Wood/composite prop bolt torque
Old February 22nd 06, 08:34 PM posted to rec.aviation.homebuilt
Default Wood/composite prop bolt torque
For those of you who are concerned about prop bolt torque on non-metal
props, check out this article by Vance Jaqua:
http://www.geocities.com/vjaqua/prpblvl.html .
Old February 23rd 06, 01:27 PM posted to rec.aviation.homebuilt
On 22 Feb 2006 12:34:49 -0800, "ELIPPSE"
I use an australian article written by one of our propeller
makers.(Bishton)
the aim is for 600psi clamping force or thereabouts.
5/16"dia bolts try 5 - 8 lb ft
3/8"dia bolts try 10 - 13 lb ft
1/2"dia bolts try 18 - 25 lb ft.
yes we use belleville washers.
correctly installed the wooden prop is capable of outlasting the
aircraft.
Stealth Pilot
Old February 23rd 06, 09:43 PM posted to rec.aviation.homebuilt
Is everone getting a proper printout of the recommended article?
Graphs and some text missing?
Help ! (:)) - what do I have to do to get an all inclusive printout.
I have a "regular" computer and have had nothing like this before.
Old February 23rd 06, 10:05 PM posted to rec.aviation.homebuilt
Interesting article, belleville washers and all, but one should torque a
W72CK44 Sensenich on a Cub or T-Craft by the book at 200 inch/pounds, plus
or minus 15, and a month or so later re-torque and re-track.
Use mylar half-moons to set the prop track dead nuts.
If your engine is reasonably in balance, you'll fly smooth as silk.
Old February 24th 06, 04:12 AM posted to rec.aviation.homebuilt
All of the graphics are missing.
Old March 1st 06, 06:37 PM posted to rec.aviation.homebuilt
makers.(Bishton)
Belleville springs. This was a nit with an old engineer with whom I
worked and upon reflection, I agree with him.
Of course a bolt is also a spring, but no one ever talks about
hex-head springs....
FF
Why does a prop ice up so apparently readily? Mike Rapoport Instrument Flight Rules 2 November 8th 05 02:52 PM
Bolt torque Neal Fulco Home Built 1 October 16th 04 06:57 AM
Ivo Prop on O-320 Dave S Home Built 14 October 15th 04 03:04 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
Prop bolt torque setting Whunicut Home Built 2 September 4th 03 12:12 PM
