#191
"MaulePilot" wrote:
A plane on a conveyor belt takes off East Bound at 9:15am from Peoria, Il, while a 747 on a conveyor belt takes off West Bound at the same time from Hackensack NJ. What time and at what point will they meet? NEVER you morons. There is no air moving over the wings to produce any 'lift', much less any forward ground speed. I can't believe the stupid crap that people talk about here. There goes another one! g Has anyone counted how many folks have fallen into this "trap"? I wonder if those who call others "morons" as they fall in tend to have bigger welts on their forehead when they finally get it and give themselves a dope slap? g -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#192
It was a joke James. I'll bet The Monk got it.
Even if I didn't I'd pretend that I did. LOL The Monk Damn straight you would! Damn straight you would! LOL The Monk |
#193
Thomas Borchert wrote:
Alexy, The conveyor is programmed to move in such a way as to maintain the aircraft at an airspeed of zero as measured at the pitot. Absolutely, if you CHANGED the problem, and restated it as above, then it wouldn't fly. Actually, you couldn't do that - which is another point the question makes. True, from a practical standpoint. As far as the thought experiment goes, you could if the conveyer moved fast enough that the rolling friction of the tires plus the bearing friction of the wheels exactly offset the thrust of the plane's propulsion system. My initial calculations indicate that the speed needed for that to happen is somewhat below the speed of light, but significantly beyond the speed at which the wheels and tires would disintegrate. g -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#194
Depends on how long the treadmill is....
-- Gene Seibel Hangar 131 - http://pad39a.com/gene/plane.html Because I fly, I envy no one. |
#195
I would be at a loss to explain the difference between the
minds of both groups. Well, the difference is simply that someone looks at the tree, someone else looks at the forest and sees the problem in its integrity. Everyone that answers "Won't take off" don't think that the runway is NOT a relevant element to make an airplane take off. The airplane works in the air whether or not the wheels are on the ground. Piero |
#196
No one has thought of the other limitation: the airplane could fall off
the edge of the world. |
#197
Alexy,
Has anyone counted how many folks have fallen into this "trap"? What irks me most is how violent people attack those of a different opinion over this rather trivial matter - all the while being wrong... -- Thomas Borchert (EDDH) |
#198
Darthpup,
Actually conveyor belt would decrease the length of runways if operated in the direction of take off??? The point the question makes is that the speed of the belt is completely independent of the airspeed of the plane, so you just CAN'T make the belt keep the airspeed at zero. -- Thomas Borchert (EDDH) |
#199
Alexy,
My initial calculations indicate that the speed needed for that to happen is somewhat below the speed of light, but significantly beyond the speed at which the wheels and tires would disintegrate. g Concur. g -- Thomas Borchert (EDDH) |
#200
wrote)
[snip] The airplane works in the air whether or not the wheels are on the ground. BUT...the AIRplane isn't in the AIR yet! Gravity, wheels, belt, zero airspeed. Once the wings get some lift under them, sure... But just like a plane sitting on the tarmac, our plane is still heavy enough to rest on those happy little spinning wheels. It's not a frigg'n blimp! Montblack 83.7 More from the double-diget crowd. |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
