Getting a Power rating
Old February 22nd 06, 07:00 AM posted to rec.aviation.soaring
Default Getting a Power rating
I have my Glider ticket and want to get a power rating. Eventually I
want to get a tow rating. What do I have to do?
Bob
Old February 22nd 06, 10:19 AM posted to rec.aviation.soaring
http://search.yahoo.com/search?p=fly...&cop=&ei=UTF-8
Old February 23rd 06, 03:14 PM posted to rec.aviation.soaring
In the USA, this is governed by 14CFR 61.109(a). Basically if you have
18 hours in gliders with at least 8 hours dual, then you can meet the
ASEL requirements with 12 dual and 10 solo hours in a single engine
airplane. In order to complete that fast, you will need to be prepared
for each minute of your lessons. You also will need to pass the FAA
knowledge test for Private Pilot airplane.
Your instructor needs to be as prepared as well. Be sure he has a
syllabus that takes advantage of your experiences. Good luck with your
training.
Terry
Old February 23rd 06, 05:37 PM posted to rec.aviation.soaring
Todd,
My post paraphrased a legal interpretation from the FAA Eastern Region
General Council. It is posted on the AOPA forum and I have copy if you
need it. Dual is dual and unless the regulation specifically says
"airplane" or "single engine airplane" your glider time whether
instruction received or PIC count towards the larger totals.
Cheers.
Terry
Old February 23rd 06, 10:15 PM posted to rec.aviation.soaring
The others have covered the legalities (assuming you are in the US) and, if
you are a Private Pilot, you should be familiar enough withe the FARS to look up
the legal and procedural part yourself. I would like to take a moment to
discuss the "other stuff".
First of all, you will find the average power instructor woefully ignorant
about soaring. I suggest that you take your new instructor for a glider ride so
that he can have some minimal concept of the environment in which you have been
flying. Having done that; CLAM UP, turn on your ears, your brain and your
humility, act like any other student, and insist that your instructor assume
nothing. You will find that much of the ignorance goes both ways and you have
much to learn (and unlearn).
After several years flying gliders as a CFIG and commercial rides pilot, I
finally got a power rating just a year or so ago. It took me significantly more
than the minimum number of hours. My checkride was a humbling experience (yes,
I passed). I entertained the examiner (not) by forgetting to add power while
doing a stall recovery!
Vaughn (CFIG)
Bob
Old February 24th 06, 07:34 AM posted to rec.aviation.soaring
Cross-country glider flights in which you landed more than 50NM from
where you took off also count towards the single engine requirements.
Old February 26th 06, 02:24 PM posted to rec.aviation.soaring
Negative, JS. See 61.109(a)(5)(i):
"10 hours of solo flight time in a single-engine airplane, consisting
of at least--
[i] 5 hours of solo cross country time."
Your glider cross countries can count towards commercial or ATP, but
not private. Look to the requirements of each certificate and apply.
I do not know how any DPE could verify that the farmer's field you
landed in was at least 50 NM from your departure for commercial or
instrument. Good luck with that.
Terry C
Old February 26th 06, 09:01 PM posted to rec.aviation.soaring
of at least--
I was able to use my glider cross country time for about half of the
power solo requirements. The date, takeoff and landing points were
logged and signed in my log book. My instructor and examiner took that
on face value. It saved me about $1,000 at the time (now it will be
more like $1,600).
Tom Seim
Richland, WA
Another thing I'm puzzled about: this time power settings and altitude. xerj Piloting 8 October 4th 05 12:40 PM
Aw Rating merger and Today's ASW Charlie Wolf Naval Aviation 5 May 12th 05 10:34 PM
Are you gliding when you touch down? John Doe Piloting 29 January 23rd 05 12:52 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Winch Experts wanted Ulrich Neumann Soaring 117 April 5th 04 06:52 AM
