Handheld GPS adaptible to aviation
Old March 3rd 06, 05:52 PM posted to rec.aviation.piloting
Default Handheld GPS adaptible to aviation
Hi, I'm a PP-ASEL student. Although the rental planes at my club have
pretty good nav equipment, I'm hoping to supplement them with a
handheld GPS that isn't expensive.
Mostly, I'm of the "your chart isn't going to lie to you" school of
pilotage and frugality. But your chart also doesn't tell you where you
are or what direction you're headed. So, I'd like to use an
inexpensive GPS with very basic mapping capability as a supplement to
VOR navigation for VFR.
Aviation GPS's need periodic map updates. So what I'd ideally like is
rather low-end land/marine unit with a basic map (cities, highways,
shoreline, other topographic features) that has available software to
create my own waypoint database of airports and navaids to supplement
the base map.
Anyone using something like that?
BTW, I am familiar with Brian Wade's excellent database for the
Magellan 315. But that's not a mapping unit. I'm trying to do
something similar but with a low-end mapping GPS.
Thanks
Old March 3rd 06, 06:07 PM posted to rec.aviation.piloting
I think color is important, but I was just given a birthday
present, quite unexpected [the present, the b'day was
expected] of a Magellan Meridian Gold with a monochrome
display. It seems adequate and has a pretty good database
that includes airports. There is no terrain unless you buy
a detailed map database. It will work up to 951 mph and
17,500 meters.
Programming is not something I'd want to do in-flight unless
I had lots of time. I think my son bought it at Wal-Mart
for about $200. It runs 14 hours on 2 AA batteries if you
don't use the light.
I told him I wanted the Garmin 396, it's only $2500.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
my club have
with a
school of
you where you
an
supplement to
ideally like is
highways,
software to
supplement
| the base map.
for the
to do
| Thanks
Old March 3rd 06, 06:49 PM posted to rec.aviation.piloting
If you are looking for something loo cost, consider buying a PDA with a
CF slot and just running something like PocketFMS (its free). You could
also buy a $15 copy of MS streets for it for use in the car too.
-Robert
Old March 3rd 06, 07:11 PM posted to rec.aviation.piloting
Just a follow-up, the Magellan Meridian Gold does have a
GOTO button and an airport list in the database. You can
select from airports nearest to your position with just a
few button pushes. I think most hand-helds will do this,
try them out to see what they'll do and how you like them.
They also have car power cigarette plugs available so you
can work as long as you need to and keep the batteries full.
But unless you buy an aviation unit, you won't have MOA, TFR
and other "bad" places, so you'll need to have that current
sectional and FSS brief data to stay out of the F-16
gunsights.
I think both Magellan and Garmin have downloadable SDK
programming instructions, you might be able to create the
NAVAID database, airports are included in the basic LAND map
on the units.
"peter" wrote in message
ideally like is
(cities, highways,
to supplement
| the base map.
| The Garmin eTrex Legend is a small handheld that includes
a reasonable
| basemap (roughly the level of detail as state highway
maps) and has a
| PC interface cable for use with a wide variety of
available software,
| much of it free. It'll let you load in up to 1000
waypoints at a time.
| Retails for around $140.
Old March 3rd 06, 07:37 PM posted to rec.aviation.piloting
I agree to that. In dense airspace with lots of traffic,
military and civilian, Class B and C and TFRs, use all you
can that is helpful, but a cobbled together land unit will
just be a distraction and a toy.
A good sectional and pre-flight planning an proper pilotage
will keep you out of trouble. Besides, sigh seeing is the
reason for flying, isn't it?
James H. Macklin
ATP,CFI,A&P
some support
"Stubby" wrote in
message ...
| As a student you need to concentrate on your own
navigation and flying
| skills using the standard instruments. After you are out
on your own
| with a PPL, you can begin to use a GPS.
at my club have
with a
you" school of
tell you where you
use an
supplement to
ideally like is
(cities, highways,
to supplement
| the base map.
for the
trying to do
| Thanks
Old March 3rd 06, 10:09 PM posted to rec.aviation.piloting
I second the recommendation for PocketPC and PocketFMS. Inexpensive,
lots of options and in color. However, there is no guarantee for
currency of charts and reliability, so it is meant as a backup unit
only.
Old March 4th 06, 02:45 AM posted to rec.aviation.piloting
Everything except the windows and a chart is just an aid to
navigation.
James H. Macklin
ATP,CFI,A&P
some support
on your own
| Right on, Stubby. Reminds me of a PPL student I had years
ago when I
| was actively instructing - he'd gotten a Garmin handheld
from his wife
| as a gift when he started taking lessons. The very first
time we got
| into the plane I saw him pull it out and start to set it
up, and when I
| asked what he was doing his answer was "I figured we'd
need this to
| navigate". To which I responded that he'd need to learn to
fly the
| plane first before navigating became an issue. After that
the GPS
| stayed in his flight bag. Gotta get the basics down first,
(pilotage
| being one of them) as I doubt DEs would even allow a GPS
to be used on
| a PPL checkride. And, like Jim said, it's just another
distraction if
| you're fidgeting with it too much.
Old March 4th 06, 03:01 AM posted to rec.aviation.piloting
the base map.
Take a look at EasyGPS.com - it will tell you what GPSes will accept a
load of data from a GPX format file. Then you can generate GPX format
files from my web site,
http://navaid.com/GPX/ - I update the data on that
site every 28 days from DAFIF data and every 56 days from FAA data.
Paul Tomblin http://xcski.com/blogs/pt/
"If something's expensive to develop, and somebody's not going to get paid, it
won't get developed. So you decide: Do you want software to be written, or
not?" - Bill Gates doesn't foresee the FSF or Linux, 1980.
STS AV7600 VOR Handheld aviation transceiver Fastglasair Home Built 1 May 29th 04 12:16 AM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Home Built 3 May 14th 04 11:55 AM
General Aviation Legal Defense Fund Dr. Guenther Eichhorn Aerobatics 0 May 11th 04 10:43 PM
Associate Publisher Wanted - Aviation & Business Journals Mergatroide Aviation Marketplace 1 January 13th 04 08:26 PM
