King KX155 question
Old February 7th 06, 11:11 PM posted to rec.aviation.owning
Default King KX155 question
Flyers,
I have a Bendix-King KX155 which I use as my primary radio. Lately I have
major distortion only on certain frequencies. For example I frequently talk
to Atlantic City Approach on 134.25 and the reception is garbled. I have
limited data on some things since this is a new problem. But I *think*
switching radios does not always fix the problem. Sometimes it does and
sometimes it doesn't. I think they can hear me better then I can hear them.
It only seems to be frequencies above 130.xx. Lower frequencies are fine.
I assume I only have one antenna for both radios. Sorry for such scant
information. I will try and pin some of these variables down in the next
few days.
Any ideas?
Kobra
Old February 8th 06, 01:25 AM posted to rec.aviation.owning
I wouldn't bother trying to figure it out too much, as long as you can
describe the problem to the avionics shop. The radios really are black
boxes to most of us. I don't understand 1/2 of what my avionics guy
tells me anyway, and I have an undergrad in engineering.
-Robert
Old February 8th 06, 02:42 AM posted to rec.aviation.owning
Kobra wrote:
Flyers,
few days.
Any ideas?
Kobra
Antenna or Coax. Your avionics shop should be able to test that very quickly.
Steve Rubin / AE6CH / http://www.altdb.net/
Email: / N6441C / http://www.tch.org/~ser/
"Why don't you mind your own business?" -- John Navas 01/04/05
"If you don't like it, keep it to yourself" -- John Navas 01/04/05
Old February 8th 06, 07:22 AM posted to rec.aviation.owning
Maybe half of what your avionics guy tells you is BS.
Old February 8th 06, 03:02 PM posted to rec.aviation.owning
While you may have a single antenna for the nav portions of multiple
radios, I would bet that each comm radio has its own separate antenna.
When you get this sorted out, be sure to ask someone knowledgeable to
point out each antenna and its function.
Old February 8th 06, 03:38 PM posted to rec.aviation.owning
Kobra wrote:
: Flyers,
: I have a Bendix-King KX155 which I use as my primary radio. Lately I have
: major distortion only on certain frequencies. For example I frequently talk
: to Atlantic City Approach on 134.25 and the reception is garbled. I have
: limited data on some things since this is a new problem. But I *think*
: switching radios does not always fix the problem. Sometimes it does and
: sometimes it doesn't. I think they can hear me better then I can hear them.
: It only seems to be frequencies above 130.xx. Lower frequencies are fine.
: I assume I only have one antenna for both radios. Sorry for such scant
: information. I will try and pin some of these variables down in the next
: few days.
I had a similafr problem with my #1 KX155. Bad disgtortion on PVD approach,
135.4, OK on other lower freqs. Turned out to be a bad connection to the
whip-style antenna.
Aaron C.
Old February 8th 06, 03:51 PM posted to rec.aviation.owning
I had some distortion problems on my COM radios. One was when the audio
panel switch was in the BOTH position, COM2's audio was distorted and had
low volume. I avoid using the BOTH position now. This is easy to do since
COM1 is and SL30 and can monitor its standby frequency while talking on the
primary freq.
The other problem was also in the BOTH position when COM1 and COM2 were
tuned to nearby frequencies. The sidetone was extremely garbled when
transmitting. Changing the non-transmitting radio to a different frequency
or turning down its volume bypassed the problem. Of course not using the
BOTH position would also have avoided the problem.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
"Kobra" wrote in message
Flyers,
talk to Atlantic City Approach on 134.25 and the reception is garbled. I
have limited data on some things since this is a new problem. But I
*think* switching radios does not always fix the problem. Sometimes it
does and sometimes it doesn't. I think they can hear me better then I can
hear them. It only seems to be frequencies above 130.xx. Lower
frequencies are fine. I assume I only have one antenna for both radios.
Sorry for such scant information. I will try and pin some of these
variables down in the next few days.
Any ideas?
Kobra
Old February 9th 06, 04:24 AM posted to rec.aviation.owning
Maybe, but how the hell would I know?
Old February 9th 06, 06:22 PM posted to rec.aviation.owning
"Robert M. Gary" wrote in message
You don't have a well-calibrated BS detector?
King Avionics Repair [email protected] Owning 1 December 4th 04 12:49 AM
The Superior King Tiger robert arndt Military Aviation 168 June 8th 04 12:25 AM
Got to land a King Air 90 today... Jay Honeck Piloting 73 March 26th 04 07:59 PM
Selling some of my King and Jeppesen FlighTime Videos on Ebay - Various Titles Cecil E. Chapman Products 0 October 21st 03 05:47 PM
$5.8M for a King Air? Doug Vetter Owning 5 October 19th 03 01:04 AM
