Experimental Aiworthiness
Old February 21st 06, 07:26 PM
Gadget Guy Gadget Guy is offline
Junior Member
First recorded activity by AviationBanter: Nov 2005
Default Experimental Aiworthiness
I have just recently had my Airworthiness inspection on a DG-300 completed by the local DAR. He provided me with 5 pages of limitations. I noticed that the past owner had only 1 page, a total of 9 limitations. The airplane has only been in the country for 7 years. Does someone know where these limitations come from? What is the Guideline that the FAA DAR follows when issueing?
The plane has a exhibition/racing Special Airworthiness.
John
Old February 21st 06, 10:50 PM posted to rec.aviation.soaring
FAA Order 8310F, including Chg 1 (347pages)
http://tinyurl.com/8fxtg (pdf)
See Section 10, pg 184 for Experimental Racing, Exhibition. All items
that pertain to Group I, Performance Competition Aircraft as
applicable.
Frank Whiteley
Old February 24th 06, 02:38 AM posted to rec.aviation.soaring
Try re-applying for the Operating Limitations at your FSDO. My old
OLs had 16 paragraphs, one being the requirement to send an annual
Program Letter to a specific FSDO which no longer existed. It was also
2300 miles away.
I applied for a new EXP certificate and Operating Limitations at the
local FSDO, which came to 9 sensible paragraphs. The only Program
Letter required was submitted with the application. I thought that was
exceptional service, and cost nothing.
Yes, you did read - exceptional service - from the FAA!
When an Experimental aircraft moves from one FSDO's jurisdiction to
another, the new local FSDO would prefer to have the paperwork filed in
their office.
Old February 24th 06, 05:38 AM
Junior Member
Thanks Jim
The other item that we started to discuss locally is can a owner of a experimental perform "ALL" maintenance on their ship? Part 43.1 (b) says "This part does not apply to any aircraft for which the FAA has issued an experimental certificate, unless the FAA has previously issued a different kind of airworthiness certificate for that aircraft. "
The local DAR had said that I can do all maintenance. I just log it to the plane log book and put my pilot certificate number down.
Now I know my own limits of what I can do and can't do mechanically. But does this mean that the only sign off I need from a AP or AI is for the condition inspection every year? This would lead me to believe that the only advantage to a homebuilt is a Repairmans liscense allows you to do your own annual.
Is this thinking correct?
2300 miles away.
their office.
Old February 24th 06, 04:28 PM posted to rec.aviation.soaring
Earlier, Gadget Guy wrote:
...But does this mean that the only sign off I need from a AP or AI is for
do your own annual.
I believe that it is correct, unless there are specific directives
otherwise in your Operating Limitations. It's definitely how I approach
my experimental glider.
But, personally, I'm of a mind that the annual condition inspection is
best done by a party other than the builder or owner. They're more
liely to bring a fresh perspective to the job.
Bob K.
Old February 24th 06, 06:02 PM posted to rec.aviation.soaring
do your own annual.
This is certainly my experience over the last 20 years.
www.motorglider.org - Download "A Guide to Self-launching Sailplane
Operation"
Old February 24th 06, 06:47 PM posted to rec.aviation.soaring
There are differences regarding the assignment and transferability of
operating limitations depending on whether your glider was pre- (July
9, 1993) or post- (August 18, 1993) moratorium import.
Frank Whiteley
Old February 26th 06, 05:33 AM posted to rec.aviation.soaring
We tend to be a bit liberal with the EXP rules. I hear you can
disassemble and reassemble the whole flying machine, but modification
is a bit of a gray area. There is a rating (?) you can get from your
FSDO which would permit you to perform maintenance on your own
experimental aircraft. This can be used to log hours toward other
mechanic ratings.
Agreed, Bob, a fresh perspective is good on the annual "condition
inspection".
Old February 26th 06, 06:18 AM posted to rec.aviation.soaring
Liberal or not, alteration or major modification with likely void your
current airworthy and involve a new Special Airworthiness Certificate
which would require new operating limitations and program letter and
perhaps fly-off requirements.
I'm aware of a experimental glider that the two previous owners were
not flying legally. Neither came to the attention of the FAA, but
there exists a trail of documentation that would indicate that pilots
and perhaps those signing off the condition inspections were ignorant
of specific requirements.
Frank Whiteley
Old February 26th 06, 04:42 PM posted to rec.aviation.soaring
mechanic ratings...
So far as I know, there is no such rating. The closest thing I know of
is the reparman's certificate available to the builder of an
amateur-built experimental. As as others have mentioned, the only
unique priviledge it confers is that of conducting the annual condition
inspection.
Modifications depend on the aircraft's specific operating limitations.
Several years ago I developed a retrofit center stick control system
for my HP-18. At the time, my OLs specified that I had to inform the
FAA in writing of any major modifications. I did, and the FAA guys came
out and inspected it. They issued a new airworthiness certificate, and
also new operating limitations that said removed the provision for
informing the FAA, and instead just imposing a new test period.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com/hp-24
Flying Club with Experimental Aircraft Jeff Home Built 6 October 5th 05 09:16 PM
Experimental planes at air shows? Eugene Maslov Home Built 4 May 31st 05 05:09 PM
Experimental or not? John D. Abrahms Home Built 23 April 14th 05 01:45 AM
Weird Experimental Certificate wording - Normal? Noel Luneau Soaring 12 January 11th 05 06:11 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
