxx: Thank you.
This sort of CYA makes sense for everyone involved.
Peter
Old February 9th 06, 02:20 AM posted to rec.aviation.ifr
Another situation is while you are waiting to depart on IFR
clearance and being held for approach / landing traffic. Last
summer when I called ready to depart at Destin, FL, approach
told me to hold for release becuse of landing IFR traffic on an approach
to the airport. He called me back in a minute and gave me an update,
"Lear on approach now 2 miles striaght-in runway xxx". I advised I
had the traffic in sight and the controller asked me to report when
the Lear's wheels touched the runway. I did and he immediately released
me, even before the Lear turned off the runway.
Ronnie
"Dave Butler" wrote in message
news:1139238235.265085@sj-nntpcache-5...
ATC.
the aircraft on the ground was unable to raise ATC on the radio, and I
relayed the cancellation and was immediately cleared for the approach.
to verify the cancellation.
Something like:
Me: yes
Nxxx: Thank you.
Old February 9th 06, 02:16 PM posted to rec.aviation.ifr
Back when I was newly instrument-rated, I was so excited about having completed
my first ILS in IMC that I completely forgot about cancelling. As I taxied past
another airplane, I was still on the approach freq and I heard him call
approach, "...is that aircraft that I'm holding for N12345? He just taxiied past
me". I sheepishly 'fessed up and cancelled. DGB
Ronnie
ATC.
Something like:
Me: yes
Nxxx: Thank you.
Dave Butler, software engineer 919-392-4367
Old February 9th 06, 02:27 PM posted to rec.aviation.ifr
One problem is that a majority of the IFR is at those
airports with control towers, so pilots forget about
canceling. Much of the IFR to uncontrolled airports is in
VMC weather and the pilot will cancel when 5 miles from the
airport, the IFR flight plan just being a nice way to handle
controlled airspace, weather and TFRs. When they do have to
go to the E airport in real IMC, they forget that they have
to cancel.
Part 135 is required to be on a flight plan [VFR or IFR with
pax onboard or have their own flight following] so charter
flights can't cancel before landing even in good VMC.
James H. Macklin
ATP,CFI,A&P
some support
news:1139495082.404516@sj-nntpcache-3...
heard him call
IFR
Last
approach
me an update,
I advised I
report when
| Ronnie
a cancellation to
| ATC.
for the approach,
the radio, and I
the approach.
three-way handshake
| Something like:
IFR.
| Me: yes
IFR.
IFR.
| Nxxx: Thank you.
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
