#31
Morgans wrote:
You no doubt have found that the group will get into mental exercises like this, and you know what they say about opinions... g What you want to do is mount a lathe bit on a spring loaded arm. You pull a lever and cut the prop shaft off. Deploy the chute when you feel the prop drop off the back. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
#32
Okay Rich, I'll bite. You must have thought up a way to do that,
but it escapes me right now. Explosive bolts like they use in the space program? Don W. Rich S. wrote: "Don W" wrote in message . com... You wouldn't need a brake to get a fully feathering prop to stop. Even with the propeller stopped it seems that getting the chute to deploy without snagging risers on the prop would be problematic Don............ I see you did not pick up on my suggestion, so I'll take it one step further. If the *prop* is the problem, jettison the _________. (Fill in the blank) Rich "Engines are expensive, too." S. |
#33
om... Okay Rich, I'll bite. You must have thought up a way to do that, but it escapes me right now. Explosive bolts like they use in the space program? Oh heck, Don. I was just trying to focus your problem solving skills on where I thought the real problem was. It's not with the engine, of course - besides, they're too hard to convince that leaving the airframe is the proper thing to do. I remember when I was building Esmeralda, I gave a bit of thought on how to prevent the engine from departing the building in case I should ever toss a prop blade. CG shift making the airframe unflyable, y'know. I like the lathe tool idea, but there's others that might work. Since it's a pusher, the prop would normally like to stay on something like a splined shaft. You could have a snap-ring retainer that would resist it coming off during an idling descent. To jettison, a rubbing block would push the snap ring out of its groove and wind drag would yank the prop back and off the shaft. If it is a controllable pitch unit with separate blades, there must be a way to retain the center section and just lose the blades. I think some of the composite props have that happen unintentionally! It would seem that the most elegant solution lies in a prop shroud. No moving parts, an increase in safety and possible efficiency improvement. Rich S. |
#34
("Rich S." wrote)
To jettison, a rubbing block would push the snap ring out of its groove and wind drag would yank the prop back and off the shaft. The Wile E Cyotte in me is seeing a spinning prop (flipped horitontal) coming back to get me ...and/or the chute lines. Didn't factor that one in, did ya? :-) http://img.thefreedictionary.com/thu...e_E_Coyote.jpg It would seem that the most elegant solution lies in a prop shroud. No moving parts, an increase in safety and possible efficiency improvement. I've heard said improvements in efficency, with prop shrouds, haven't transfered well from the chalkboard to the airframe. http://www.midwaysailor2.com/blaine/optica.html OA7 Optica - pusher prop shrouded aircraft. (ANE) Anoka County-Blaine, MN D.A.D. Days, 2003 Montblack |
#35
"Montblack" wrote in message
... ("Rich S." wrote) To jettison, a rubbing block would push the snap ring out of its groove and wind drag would yank the prop back and off the shaft. The Wile E Cyotte in me is seeing a spinning prop (flipped horitontal) coming back to get me ...and/or the chute lines. Didn't factor that one in, did ya? :-) Zee small parachute for zee prop is trailing out of zee spinner. It would seem that the most elegant solution lies in a prop shroud. No moving parts, an increase in safety and possible efficiency improvement. I've heard said improvements in efficency, with prop shrouds, haven't transfered well from the chalkboard to the airframe. I said possible! ![]() http://www.moller.com/ Rich "Wanna see the elepahant??" S |
#36
![]() Montblack wrote: ("Rich S." wrote) It would seem that the most elegant solution lies in a prop shroud. No moving parts, an increase in safety and possible efficiency improvement. I've heard said improvements in efficency, with prop shrouds, haven't transfered well from the chalkboard to the airframe. http://www.midwaysailor2.com/blaine/optica.html OA7 Optica - pusher prop shrouded aircraft. (ANE) Anoka County-Blaine, MN D.A.D. Days, 2003 Montblack That is one funky looking airthingamabob! Don W. |
#37
![]() Rich S. wrote: Oh heck, Don. I was just trying to focus your problem solving skills on where I thought the real problem was. It's not with the engine, of course - besides, they're too hard to convince that leaving the airframe is the proper thing to do. Yeah, and the other thing is that you usually want them to stay firmly attached. I remember when I was building Esmeralda, I gave a bit of thought on how to prevent the engine from departing the building in case I should ever toss a prop blade. CG shift making the airframe unflyable, y'know. Yep, I know of one fatal accident that started with the engine trying to fly on its own. I like the lathe tool idea, but there's others that might work. Since it's a pusher, the prop would normally like to stay on something like a splined shaft. You could have a snap-ring retainer that would resist it coming off during an idling descent. To jettison, a rubbing block would push the snap ring out of its groove and wind drag would yank the prop back and off the shaft. If it is a controllable pitch unit with separate blades, there must be a way to retain the center section and just lose the blades. I think some of the composite props have that happen unintentionally! Okay, you just made me think of a way that would work for a controllable pitch prop. Just make the retainer hub keyed to fit the prop, and when you rotate the prop just right, it slings its blades. Check list item: Make sure that the propellor control detent lock is installed properly. WARNING: NEVER OPERATE THE PROPELLOR CONTROL IN THE DETENT POSITION EXCEPT IN AN EMERGENCY REQUIRING THE BALLISTIC CHUTE!! It would seem that the most elegant solution lies in a prop shroud. No moving parts, an increase in safety and possible efficiency improvement. Rich S. I finally figured out what you mean by a "prop shroud". Duh... Yeah that could work. Don W. |
#38
. com... I finally figured out what you mean by a "prop shroud". Duh... Yeah that could work. Pushy Galore used to have one, but I couldn't find a picture taken before it was removed. Rich S. |
#39
![]() "Don W" wrote in message . com... Tater Schuld wrote: "Don W" wrote in message . com... I'd really like to build something like a pressurized turboVelocity with the VNE pushed up to 250kts. I'd also like it to have a built in ballistic chute system which jettisons the engine (to its own chute) before deployment. instead of asking us, wouldn't it be wiser to ask the makers of ballistic chutes? That makes too much sense ;-) Unfortunately, I don't know any of them and you guys are readily available. I suspect that if I approached one of the ballistic chute companys about this they would give me that "you must be joking, right" look and tell me that ballistic chutes for pushers is too thin of a market for them to go after. http://brsparachutes.com/Default.aspx?TabId=18 There's the contact info page from their site. They have them mounted in pusher ULs already. |
#40
Piano hinges with cable instead of wire hold the pod to the rest of the
airframe. Size it to resist the canopy lift load. When you pull the plug, a spring-loaded reel yanks the cable out. The chute deploys, and the airplane falls away from you. Best let go of the stick, since the controls are attached to the airframe. All that's in the pod are the seats (strap in tight!). The control panel needs to stay with the airframe, too - waaay too many quick-disconnects to think about there. One set for the headsets is doable, but throttle, instruments... of course, with FADEC and a full glass cockpit all you have is a big honkin multipin plug. No. You still have the steam gauges as backups, so you still have the pitot/static connection to deal with. But now you don't have any structure under you to cushion the impact. In fact, your feet are hanging out in space a la Fred Flintstone. Deploy an airbag once forward speed drops? |
Introduction to AMU spending | Jack Allison | Owning | 12 | May 3rd 05 01:06 PM |
Introduction to a newbie | Shane O | Aerobatics | 9 | December 31st 04 06:13 AM |
request for introduction | GARY WAINWRIGHT | Home Built | 1 | March 4th 04 01:11 AM |
Vietnam era F-4s Q | Ed Rasimus | Military Aviation | 87 | September 27th 03 03:59 PM |
My introduction and 4 seater kits | LFOD76 | Home Built | 18 | July 25th 03 09:36 AM |
