The Impossibility of Flying Heavy Aircraft Without Training
Old March 3rd 06, 01:41 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Default The Impossibility of Flying Heavy Aircraft Without Training
In article .com, george
says...
Isn't a Bernouli what an Arab wears?
under his theorum :-)
Is that near his axiom?
Sorry I couldn't help myself.
Chuck S
  #242
Old March 3rd 06, 03:15 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Default lift, wings, and Bernuolli
Suppose we have a 1500 lb airplane in level flight at 120 mph.
What are its horizontal and vertical components of momentum?
Suppose we have a 1500 lb rocketship hovering over the moon on its
rocket exhaust. What are its horizontal and vertical componnts of momentum?
Jose
Money: what you need when you run out of brains.
  #243
Old March 3rd 06, 04:00 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
I asked first.
FF
  #244
Old March 3rd 06, 05:49 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Zero at equalibrium.
Again, zero.
I asked first.
Same answer, different criteria. Net energy for a given mass will be
the same whether the craft is flying, rocketing, or in orbit.
F=MA
But, only in the instance of 'flying' does Bernuolli apply.
  #245
Old March 3rd 06, 05:56 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Incorrect. It has considerable horizontal momentum and no vertical
momentum.
momentum?
Again, zero.
Correct, but how can you possibly get zero for this answer and think
that an aircraft moving horizontally at 120 mph has no horizontal
momentum...
snip
Alan Baker
Vancouver, British Columbia
"If you raise the ceiling 4 feet, move the fireplace from that wall
to that wall, you'll still only get the full stereophonic effect
if you sit in the bottom of that cupboard."
  #246
Old March 3rd 06, 06:38 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
momentum.
I thought the focus was forces.
The 'aircraft' with respect to the media, air.
If the ground is at play with respect to horizontal 'componet'
is it in the form of 'gravity' (a force) or geologial energy
of some sort expressed as the force of location?
This is hightly interesting. Never thought of it before.
  #247
Old March 3rd 06, 06:55 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
momentum.
Whereas for the hovering spacecraft both components are zero.
It should be.
The hovering spacecraft has zero horizontal and vertical momentum.
It has weight, directed downwards. The engine accelerates
mass downward producing an upward force equal in magnitude
and opposite in direction to the weight of the spacecraft. This
imparts an acceleration to the spacecraft equal in magnitude and
opposite in direction from the local acceleration due to gravity.
Now of course weight is a convenient fiction. There is really no such
thing as gravitational force, what we model as a force acting at a
distance is in reality the distortion of spacetime in the presence of
mass. Perhaps other forces are similarly ficticious.
But how sure can we be that mass and velocity are any less ficticious
than force?
FF
  #248
Old March 3rd 06, 07:23 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Can I allocate excess fat that same definition?
I hope not the Air Force.
So you want to bring general and special relativity into
the frey `eh? Newton ain't good enough for you, huh? Ok.
Gimme your Lorentz transformations for -Mach 1 to +Mach 1
at the transition point. I wanna see how time and gravity
are related to mass transactions. The speed of sound must
be a nodal harmonic of the speed of light. I wanna see it
too. Gimme gimme...
than force?
Gravity seems to work to it's own advantage so it's the
ultimate taxing authority in the universe. That really sucks.
  #249
Old March 3rd 06, 08:29 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Air resistance is fricticious
I thought resistance was useless.
At least for Dent and Ford.
  #250
Old March 3rd 06, 09:21 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
On Fri, 03 Mar 2006 01:27:46 +0000, David CL Francis wrote:
Above
Mach one the air does not detect the approaching aircraft! :-)
If it did, what would happen?
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Sport Pilot pilots not insurable? Blueskies Piloting 14 July 12th 05 05:45 AM
