#21
Rachel wrote:
Matt Whiting wrote: Rachel wrote: Matt Whiting wrote: Kyle Boatright wrote: "Nik" wrote in message ups.com... Ok thank you... How would you say the intentions though? -Nik "Your Location Traffic, NXYZ is going around due to departing traffic on Runway **, will fly an upwind on the Right side of Runway **." I'd probably say I was going around due to a fool on the runway, but otherwise I concur with what you suggest. :-) I normally unkey the mic and THEN say what I really want... :-) Why unkey the mic? Matt Controllers tend to get angry when you swear on the radio. Well, I wouldn't do that, but I don't have any qualms letting the idiot know that I know that he or she is an idiot. :-) Matt |
Rachel wrote:
Matt Whiting wrote: Rachel wrote: Matt Whiting wrote: Kyle Boatright wrote: "Nik" wrote in message ups.com... Ok thank you... How would you say the intentions though? -Nik "Your Location Traffic, NXYZ is going around due to departing traffic on Runway **, will fly an upwind on the Right side of Runway **." I'd probably say I was going around due to a fool on the runway, but otherwise I concur with what you suggest. :-) I normally unkey the mic and THEN say what I really want... :-) Why unkey the mic? Matt Controllers tend to get angry when you swear on the radio. I agree. And none of us really want to hear your pain, unhappiness, inconvenience, etc. Try to be a professional and handle the situation as you have been taught. |
Stubby wrote:
Rachel wrote: Matt Whiting wrote: Rachel wrote: Matt Whiting wrote: Kyle Boatright wrote: "Nik" wrote in message ups.com... Ok thank you... How would you say the intentions though? -Nik "Your Location Traffic, NXYZ is going around due to departing traffic on Runway **, will fly an upwind on the Right side of Runway **." I'd probably say I was going around due to a fool on the runway, but otherwise I concur with what you suggest. :-) I normally unkey the mic and THEN say what I really want... :-) Why unkey the mic? Matt Controllers tend to get angry when you swear on the radio. I agree. And none of us really want to hear your pain, unhappiness, inconvenience, etc. Try to be a professional and handle the situation as you have been taught. Not sure if that was supposed to be an insult. I'm always professional on the radio. But name one pilot who doesn't bitch when he gets on the ground. |
Rachel wrote:
Nik wrote: Ok thank you... How would you say the intentions though? -Nik "Going around, sidestepping to the right" Isn't "Going around" sufficient. The default is "to the right" so you don't tangle with other planes on crosswind and base. |
Depends on other factors, especially WHERE on final I am
True enough. If you're far enough behind the departing acft and can maintain a safe interval (maybe with S turns) then you can continue the approach, otherwise I've taught my students to be spring-loaded for a go-around. |
Just swing to the right and stay clear of the jerk and continue back
around the pattern. I have had it happen to me at least a dozen times in the last thirty years. |
Sorry, I don't fly over the same runway when another aircraft could be
right below me, or that I could run into it. ATC would be quite okay with you sidestepping. That is, of course, if you didn't already receive instructions telling you to get out of the way. At a non-towered field, see the above, but announce intentions. If I lose sight of the other traffic, it's no longer "See and Avoid". It becomes, "I made a bad decision and hope the other plane avoids me." Chris G. Steven P. McNicoll wrote: "Kyle Boatright" wrote in message . .. In both cases, announce your intentions, offset your approach and fly an upwind leg (typically to the right of the runway centerline). You should adjust your upwind leg to keep the rogue aircraft/pilot in view until it is no longer a collision threat. At a controlled field, unless told otherwise, you should overfly the runway while climbing to traffic pattern altitude. |
#28
![]() "Chris G." wrote in message reenews.net... Sorry, I don't fly over the same runway when another aircraft could be right below me, or that I could run into it. ATC would be quite okay with you sidestepping. That is, of course, if you didn't already receive instructions telling you to get out of the way. The instruction, "go around", by itself, means overfly the runway while climbing to traffic pattern altitude. You're not complying with the instruction if you sidestep to the right without being told to do so. |
#29
On Wed, 08 Feb 2006 19:11:41 GMT, "Steven P. McNicoll"
wrote: "Chris G." wrote in message freenews.net... Sorry, I don't fly over the same runway when another aircraft could be right below me, or that I could run into it. ATC would be quite okay with you sidestepping. That is, of course, if you didn't already receive instructions telling you to get out of the way. The instruction, "go around", by itself, means overfly the runway while climbing to traffic pattern altitude. You're not complying with the instruction if you sidestep to the right without being told to do so. Maybe so, but the pilot in command is the ultimate authority for the safety of the flight.... For what it's worth, I'd only side-step if I didn't like what I saw below and in front of me. Letting ATC know what I was doing would of course be a polite thing to do! Bela P. Havasreti |
#30
There were two rationales given in this thread, and both of them make
sense to me... but which one would you say is more correct? a) stay to the right to make it easier to see the traffic (sitting in the left seat), b) stay to the right to stay away from the pattern (and away from the departing plane's presumed crosswind turn). The reason for asking, of course, is what should you do if the pattern is RH - sidestep to the left or right? I've only had to go around for traffic once and it was a weird situation. I was cleared for T&G on 31. 28 starts to the right of 31, intersects it, and obviously continues to the left. I was on short final when tower cleared someone for takeoff on 28; he started rolling. Since i wanted no part of playing chicken at the intersection, I immediately went around (then announced it), flew the centerline and probably the tower gave me right traffic to stay away from the departure end of 28. The other guy's takeoff clearance was not canceled, and he departed. At the time (pre-solo), I was a little rattled, the tower said "sorry about that" and my instructor said I did the right thing. But, after reading this thread, it made me think about it some more, and I realize I likely did not keep the traffic in sight and in fact may have passed directly over him at some point (certainly a possibility even if it didn't actually happen that way). So, now I think perhaps I should have done something differently, but what? Not crossing 28 would be difficult at best (the airport is KAGC if anyone wants to look at a diagram) - for one, it's going to involve really low altitude turns - no way you're missing the approach end by turning right, and if you go left you're headed towards the hangars and tower. You're also not going to have a lot of choice about your airspeed during the initial stages of the go-around. So what to do? I know now that a 172 should easily be able to land and stop before the intersection, but even now (a whopping ~25 hours later) I wouldn't be entirely comfortable with that... todd |
