Going around what to do?
Old February 10th 06, 02:00 PM posted to rec.aviation.piloting
Default Going around what to do?
"Kyle Boatright" wrote in message
True, but ATC isn't likely to suffer the ultimate price should there be a
mid-air collision. I'm announcing intentions and keeping the rogue
aircraft in sight. If ATC has a problem with that, we can sort it out
later.
A midair with the rogue departure? That seems unlikely. You're behind and
above the aircraft taking off. For a collision to occur it would have to
climb significantly faster than your aircraft. If it can it do that it is
probably significantly faster as well and will stay in front of you. The
safest thing to do is comply with the instruction and overfly the runway.
  #62
Old February 10th 06, 02:13 PM posted to rec.aviation.piloting
"Gig 601XL Builder" wrDOTgiaconaATcox.net wrote in message
How much room will there be as the Cessna rolls down the runway? If he
leaves me about 1000 feet I'm landing.
And what happens if he aborts his takeoff and stops?
How much room is there?
  #63
Old February 10th 06, 02:14 PM posted to rec.aviation.piloting
"Ron Lee" wrote in message
I agree. Be safe and if they want to scream and yell at least
everyone is alive to vent.
Not if you turn and collide with somebody on downwind.
  #64
Old February 10th 06, 02:19 PM posted to rec.aviation.piloting
"Allen" wrote in message
t...
And if you follow ATC instructions and the departing aircraft collides
with you you are still at fault for not seeing and avoiding and you are
still
dead.
So the best course of action is to comply with ATC's instruction and overfly
the runway. There's less risk of collision and no risk of enforcement
action.
  #65
Old February 10th 06, 06:52 PM posted to rec.aviation.piloting
On Fri, 10 Feb 2006 12:39:12 GMT, "Steven P. McNicoll"
"Bela P. Havasreti" wrote in message
Maybe so,
There's no "maybe" about it. The Pilot/Controller Glossary was compiled to
promote a common understanding of the terms used in the Air Traffic Control
system. The instruction "Go Around" is defined as:
"Instructions for a pilot to abandon his/her approach to landing. Additional
instructions may follow. Unless otherwise advised by ATC, a VFR aircraft or
an aircraft conducting visual approach should overfly the runway while
climbing to traffic pattern altitude and enter the traffic pattern via the
crosswind leg. A pilot on an IFR flight plan making an instrument approach
should execute the published missed approach procedure or proceed as
instructed by ATC; e.g., "Go around" (additional instructions if required)."
but the pilot in command is the ultimate authority for
the safety of the flight....
"The pilot in command of an aircraft is directly responsible for, and is the
final authority as to, the operation of that aircraft." Authority and
responsibility go hand-in-hand. So if you're instructed to overfly the
runway while climbing to traffic pattern altitude, but instead use your PIC
authority and begin a climbing turn to the right and collide with an
aircraft on downwind, you're responsible for all damages, injuries, and
lives lost.
For what it's worth, I'd only side-step if I didn't like what I saw
below and in front of me. Letting ATC know what I was doing
would of course be a polite thing to do!
It would also make any potential enforcement action of your violation of FAR
91.123(b) easier.
ATC can issue whatever instructions they want. If a collision is
imminent, or likely, based upon their instruction and based upon
what I'm seeing out of the windshield as PIC, I'm going to do whatever
it takes to keep from colliding with another aircraft. As someone
else pointed out, the idea is to be around for the hearing, or the
inevitable "talk" one might have with the feds.
Pilots are human beings and sometimes make mistakes. Sometimes
sheet metal gets bent, and other times, folks get hurt or killed.
Controllers are not exempt from "being human" and making mistakes....
(it's happened many times before, and it'll no doubt happen again).
Bela P. Havasreti
  #66
Old February 10th 06, 07:32 PM posted to rec.aviation.piloting
Well, no, there are limits to the instructions ATC can issue.
If a collision is
It is unlikely that proper compliance with an instruction to "go around"
will make a collision imminent or even likely. Following the improper
action that you espouse is more likely to do that. If you do not understand
the procedures or terminologies commonly used at towered airports it would
be best from the standpoint of safety for you to avoid towered airports.
  #67
Old February 10th 06, 08:24 PM posted to rec.aviation.piloting
On Fri, 10 Feb 2006 19:32:40 GMT, "Steven P. McNicoll"
I am perfectly comfortable flying into towered airports (been flying
since 1976, and have lived in a large, metropolitan area most of
my life). I'm not a "rebel" and I do comply with ATC instructions the
vast majority of the time (in case you're wondering, yes... I have
used the "unable" card with ATC on occasion when the situation
warranted it). I'm only pointing out the fact that I'm the PIC of the
aircraft I'm flying and I decide what the safest way is to operate
said aircraft, not ATC. If you still feel the need to quote FARs and
post insulting comments about my ability to fly safely, knock
yourself out....
I apologize for having to point this out, but you can't make others
think exactly the way you do by pressing arguments on usenet....
During your tenure on this good green earth, there just may
be times when others don't agree with what you have to say.
The sooner you learn to live with that fact, the sooner you can
begin to enjoy life (don't sweat the small stuff...).
Be safe, and have a nice flight.
Bela P. Havasreti
  #68
Old February 10th 06, 09:14 PM posted to rec.aviation.piloting
yourself out....
I was merely pointing out that the course of action you proposed is unsafe
and explained why that is so. If you choose to feel insulted by that then
that is your privilege.
  #69
Old February 10th 06, 09:40 PM posted to rec.aviation.piloting
helloooooo.....
I wouldn't sidestep THAT far... NOR would I sidestep into traffic (that
I know about). Steve, Give it a rest. As PIC, I'm responsible for the
safety of my aircraft and of my actions. You quoted the regs saying
just that. If I feel that I *need* to deviate from ATC instructions to
avoid an imminent collision, then I believe that would constitute and
EMERGENCY. In an emergency, it is well known that I may deviate from
the FARs to meet the needs of that emergency. Also, remember, Aviate,
Nagivate, and Communicate. I'll tell ATC what is going on, but not
before I ensure the safety of my flight. That being said, I don't doubt
that ATC will not intentionally issue an instruction that would put me
in harm's way. That still does not relieve me of being situationally
aware and ready to respond appropriately to a given situation/instruction.
Chris G.
PP-ASEL and still alive to talk about it cuz I fly safely!
  #70
Old February 10th 06, 10:22 PM posted to rec.aviation.piloting
On Fri, 10 Feb 2006 21:14:55 GMT, "Steven P. McNicoll"
yourself out....
It is not unsafe, and you did not "explain why that is so". You
quoted some regs. Regs are open to interpretation.
Nobody is talking about a 4+ G pitchout to the side to avoid
an aircraft that is 1000+ feet up-wind.
I'm guessing you're just one of those folks who like to "argue"
and/or get the last word in.....?
If so, be my guest and post your last word(s)
here - - 8^)
Bela P. Havasreti
