GS indicator circuit-Jim Weir?
Old February 26th 06, 10:26 AM posted to rec.aviation.homebuilt
Default GS indicator circuit-Jim Weir?
This question is mainly aimed at Jim Weir, but others are more than welcome
to give their 2c.
With the aero-lectrics column in kitplanes, a GS tester has just been
completed.
My question. How hard would it be to make a GS indicator, with say LEDs
instead of lines and needles. For example, when going down the glideslide,
needles centred, you get a Green led in the centre, diverge and get yellow,
really off and get red, the universal warning. Rotary encoder with 7
segment leds for OBS. How hard would this project be? (considering the
grand scale of the test unit just completed). Obviously not for Primary
use, but as a tester for radios, and possibly a back-up unit.
Thanks.
Just a thought.
Rob
Australia.
Old February 26th 06, 02:00 PM posted to rec.aviation.homebuilt
Should be easy enough using op-amp comparators with resistors setting up
a 10 or 20 step voltage divider as a reference. For example, if the
voltage swing that drives an analog meter goes from 0 volts for the
needle at its full down position (high of GS) to 5 volts at its upper
most swing (low of GS), the comparators compare the voltage used to move
the needle and light a corresponding LED (at 2.5 volts, or half-scale,
the green LED would be lit)...Terra produced just such a radio back in
the 80s...I think it was called the Tri-Nav C...
Scott
to give their 2c.
completed.
Thanks.
Just a thought.
Rob
Australia.
Old February 26th 06, 08:02 PM posted to rec.aviation.homebuilt
I'd probably use a 9-step system. Green in the center, then orange, yellow,
blue, and red going up and down. What does the rotary encoder do?
"Scott" wrote in message
Should be easy enough using op-amp comparators with resistors setting up a
10 or 20 step voltage divider as a reference. For example, if the voltage
swing that drives an analog meter goes from 0 volts for the needle at its
full down position (high of GS) to 5 volts at its upper most swing (low of
GS), the comparators compare the voltage used to move the needle and light
a corresponding LED (at 2.5 volts, or half-scale, the green LED would be
lit)...Terra produced just such a radio back in the 80s...I think it was
Scott
welcome to give their 2c.
completed.
glideslide, needles centred, you get a Green led in the centre, diverge
and get yellow, really off and get red, the universal warning. Rotary
encoder with 7 segment leds for OBS. How hard would this project be?
(considering the grand scale of the test unit just completed). Obviously
not for Primary use, but as a tester for radios, and possibly a back-up
unit.
Thanks.
Just a thought.
Rob
Australia.
Old February 27th 06, 04:02 PM posted to rec.aviation.homebuilt
Been done... TKM MX-300 series... No longer in production... Both the
GS and the VOR needle are leds... I have one in my PA-23... Works just
fine... Takes all of 30 seconds to get used to it...
denny
Old February 28th 06, 10:37 AM posted to rec.aviation.homebuilt
The rotary encoder would be used, with some sort of position feedback to
change the obs setting if in the VOR mode, in the GS mode it does nothing.
Your thoughts on the 9 step system are exactly what I was thinking of, but
you were able to explain it clearly.
Thoughts on how it would work?
"RST Engineering" wrote in message
yellow, blue, and red going up and down. What does the rotary encoder do?
Scott
completed.
Obviously not for Primary use, but as a tester for radios, and possibly
a back-up unit.
Thanks.
Just a thought.
Rob
Australia.
Weir W-2 Gyro [email protected] Home Built 2 October 29th 05 11:12 PM
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 01:19 AM
Jim Weir and radio racks Matthew M. Jurotich Home Built 4 November 13th 03 03:51 AM
B is for Governor candidate Jim Weir Montblack Piloting 17 August 19th 03 04:35 AM
B is for Governor candidate Jim Weir Montblack Owning 9 August 13th 03 12:45 AM
