Why didn't the Cessna 337 make it?
Old February 27th 06, 11:51 PM posted to rec.aviation.piloting
Default Why didn't the Cessna 337 make it?
Looking at the design of the C377, it seems like it should have been more of
a winner. Why did it flop?
Dallas
Old February 27th 06, 11:56 PM posted to rec.aviation.piloting
It made a poor multi trainer for FBOs because the FAA would not issue
"full" multiengine ratings to students who took their checkrides in it.
-Robert
Old February 28th 06, 12:27 AM posted to rec.aviation.piloting
Just what did the FAA issue then?
Old February 28th 06, 12:30 AM posted to rec.aviation.piloting
"Dallas" wrote in message
k.net...
of
Dallas
My old CFI said guys would forget to start the back engine or not notice
that it would quit and end up crashing, true or not I don't know but it was
his story. I always thought it was an odd looking piece.
DW
Old February 28th 06, 12:31 AM posted to rec.aviation.piloting
A 'centerline only' thrust limitation to the ME rating.
Old February 28th 06, 12:45 AM posted to rec.aviation.piloting
A multi-engine rating limited to centerline thrust.
Old February 28th 06, 01:26 AM posted to rec.aviation.piloting
of a winner. Why did it flop?
To that I would add that I personally think the 200 hp O-360's are not
enough power for the size and weight of the aircraft.
Old February 28th 06, 01:29 AM posted to rec.aviation.piloting
We had a 337 and I flew it quite often on charter.
I don't remember any FBO's in our area using a 336 or a 337 for multi-engine
training. You could fly these airplanes with a checkout and your regular
multi-engine rating or you could qualify simply in the airplane itself with
a center-thrust rating that the FAA created just for the 336/337 series.
It was extremely stable and easy to fly and had none of the critical engine
aspects of a regular twin.
Dudley Henriques
-Robert
Old February 28th 06, 01:38 AM posted to rec.aviation.piloting
"john smith" wrote in message
more
was
Maintenance wise, we had a cracked case on one of the engines that was a bit
costly to fix :-) and you had to monitor the EGT carefully on takeoff
because the noise was so bad you couldn't pick up an engine problem during
the run, but aside from that, fun to fly!
Dudley Henriques
Old February 28th 06, 02:18 AM posted to rec.aviation.piloting
It was not a safer twin since the failure of an engine was
not as quickly detected since there was no yaw, just reduced
performance. It did not have good baggage areas and it was
noisy inside.
It was successful as a FAC aircraft in VN as the O-2
"Dudley Henriques" wrote in
message
ink.net...
should have been
| more
don't know but it
| was
piece.
O-360's are not
| Dudley Henriques
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
