The Impossibility of Flying Heavy Aircraft Without Training
Old March 7th 06, 12:50 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Default lift, wings, and Bernuolli
On Fri, 3 Mar 2006 at 05:30:06 in message
.com,
Newton had three laws of motion, you're ignoring the first.
Is there a net change inmomentum of the fan? If not,
how can there be a net change of momentum of the air?
I am ignoring nothing. The above statement is wrong. You agree below
that energy is put into the air. In the case of a fan that energy goes
into increasing the velocity of the air. The rate of change of momentum
(mass flow times velocity increase) produces forces that increase the
momentum of the air. Energy changes momentum. Momentum destroyed turns
back into energy.
This argument is hung up on the idea that the air returns to a steady
state eventually - which it does! But not quite back to where it was
because of losses Nevertheless energy is lost and replaced by the
engines of the aircraft.
There no question that energy is put into the air. There is
no net change in momentum, of the air. otherwise all the
air would pile up on one side of the fan and there would
be a vacuum on the inlet side. Air moving through the
fan in one direction is offset by air moving around the fan
in the other direction.
The air slows down and looses energy and momentum far away from the
aircraft - so what? Any small drop in pressure at the fan also reaches
back and develops flow some way in front of the fan. For lift purposes
it does not matter much. The air may or may not make its way back to the
inlet again, some of it will.
In open air the volume of air moving around the fan is larger,
but moving at a lower speed than the air moving through the
fan so that the momenta of the flow in either direction is equal
magnitude and opposite in direction to the flow in the other
direction.
Except for losses that occur due to friction and eddies that float away
to dissipate themselves elsewhere. But the answer must be still be so
what? Momentum is not conserved because energy has been added. Are you
saying that a land vehicle with a horizontal fan to drive it along rails
will not accelerate and move? Will the vehicle not build up momentum
because of this?
David CL Francis
  #334
Old March 7th 06, 12:50 AM posted to rec.aviation.piloting,rec.aviation.student
On Sat, 4 Mar 2006 at 05:38:33 in message
.com,
A more efficient wing will produce less downwash than a less efficient
one, for the same lift.
Yes but it still has to provide the exact same amount of rate of change
of momentum. It tends to move a bigger mass of air slower but at the
same momentum change.
David CL Francis
  #335
Old March 7th 06, 01:56 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Alan Baker wrote:
In article .com,
Well then if the downflow is NOT balanced by upflow why doesn't
the upper atmosphere run out of air?
Because the air contacts the earth and *stops* moving downward.
Could you define downflow?
FF
  #336
Old March 7th 06, 02:15 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
David CL Francis wrote:
On Fri, 3 Mar 2006 at 02:27:02 in message
. net, Richard Lamb
I hate to be a spoil sport (or dullard?), but...
the (stationary) air does WHAT (as the wing passes by)???
The nature of things is such that the situation does not change if you
change the frame of reference. It is normal in doing calculations to
start with a frame of reference based on the aircraft. If you follow the
aircraft then the air is going past it.
The presence of the wing changes the air flowing past the aircraft in
the same way as if you consider the aircraft passing through the air.
The 'stationary' air as you call it has its local velocity and direction
changed by the aircraft.
Yeahbut...
A handy frame of reference is - handy.
But it can be very misleading.....
  #337
Old March 7th 06, 03:58 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
. net, Richard Lamb
the aircraft then the air is going past it.
direction changed by the aircraft.
Yeahbut...
For instance?
If the air is moving, we expect a lower pressure. Nod to Bernoulli.
But the air would also be moving along the bottom side of the wing also?
And what would that do to the pressure under the wing?
And if the pressure under the wing is below ambient....
  #338
Old March 7th 06, 05:06 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.student
Momentum is not conserved because energy has been added. Are you saying that a land vehicle with a horizontal fan to drive it along rails will not accelerate and move? Will the vehicle not build up momentum because of this?
Momentum is always conserved. If you see momentum disappearing, you are
not looking at the whole system. In the case of the land vehicle
propelled by a fan, the air blown back acquires momentum in one
direction, exactly balanced by the momentum that the vehicle acquires,
plus the (rotational) momentum (due to wheel friction) that the earth
acquires.
Jose
Money: what you need when you run out of brains.
GAO: Electronic Warfa Comprehensive Strategy Needed for Suppressing Enemy Mike Naval Aviation 0 December 27th 05 06:23 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
