paint
Old March 5th 06, 09:00 PM posted to rec.aviation.soaring
Default paint
Hi,
Fenders on Cobra trailer fade after a couple of years. Anyone ever
painted them?
What paint did you use? Can it be done with a paint brush?
Regards,
S6
Old March 5th 06, 10:36 PM posted to rec.aviation.soaring
Default paint
Normal procedure is to wait until the tire
blows out and takes out the fender, at
which point you get new tires and
fenders ;-)
PS: Don't ask how I know.
PPS: M&H and Murray stock fenders.
Old March 6th 06, 09:19 AM posted to rec.aviation.soaring
Default paint
Go down to your local RV trailer supply and buy 2 steel fenders. Take
one useable fender with you to size it. Then pre drill your mounting
holes. Find a powder coat shop and powder coat them. Mount em up and
now you've got a fender that is stronger than the old plastic one that
won't shater when you have a tire go to pieces on you and the powder
coat won't fade.
Old March 6th 06, 01:36 PM posted to rec.aviation.soaring
Default paint
Second the nomination for steel fenders. I replaced the plastics on my
old Komet with steel. In short order I then a) hit a deer carcass
doing around 40 mph and b) had a tire disintegrate doing around 70mph.
Aside from some cosmetic damage (one red stripe, one black stripe),
the fenders came through unscathed. Plastics would've been reduced to
shrapnel.
The mounting holes can be a pain if the radius of the new fenders isn't
precisely the same as the old; it's hard to use the existing fender as
a template. I ended up welding some additional material to the fender
to create a wider mounting flange; cheap and easy.
Erik Mann
LS8-18 (P3)
Old March 6th 06, 06:13 PM posted to rec.aviation.soaring
Default paint
Forget "The Graduate": the future is not plastics when it comes to
trailer fenders.
Make offer on a right side blue Cobra fender: ca. 1992, only used one
season before the other one was destroyed by a piece of tire retread
flipping up into it.
I bought two galvanized steel fenders from Northern Tool (then called
Northern Hydraulics) that have held up well. IIRC, I was able to make
two of the four mounting holes work as is. And since the steel fender
was slight bigger than the plastic one, I drilled two new holes in the
trailer and put a piece of plastic tape over each hole in the
[wheelwell of the] trailer, which has lasted 13 years.
I just took a look at Northern Tool's Web site. They no longer show the
galvanized fenders but have a large assortment of steel, aluminum and
plastic fenders for sale in many sizes. I suspect shipping is expensive
so in the U.S., shop your local trailer supplier, or maybe Sears.
Chip Bearden
ASW 24 "JB"
Old March 7th 06, 05:51 AM posted to rec.aviation.soaring
Default paint
Oh yeah I forgot to say you can sit on the steel fenders too. If
you're not too fat and you buy the heavy gage steel.
Old March 7th 06, 02:48 PM posted to rec.aviation.soaring
Default paint
Thank you all for your reply.
My fender are perfectly correct. I do not repair what is not broken.
Any suggestion about which paint to use on plastic, applicable with a
paint brush.
Regards,
S6
Old March 7th 06, 03:49 PM posted to rec.aviation.soaring
Default paint
If you paint the fenders with a paint brush . . . they'll *look* like
they've been painted with a paint brush.
Suggest instead you stroll down to Home Depot, or similar hardware store,
and purchase a rattle can (spray can) of paint intended for plastic - -
think it's marked for use on vinyl, but suitable for other plastics too.
It'll give you a much nicer finish than you'll likely achieve with a brush.
all the best,
bumper
paint brush.
Regards,
S6
Old March 7th 06, 06:32 PM posted to rec.aviation.soaring
Default paint
He must be a fat guy.
Old March 7th 06, 09:22 PM posted to rec.aviation.soaring
Default paint
Voilą!
Thank you Bob K.
S6
Update on new paint job and leather seats - Trip back home Longworth Piloting 6 November 21st 05 06:52 PM
Trailer paint removal Chris Davison Soaring 13 September 3rd 04 10:42 PM
Good Paint Remover? Marco Leon Owning 2 June 22nd 04 07:58 PM
Radar Absorbing Paint robert arndt Military Aviation 2 December 2nd 03 05:09 PM
Choice of Paint for use over Copper foil Antennas Charlie Precourt Home Built 1 December 2nd 03 02:51 AM
