Looking for an affordable 4-passenger aircraft
Old March 7th 06, 11:38 PM
Tailhook Tailhook is offline
Junior Member
First recorded activity by AviationBanter: Mar 2006
Default Looking for an affordable 4-passenger aircraft
I'm an retired Navy pilot with lots of time (6000)--but nothing in the past 15 years--but my children are now moving all over the country and I'd like to get back into the air to visit them. I know little about the general aviation market or products but I'm partial to twin engines if only because they gives you an option when the weather deteriorates and so does one engine. I'm looking for the following:
reliable and affordable--under $200K
4-passenger capability (real passengers--none of my kids are under 6')
twin preferred--or logic why a single engine is not really an emergency
range: 1000 NM
speed: 160 KIAS +
pressurized cabin (a preference but not a requirement)
reasonable IFR package--but state of the art not needed
Some idea of annual maintenance costs I need to be planning on
What aircraft would you recommend I be looking into?
Thanks from general aviation rookie with less than 50 hours of Cesnna 150 time from the 1960s.
Old March 8th 06, 05:50 AM posted to rec.aviation.owning
("Tailhook" wrote)
[I didn't know what to snip g]
Here's one for around $400K .....partnership? :-)
http://www.diamond-air.at/en/products/DA42/index.htm
http://www.diamondair.com/aircraft.php?PHPSESSID=671daa05c9d24f23f9b4e6c87f6 12754
Diamond DA-42 Twin Star
Diesel.
Amazing plane. Not sure if the diesel version is available, yet, in the US -
this summer probably.
Don't buy the non-diesel option. Wait for the diesel.
80% Power
Range: .....917 NM
Time:...........5.3 hrs
Speed: ......172 kts
Gal/hr: ........12.5 total
60% Power
Range: ...1,129 NM
Time:.........7.48 hrs
Speed: ......151 kts
Gal/hr: ........8.8 total
Montblack
Old March 8th 06, 06:05 AM posted to rec.aviation.owning
Without reading the other responses.. Piper Seneca II Turbo
most can be had with average radios for about $150K
What was your Navy Twin time in, and hopefully NOT centerline thrust.
BT
"Tailhook" wrote in message
emergency
range: 1000 NM
speed: 160 KIAS +
Tailhook
Old March 8th 06, 06:08 AM posted to rec.aviation.owning
Well it won't go quite that fast, and it's not pressurized, it's a
single, but it will carry 4 and it will go anywhere reliably, a Cessna
182 (or 182RG if you want the extra speed). Standard issue all american
airplane. Hard to beat. $100-$150 per hour.
In the Piper line, a Cherokee 235 Pathfinder or Cherokee 236 are the
ones. $100-150 per hour.
If you REALLY have to have pressurized and that sort of range, you are
above your budget because neither a Cessna 210P or a Piper Malibu have
that kind of range, though they come close (both are pressurized).
$150-200 per hour
Something like a Beech Baron 58P will do what you want, but believe me
it will COST to buy and COST to run. But it's pressuriized, a twin and
plenty fast. With long range tanks it might go 1000 NM, I dunno. If you
have the bucks, its the one to have. $200-250 per hour.
(The per hour figures are based on 200 hours a year and are rough
estimates).
Old March 8th 06, 03:40 PM posted to rec.aviation.owning
On Tue, 7 Mar 2006 22:38:10 +0000, Tailhook
emergency
range: 1000 NM
speed: 160 KIAS +
Check out risingup.com. It has a performance database of nearly all
production GA planes. You can search for aircraft types based upon
performance parameters.
Then use aso.com or controller.com to get an idea of the aircraft
price range.
The 1000nm range is going to eliminate a lot of aircraft. Also, that
is a really long time to stay aloft if you are flying at 160kts.
As you get into your search, remember that the purchase price only
scratches the surface on aircraft expenses. Insurance + hangar fees +
maintenance + fuel & oil costs can be quite large, particularly on a
larger engined twin. I would budget at least $20k / year to fly a
Baron or similar twin (not including acquisition or loan costs).
-Nathan
Old March 8th 06, 05:33 PM posted to rec.aviation.owning
Not doubting that you need this, but I think many buyers overestimate the need
for weight capacity, unless they have some experience in the GA environment and
know what their mission profile is. Many people find they make many trips by
themselves or with a single passenger. Just think critically about this
requirement, is all I'm saying.
emergency
Look around on avweb.com and aopa.org and other places for statistics on
relative accident rates twins vs. singles. You might decide the difference is
not worth the huge bump in operating costs. There are times and places, of
course, where a twin has an obvious safety advantage.
range: 1000 NM
I think it will open up the range of options consdirably if you are willing to
make two 500 nm hops.
speed: 160 KIAS +
Given pressurized, I think any pressurized aircraft will meet the speed
requirement handily. As soon as you say 'pressurized', you are going way up the
scale toward the high-end, at least from my lowly point of view.
$100-$200/hr overall operating costs (incl fuel) for a typical piston single,
probably toward the higher end since you have a large weight capacity
requirement, which drives you toward larger airplanes and bigger engines.
There's a lot of variability in operating costs from individual to individual,
and airplane to airplane, and year to year. Hard to predict. You need a flexible
budget. Multi-hundred dollar surprises are common, and multi-thousand dollar
surprises are not uncommon.
The above is for non-pressurized, pressurized is going to bump that even higher.
Don't have any experience with twins, but it will be still more, of course.
Good luck with your search, and keep us in the loop!
Dave
Old March 8th 06, 07:36 PM posted to rec.aviation.owning
Anytime you are talking about pressurized aircraft - and
multi engine you are talking more than $200K.
According to your performce requirements a Kingar 90 would
fit the bill but I don't think you can find one for $200k.
I wouldn't rule out single engine airplanes, there are
many that could meet your mission for a lot less cost than
a twin.
Old March 8th 06, 07:52 PM posted to rec.aviation.owning
Take a look at the Cessna 340 and the Cessna 400 series, particular
the 414 and 421. These will be above your $200K range, but are
fast, pressurized twins. Also, understand the wing spar AD on the 400
series Cessnas before buying one.
If you eliminate the pressurization requirement, look at the Cessna 310,
Beech Barons (55 and 58 models) and the Piper Aztec. Of the bunch, the
Aztec is the slowest, but also the cheapest to buy. You can find a really
nice Aztec for well under $200K.
Moving a bit more into the rarer category, the Twin Aerocommander and
Piper Aerostar are possibilities.
I'd also reccommend either getting a copy of the Aviation Consumer's
Used Aircraft Buyer's Guide, or subscribing to the montly Aviation
Consumer publication which includes access to their web site. Then you
can access the used aircraft articles online.
http://www.aviationconsumer.com/
Another good publication to get a subscription to is Trade-A-Plane, the
bible for the GA aircraft market. Again, subscribing to the print copy
gets you online access to their database which is a good place to shop
and get a feel for the market.
http://www.trade-a-plane.com/index.shtml
Good luck.
Ronnie
emergency
range: 1000 NM
speed: 160 KIAS +
Tailhook
Old March 8th 06, 08:11 PM posted to rec.aviation.owning
A pressurized twin is out of your price range. So is 160 KIAS at
cruising altitude. 1000 nm range will be iffy.
Assuming you really meant 160 KTAS at crusising altitude, the options
open up.
Starting bottom up in terms of operating cost, think Twin Comanche with
extended range tanks (tips or nacelle) and a Robertson kit. Typically
1400-1500 lbs useful load, about 100 gallons usable fuel (84 is
standard), and 160 KTAS at 7000-11000 ft on 15-16 gph total. Total
operating cost will be about $25K/year, all up (maintenance, fuel,
insurance, hangar, etc) and you can get a good one for $120K.
If you really need more load carrying, think Baron or C-310. Operating
cost goes up by 40% or so, payload goes up about the same, speed might
go up a few knots.
Michael
Old March 10th 06, 12:25 AM
Junior Member
BTIZ
The only centerline thrust time I had was back in flight school. After that it was all 2 & 4 engine--Carrier On Board Delivery (COD) C-1 (twin R1820 radials) & C-2 (twin T-56 truboprop) during Vietnam, P-3 oceanographic research and hurricane hunters for 4 more years (4-T56-turbos), and 13 more years of carrier E-2 (more T-56's--4000+ hours in 3 versions of Hawkeyes).
Thanks for the tips. At least your pointing me along a valid path for getting back into this. I may end up having to go to some kind of partnership but I'm just getting serious on the search. I do appreciate the help.
Tailhook
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 04:04 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
