Military Airfield Procedures..
Old February 25th 06, 10:19 PM posted to rec.aviation.piloting,rec.aviation.ifr
Default Military Airfield Procedures..
Last night I took a quick trip to KYUM. On approach, the controller
mentioned that the "arresting gear was up" on the runway I was to land
on. Being unfamiliar with arresting gear and flying an Archer, I asked
the controller specifically what that meant. He indicated that it
consisted of a cable stretched across the runway about 6 inches high.
Since it seemed that this could seriously damage an Archer, I made sure
to land beyond it. (although it's exact position was difficult to
determine at night.)
Does anyone know what would have happened if I had landed on it? This
type of thing seems quite dangerous to GA aircraft.
On another note, as I was inbound on the ILS, the tower handed me over
to someone else for a "monitored" approach. This controller called my
position on the ILS and advised of any deviations. There was no
parallel ILS in progress. Is this just the way things are done at a
military field?
-Dan
Old February 25th 06, 11:09 PM posted to rec.aviation.piloting,rec.aviation.ifr
On 25 Feb 2006 14:19:32 -0800, "Dan" wrote:
Isn't the arresting gear charted as the E-23 lines on the airport
diagram? http://avn.faa.gov/d-tpp/0602/00511AD.PDF
I think the 1000x200 is how far up the runway and how wide the wire is
(for 3L at least, there are other similar numbers like 600x200 at the
other end)?
military field?
Did they say "No further acknowledgement required" or something to
that effect? If so you got a PAR (Precision Approach Radar). They
light up two radars, one for vertical and one for lateral positioning
and guide you all the way down. There's no civilian plate for these
(is there a military plate somewhere?) but it's a cool approach to
shoot with a safety pilot. Since the radar guidance is precision, you
need no onboard equipment to shoot this approach. I think it's fun to
go up with a safety pilot, cover the AI and DG, and shoot the approach
using altimeter, wet compass, and ground controllers only until they
call minimums, at which point you should be able to pop off the hood
and have a runway right in front of you.
Old February 25th 06, 11:33 PM posted to rec.aviation.piloting,rec.aviation.ifr
I was specifically on the ILS 21R. No mention of PAR, however they did
say "this will be a monitored approach" and handed me off to someone
else who simply gave me these position reports. I was unsure if I was
expected to acknowledge.
Old February 26th 06, 02:01 AM posted to rec.aviation.piloting,rec.aviation.ifr
On 2/25/2006 5:33 PM, Dan wrote the following:
Why don't you call them and ask for an explanation of what happened?
I think we'd all be interested to hear. In the few times I've called
ATC with a question they have been very willing to explain and help.
Old February 26th 06, 03:49 AM posted to rec.aviation.piloting,rec.aviation.ifr
a monitored approach is one step short of a PAR
BT
"Dan" wrote in message
Old February 26th 06, 03:50 AM posted to rec.aviation.piloting,rec.aviation.ifr
I should add.. that sometimes it is for controller currency..
he needs to do xx monitored approaches or xx PARs per quarter, just like you
need 3 landings per 90 days to carry pax
BT
Old February 26th 06, 04:15 AM posted to rec.aviation.piloting,rec.aviation.ifr
military field?
-Dan
The cable is suspended above the ground by rubber "donuts" to give it
enough height for a tailhook to engage it. Acft with very small tires
will feel like the aircraft "bounces" when going over the cable. The
cable could possibly bounce up slightly when you run over it and snag
any very low antennas or other protuberances on the bottom of the
aircraft, so it's best to land beyond it. Most cables used to be either
connected to large heavy anchor chains that create extra drag as the
aircraft pulls the cable down the runway, acting as brakes, or they were
connected to B-52 brake mechanisms housed in small shacks on either side
of the runway.
Those airports that have Precision Approach Radar (PAR) routinely
"monitor" aircraft flying the ILS. The only thing they do on the monitor
is get your landing clearance from the tower for you, give you an
"approaching glidepath, wheels should be down" advisory, and verify that
you don't go outside the PAR lateral safety limits or below the vertical
safety limits, since the glidepath and course are depicted on the
controllers radar scope. The safety limits of the PAR and ILS are the
same. You could also ask for a PAR approach from the same controller,
and they will provide course and glidepath advisories once every 5
seconds on final. Even better, ask for a "no-gyro" PAR approach, and the
controller will get you down to the 100 or 200 HAT (whichever is used
there) using "turn left, stop turn" or "turn right, stop turn"
directions. Expect the phrase "make half standard rate turns" once you
get on final.
From the AIM;
2-3-14. Aircraft Arresting Devices
a. Certain airports are equipped with a means of rapidly stopping
military aircraft on a runway. This equipment, normally referred to as
EMERGENCY ARRESTING GEAR, generally consists of pendant cables supported
over the runway surface by rubber "donuts." Although most devices are
located in the overrun areas, a few of these arresting systems have
cables stretched over the operational areas near the ends of a runway.
b. Arresting cables which cross over a runway require special markings
on the runway to identify the cable location. These markings consist of
10 feet diameter solid circles painted "identification yellow," 30 feet
on center, perpendicular to the runway centerline across the entire
runway width. Additional details are contained in AC 150/5220-9,
Aircraft Arresting Systems for Joint Civil/Military Airports.
NOTE-
Aircraft operations on the runway are not restricted by the installation
of aircraft arresting devices.
John
Old February 26th 06, 11:08 AM posted to rec.aviation.piloting,rec.aviation.ifr
One has to wonder why they didn't put it down for you (the fact that they
said it was up suggests it was retractable). As for what would have
happened - well, it would almost certainly have damaged your landing gear.
Incidentally, even if the arresting gear was down, you should always try not
to land before it (assuming there's plenty of runway the other side - which
there should be). I did part of my PPL training at RAF Coltishall, which has
arrester gear that sits in a little channel across the runway when it's
down. If you roll over the channel, you get a hell of a bump.
David C
Old February 26th 06, 11:11 AM posted to rec.aviation.piloting,rec.aviation.ifr
"JPH" wrote in message
news:VW9Mf.172831$WH.127355@dukeread01...
same. You could also ask for a PAR approach from the same controller, and
they will provide course and glidepath advisories once every 5 seconds on
final. Even better, ask for a "no-gyro" PAR approach, and the controller
will get you down to the 100 or 200 HAT (whichever is used there) using
"turn left, stop turn" or "turn right, stop turn" directions. Expect the
phrase "make half standard rate turns" once you get on final.
And the phrase "Do not acknowledge further transmissions".
If you've never done a "talkdown" before, have a go when it's convenient for
you and the controller. I did one as part of my IMC rating training, and
it's immense fun. The controller who did mine (at a civilian airport, so
they don't do all that many) told me he enjoyed it too, as it had good
training value for him.
D.
Old February 26th 06, 02:14 PM posted to rec.aviation.piloting,rec.aviation.ifr
The retraction mechanism could have been disabled or inoperative. When
Ellington (KEFD) was having their tower refurbished, the tower did not
have control over retractible mechanisms and relied on airport
operations personnel to manual actuate and retract the barrier as needed
(using a guy in a truck).
If a small or light plane was cleared to land just prior to or just
after military fighter type aircraft, the cable was likely to be up and
the tower would announce such to the inbound aircraft.
Dave
07 Feb 2006 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 February 7th 06 01:28 AM
30 Jan 2006 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 January 31st 06 03:21 AM
20 Nov 2005 - Today's Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 November 20th 05 09:43 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
