#41
![]() "Doug" wrote in message ups.com... I've always had a problem with pilots at non-towered airports self announcing "position and hold on runway so-and-so". Just as soon get rid of that one too.NOt possible to see landing traffic once you are "position and hold". And they seem to be 172 drivers that do 20 minute run ups sitting on the runway. |
#42
![]() "Judah" wrote in message . .. "Dave Stadt" wrote in et: They get special rules written specifically for the event. Planes two wide and three deep in position and hold is certainly unique, I've seen two deep at HPN, as recently as yesterday morning as a matter of fact. Two does not equal six. |
#43
"Robert M. Gary" wrote:
Its alive and well in Sacramento. However, our position and hold point is before the touchdown threshold so someone would have to land short to land on top of you. From the explanation I read, Sacramento's P&H won't be there by summer's end. -- Peter |
#44
Gary Drescher wrote:
I've never felt worried about someone landing on me while I'm holding in position at a controlled airport, but perhaps the risk is more significant than I'm aware. Have many such collisions actually occurred? I never have either. The controllers at Syracuse would always tell me of the inbound aircraft's position ("Bonanza XXX, position and hold, regional jet 5 miles out") and tell the inbound aircraft about my aircraft entering the runway for a P&H ("American Eagle XXX, cleared to land rwy 28, Bonanza going into position now, will be departing before you arrive"). In these examples it is obvious that the controller is completely on top of the work load, unlike a few of the recent incidents that led to this decision by the FAA. In the tight P&Hs (an aircraft on a three mile final) I do always think of the scenario of how all involved would handle my aborted takeoff, should it be needed. -- Peter |
#45
![]() "Gary Drescher" wrote in message . .. Hm, I bet a more effective anti-incursion strategy would be to keep using position-and-hold but require an explicit clearance to taxi across any runway. What's not explicit about it now? |
#46
All of it. It is =implicit= in the clearance to taxi to the active runway. It is explicit when it is stated, for exam "taxi to runway 32, cross runway 25 at alpha". It is =implicit= (not explicit) when the clearance is merely "taxi to runway 32", and it so happens that runway 25 is in the way. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#47
![]() "Gary Drescher" wrote in message ... A clearance to taxi to the active runway is implicitly a clearance to taxi across any other runways that are in your path. What's implicit about it? If you're cleared to taxi to runway XX and runways YY and ZZ are between you and runway XX then are you not explicitly cleared to cross runways YY and ZZ? How else could you comply with the clearance to taxi to runway XX? As AOPA has pointed out, it would be safer if you needed an explicit clearance to cross any runway, whether or not it's active. Otherwise, a pilot who's disoriented (but doesn't know it) may cross the active runway thinking it's an inactive one. How is that safer? A clearance to "taxi to" the runway assigned to the aircraft is a clearance to cross ALL other runways that intersect the taxi route to that assigned takeoff runway, active or inactive. |
#48
![]() "Ben Hallert" wrote in message ps.com... Reminds me of a flight I was on last year. I tuned to Camarillo tower to listen in even though I was a couple thousand feet above his airspace and I heard this exchange: PLANE: Camarillo Tower, Cessna 123 at runway... twenty six. TOWER: Cessna 123, say your intentions. PLANE: I'd like to take off. TOWER: Cessna 123, position and hold, runway two six. PLANE: Um, I'm at runway two six. TOWER: Roger, position and hold on runway two six. PLANE: Well, my position is runway two six, and I don't understand what you mean. TOWER: Confirm, Cessna 123, you're at runway two six and you're NOT on the runway? PLANE: Yeah, and I'm holding my position here. TOWER: (pause, teeth gnashing sounds inserted by my imagination.) Cessna 123, cleared for takeoff, runway two six. PLANE: Cleared for takeoff, Cessna 123...........and I'm departing to the right. I gotta wonder how he didn't know what 'Position and hold' meant. If he didn't have his instructor onboard, he's soloing, and if he's soloing, presumably he's learned all this stuff... right? And what if he's already a pilot? Scary stuff. A few years ago the phraseology was changed from "taxi into position and hold" to just "position and hold". A bad idea, in my opinion. Some pilots apparently confuse "position and hold" with "hold your position". Also, I was once given a P&H instruction at Santa Monica with a Hawker jet on short final. I was in a Piper Cherokee with no rear window, and I declined. Controller had me switch over to ground for a moment to tell me about how they like to sequence 'em tight on busy days, but it's my butt on the line, not his. It probably would have been fine 99 times out of 100 with the spacing, but what about that 1 time? If you're uncomfortable using procedures commonly used at controlled fields it would be best for everyone if you avoided controlled fields. P&H should be replaced by a directive to pilots to plan for an immediate departure upon receiving "clear for takeoff" instructions. Stopping on the numbers then doing a checklist is just out. By the time you're holding short, you should be ready for Lights, Camera, Action the moment the tower tells you to. If you haven't done those things already you're not ready for takeoff. |
#49
![]() "Ron Lee" wrote in message ... P&H was never a wise thing to me. If you need that at an uncontrolled field then ask someone on final to extend a few seconds. I have no desire to P&H at an uncontrolled field and taking off from the hold short area only adds a few seconds. Well worth it to ensure that I can be aware of traffic on final or very close in base. Extend on final? How do you do that? At times I've found myself in a crowded pattern with aircraft lined up for departure I've announced I was extending my downwind to allow for departures. |
#50
![]() wrote in message oups.com... In that case the only solution is unrolling a large banner: "Then get your ass out of the plane and buy one !" Right. Many pilots toady cannot "see" an airplane if it doesn't have a radio. They really ought to get rid of those grandfathering rules in the FAA; just because a plane was safe in a 1960s flight environment does not mean it's safe now without upgrades. /end rant It's just as safe now as it was in the '60s where conditions are the same now as they were then. If you want radios required at your field start a campaign for a control tower. |
