#31
Changing a tire on an airplane requires removal of the brake
assembly, perhaps splitting the wheel halves and installing the new tire on the old wheel and properly torquring the wheel bolts. Then the wheel must be installed after packing the cleaned and inspected wheel bearing. Changing a tire on an airplane is more like changing the front hub on a car. The FAA assumes that all work allowed under the term, "preventative maintenance" by a private pilot will be done using the tools, techniques and procedures as a licensed A&P would use. On my car, I can do just as most oil change shops do, get under the vehicle, remove the drain plug, remove the old oil filter, reinstall the drain plug, install a new oil filter, then pour 4 or 5 quarts of oil in the engine. An aircraft oil change requires the additional steps of cleaning oil screens and inspecting for metal and cutting the old oil filter open and examining the paper for metal. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Matt Barrow" wrote in message ... | | "Jim Macklin" wrote in message | news:JktPf.116461$QW2.88175@dukeread08... | The FAA lawyers make the rules. For instance, a brand new | private pilot may change a tire, but cannot work on the | brakes on the same wheel. | | My wife and daughter can change a tire on the car, but neither of them could | do a brake job on those cars. | | | | |
#32
Robert M. Gary wrote:
(be ready to answer the output of the alternator in amps and the capacity of the battery) How do DEs know details like this for each aircraft? Are they truly that experienced, or do they grab the POH (or equivalent) first? I'm especially curious with respect to our older aircraft in the fleet, many of which have nontrivial customizations since production. - Andrew |
#33
If you are not interested in an instructor certificate, I can't think
of any reason why you would want to get a commercial. You can only do a few things, like sight seeing flights, pipeline patrol, banner towing (not sure if that is still legal after 9-11). All of these are pretty meaningless for a person who is gainfully employed elsewhere. However, the commercial training is a lot of fun. Paul Tomblin wrote: So I've got my instrument rating, complex endorsement and 450 hours PIC. So I've starting thinking about the commercial rating. But I've got some questions: - I understand there isn't much airwork involved and that it's mostly about knowing aircraft systems. Is that correct? - The requirements state I have to have made a 300nm solo flight. Does a flight with a non-pilot count, or do I really have to have been alone? - What can I do with it? Can I offer to fly people somewhere for money? If I want to take pictures from the air to sell, do I need a commercial rating? - How different is the second class medical from the third? - If I add on a seaplane rating later, will it automatically be commercial or is there a separate checkride for seaplane commercial? - Is adding a commercial rating one of the things that non-citizens need Homeland Security/TSA approval for? -- Paul Tomblin http://xcski.com/blogs/pt/ Reliability went through the floor, tunnelled its way to the centre of the Earth, and perished in the magma. -- Saundo |
#34
![]() "Andrew Sarangan" wrote in message oups.com... If you are not interested in an instructor certificate, I can't think of any reason why you would want to get a commercial. You can only do a few things, like sight seeing flights, pipeline patrol, banner towing (not sure if that is still legal after 9-11). All of these are pretty meaningless for a person who is gainfully employed elsewhere. Having a 61.75 Private certificate and the hours and experience requirements for the commercial it seemed to make more sense to do the commercial and get that in my own right than spend the same money and get the private. Chris |
#35
![]() "Jim Macklin" wrote in message news:wLDPf.116565$QW2.26150@dukeread08... Changing a tire on an airplane requires removal of the brake assembly, perhaps splitting the wheel halves and installing the new tire on the old wheel and properly torquring the wheel bolts. Then the wheel must be installed after packing the cleaned and inspected wheel bearing. Changing a tire on an airplane is more like changing the front hub on a car. Okay...now describe the steps and skills involved in doing a brake job. "Matt Barrow" wrote in message ... | | "Jim Macklin" wrote in message | news:JktPf.116461$QW2.88175@dukeread08... | The FAA lawyers make the rules. For instance, a brand new | private pilot may change a tire, but cannot work on the | brakes on the same wheel. | | My wife and daughter can change a tire on the car, but neither of them could | do a brake job on those cars. | | | | |
#36
... "Jim Macklin" wrote in message news:wLDPf.116565$QW2.26150@dukeread08... [...] Changing a tire on an airplane is more like changing the front hub on a car. Okay...now describe the steps and skills involved in doing a brake job. Why should he? The point is not how complex the task is. It's whether it's allowed under FAR 43.17(c). Tires changes are. Brake work is not. Now, that said...a tire change is only permitted "provided it does not involve complex assembly operations". Jim's description of a tire change is accurate for many aircraft, but such a tire change may be precluded by the prohibition against "complex assembly operations". It depends on how the FAA (i.e. your local inspector) interprets the word "complex". Jim certainly makes the process *sound* "complex". ![]() I've never heard of a pilot being cited for replacing a tire, but there's certainly room for equivocation in the regulation. Pete |
#37
On a car or an airplane? Drum brakes, expansion tubes,
mechanical, floating disk (Goodyear) or floating caliper (Cleveland), multi-disk (King Air or jets)? You must be specific. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Matt Barrow" wrote in message ... | | "Jim Macklin" wrote in message | news:wLDPf.116565$QW2.26150@dukeread08... | Changing a tire on an airplane requires removal of the brake | assembly, perhaps splitting the wheel halves and installing | the new tire on the old wheel and properly torquring the | wheel bolts. Then the wheel must be installed after packing | the cleaned and inspected wheel bearing. | | Changing a tire on an airplane is more like changing the | front hub on a car. | | Okay...now describe the steps and skills involved in doing a brake job. | | "Matt Barrow" wrote in message | ... | | | | "Jim Macklin" wrote | in message | | news:JktPf.116461$QW2.88175@dukeread08... | | The FAA lawyers make the rules. For instance, a brand | new | | private pilot may change a tire, but cannot work on the | | brakes on the same wheel. | | | | My wife and daughter can change a tire on the car, but | neither of them could | | do a brake job on those cars. | | | | | | | | | | | | |
#38
I really wanted to point out the need for following the
rules, procedures and techniques for any preventative maintenance. It takes 2,000 hours of training in the classroom and shop to qualify for an FAA A&P and that is really just an entry level. A private pilot requires 40 hours in the airplane flying and the other training generally just introduces such terms as "magneto, piston, safety wire." Each airplane is different and each person doing maintenance on that airplane is required to follow the manufacturer's manuals. So to do a "tire change" or replace a battery, you need to have the manual and any supplementary manuals, the tools and follow the procedures. Bottom-line, a pilot who wants to work on "his" airplane needs instruction. There are training classes available. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Peter Duniho" wrote in message ... | "Matt Barrow" wrote in message | ... | | "Jim Macklin" wrote in message | news:wLDPf.116565$QW2.26150@dukeread08... | [...] | Changing a tire on an airplane is more like changing the | front hub on a car. | | Okay...now describe the steps and skills involved in doing a brake job. | | Why should he? | | The point is not how complex the task is. It's whether it's allowed under | FAR 43.17(c). Tires changes are. Brake work is not. | | Now, that said...a tire change is only permitted "provided it does not | involve complex assembly operations". Jim's description of a tire change is | accurate for many aircraft, but such a tire change may be precluded by the | prohibition against "complex assembly operations". It depends on how the | FAA (i.e. your local inspector) interprets the word "complex". | | Jim certainly makes the process *sound* "complex". ![]() | | I've never heard of a pilot being cited for replacing a tire, but there's | certainly room for equivocation in the regulation. | | Pete | | |
#39
On Thu, 9 Mar 2006 14:25:39 -0600, "Jim Macklin"
wrote in 1c0Qf.116696$QW2.86247@dukeread08:: Bottom-line, a pilot who wants to work on "his" airplane needs instruction. Actually, he can do it without instruction if it is done under the supervision of the holder of an A&P certificate. |
#40
Any A&P who is supervising a pilot working on an airplane
without providing instruction, advice and tools is not doing the job. That A&P should have the manuals and provide them to the pilot, will watch the pilot as he does the work and inspect the work as it is done and before it is signed off for return to service. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Larry Dighera" wrote in message ... | On Thu, 9 Mar 2006 14:25:39 -0600, "Jim Macklin" | wrote in | 1c0Qf.116696$QW2.86247@dukeread08:: | | Bottom-line, a pilot who wants to work on "his" airplane | needs instruction. | | Actually, he can do it without instruction if it is done under the | supervision of the holder of an A&P certificate. | |
Commercial rating: complex aircraft required aircraft for practical test? | Marc J. Zeitlin | Piloting | 22 | November 24th 05 04:11 AM |
Commercial rating: Am I wrong here? | gatt | Piloting | 12 | November 21st 05 12:35 AM |
Skip the IR rating and go straight to commercial and CFI? | [email protected] | Piloting | 17 | May 20th 05 02:50 AM |
rotorcraft commercial rating or better rating advice | Rick Cook | Rotorcraft | 0 | October 13th 03 04:49 PM |
