#41
Chris wrote:
Having a 61.75 Private certificate and the hours and experience requirements for the commercial it seemed to make more sense to do the commercial and get that in my own right than spend the same money and get the private. absolutely; I did it initially for this very reason, makes sense. --Sylvain |
#42
"Larry Dighera" wrote in message
... Bottom-line, a pilot who wants to work on "his" airplane needs instruction. Actually, he can do it without instruction if it is done under the supervision of the holder of an A&P certificate. Actually, within the limits of the "preventative maintenance" rules, he need not do it under the supervision of the holder of an A&P certificate, nor does he need any sort of formal instruction. I believe that what Jim was trying to say is that some sort of instruction is important, not that it's legally required. Based on his clarification in response to my post, I think he's talking about the practical and safety-related side of the question, not the regulatory side. Pete |
#43
Even a licensed A&P needs instruction. The FAA position is
that formal training and currency are required for an A&P. If you have not previously done a certain ordinary task, you must be supervised the first time you do it. Then if you have not done any work for a period of time, you must gain currency. § 65.81 General privileges and limitations. (a) A certificated mechanic may perform or supervise the maintenance, preventive maintenance or alteration of an aircraft or appliance, or a part thereof, for which he is rated (but excluding major repairs to, and major alterations of, propellers, and any repair to, or alteration of, instruments), and may perform additional duties in accordance with §§65.85, 65.87, and 65.95. However, he may not supervise the maintenance, preventive maintenance, or alteration of, or approve and return to service, any aircraft or appliance, or part thereof, for which he is rated unless he has satisfactorily performed the work concerned at an earlier date. If he has not so performed that work at an earlier date, he may show his ability to do it by performing it to the satisfaction of the Administrator or under the direct supervision of a certificated and appropriately rated mechanic, or a certificated repairman, who has had previous experience in the specific operation concerned. (b) A certificated mechanic may not exercise the privileges of his certificate and rating unless he understands the current instructions of the manufacturer, and the maintenance manuals, for the specific operation concerned. [Doc. No. 1179, 27 FR 7973, Aug. 10, 1962, as amended by Amdt. 65-2, 29 FR 5451, Apr. 23, 1964; Amdt. 65-26, 45 FR 46737, July 10, 1980] -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. § 65.83 Recent experience requirements. A certificated mechanic may not exercise the privileges of his certificate and rating unless, within the preceding 24 months- (a) The Administrator has found that he is able to do that work; or (b) He has, for at least 6 months- (1) Served as a mechanic under his certificate and rating; (2) Technically supervised other mechanics; (3) Supervised, in an executive capacity, the maintenance or alteration of aircraft; or (4) Been engaged in any combination of paragraph (b) (1), (2), or (3) of this section. "Peter Duniho" wrote in message ... | "Larry Dighera" wrote in message | ... | Bottom-line, a pilot who wants to work on "his" airplane | needs instruction. | | Actually, he can do it without instruction if it is done under the | supervision of the holder of an A&P certificate. | | Actually, within the limits of the "preventative maintenance" rules, he need | not do it under the supervision of the holder of an A&P certificate, nor | does he need any sort of formal instruction. | | I believe that what Jim was trying to say is that some sort of instruction | is important, not that it's legally required. Based on his clarification in | response to my post, I think he's talking about the practical and | safety-related side of the question, not the regulatory side. | | Pete | | |
#44
"Jim Macklin" wrote in message
news:gl3Qf.116727$QW2.106797@dukeread08... Even a licensed A&P needs instruction. The FAA position is that formal training and currency are required for an A&P. It's unclear, once again, whether you are speaking of the regulatory sense or the practical sense. In the regulatory sense, you mean to write "only a licensed A&P needs instruction". I'm not aware of any regulation that requires a certificated pilot to undergo instruction prior to performing preventative maintenance. Obviously, in the practical sense, one should obtain instruction for any but the most trivial of tasks (I'd consider changing a light bulb pretty trivial in most cases, but changing the oil and a filter not in most cases, for example), whether one is a certificated mechanic or not. But the regulations only require it for the certificated mechanic (oddly enough). Pete |
Commercial rating: complex aircraft required aircraft for practical test? | Marc J. Zeitlin | Piloting | 22 | November 24th 05 04:11 AM |
Commercial rating: Am I wrong here? | gatt | Piloting | 12 | November 21st 05 12:35 AM |
Skip the IR rating and go straight to commercial and CFI? | [email protected] | Piloting | 17 | May 20th 05 02:50 AM |
rotorcraft commercial rating or better rating advice | Rick Cook | Rotorcraft | 0 | October 13th 03 04:49 PM |
