Rubber Band Powered Aircraft?
Old February 15th 06, 05:32 PM posted to rec.aviation.homebuilt
Default Rubber Band Powered Aircraft?
Like Bugs Bunny winding up for a pitch ...in the short where he
single-handedly (does Bugs have "hands"?) takes on the Gas-house
gorrillas.
rrrrrr.... rrrrrrrmrmrrr...... rrrrrrrrrrrrrrRRRRR,
rrmmmmrrRRRRRRRRRrrr, mmmmmmmrRRRRRRRRRRRRRRRRRRRRR,
mmmmmmmmmRRRRRRRR..... peeeeeeeeeeewwwwwwwwww, KApump, pumpffff,
pumppffff, kerPACK, blub, blub, blub.......
My Dad tells me that the Bell 214 uses electric-powered inerta starters
for its turbine engines. But that helicopter's rotor mass is somewhere
in the neighborhood of 2 tons.
Harry
  #32
Old February 15th 06, 05:47 PM posted to rec.aviation.homebuilt
In article , Orval
Fairbairn says...
All except the engines didn't the Spanish built 109 have Hisso&*%**# engines
which changed the look of the nose .
They got Merlins after the supply of DBs dried up at the end of WW-II.
Your right they had Dammm*&%$$$# Ben#%$&** engines not Hiss#@#%$&^%4 Wrong war
:-)besides Merlin is so much easier to spell :-)
See ya
Chuck S
  #33
Old February 15th 06, 05:50 PM posted to rec.aviation.homebuilt
In article mZIIf.558321$084.430955@attbi_s22, John Ousterhout says...
ChuckSlusarczyk wrote:
I think the plane was a Me-108 it was used as a civil plane then a trainer and
later a squadron hack.It had an inertia starter I believe.Wind it up and go :-)
Chuck(I was just a kid then) S
You still are just a kid Chuck.
and it's a damn good childhood you're having too.
- John Ousterhout -
Thank you kind sir but sooner or later I'll have to grow up but I'm having way
too much fun with my childhood to give it much consideration LOL!!
See ya
Chuck (had a confirmation now I'm going for a bar mitzva)S
  #34
Old February 16th 06, 01:07 AM posted to rec.aviation.homebuilt
Having in my possesion two ( ECLIPSE ELECTRIC STARTER ENERGIZERS )I have
become with the types of starters used back when I wuz a kid.
I soloed in a PT-19 w/ a Ranger inverted 6 .. It was a direct drive hand
crank that turned the engine slowly (albeit jerkily) with one or two
manpower applied to the crank.
The stearmans had the Inertia type where the ground personnel started
(slowly) cranking up the flywheel, when the proper whine was reached,
one of them pulled the clutch actuator which engaged it, turning the
engine over rather briskly for a turn or two,
At a flying school with 50-100 planes this could get tiring, so they
came out with 110 volt electric motors with about a 3 ft shaft extending
to a 90° gear box that took the place of the hand crank---there were a
couple of models, Eclipse , and Jack& Heintz, The Eclipse had a spring
loaded clutch that slipped before enough torque was developed to spin
the ground person around the side of the fuselage.---J&H had a flimsy
3/8" aluminum tube in the drive shaft that twisted up & sheared
(hopefully before spinning the operator).. Needless to say, the J&H was
out of service for the rest of the morning until the unit was
disassembled & the shaft replaced.
Eclipse also made the inertia unit with an integral starter motor, AND
the crank hole ALSO.. so if your battery went dead, you could still
start.---Jerry
- John Ousterhout -
See ya
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
