Can anyone ID this engine?
Old March 11th 06, 07:57 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default Can anyone ID this engine?
("Flyingmonk" wrote)
From a down aircraft in Cambodia?
http://i2.tinypic.com/r7pq4z.jpg
2 + 2 + 2 cylinder engine?
45 degree + 45 degree + 45 degree?
What is it?
Montblack
Monk posted this engine link over in RAP.
Old March 11th 06, 09:36 PM posted to rec.aviation.homebuilt
Montblack
Don't recognize the engine but looks like 60 degrees + 60 degrees and
120 degrees total.
Any indications this is an aircraft engine?
Big Johnb
On Sat, 11 Mar 2006 13:57:40 -0600, "Montblack"
What is it?
Montblack
Old March 12th 06, 12:03 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
What is it?
Montblack
Looks like an air compressor.
J Kimmel
www.metalinnovations.com
"Cuius testiculos habes, habeas cardia et cerebellum." - When you have
their full attention in your grip, their hearts and minds will follow.
Old March 12th 06, 03:08 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
What is it?
Montblack
My thoughts exactly---one bank looks smaller than the others--but that
might be the viewpoint--Incidentally, there were quite a few "W"
configured engines made just after WW-I ---Jerry
Old March 12th 06, 10:02 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
In article , says...
They look the same to me . . .
Wonder what the crank looks like - 3 main bearings?
GF
Old March 12th 06, 12:01 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
What you have in the picture, seems to be a French Lorraine 12 Ed aircraft
engine, circa year 1922. It is a liquid-cooled W-type engine (yes, 60+60=120
degrees most probably), but instead of 6-cylinder configuration, it's a
12-cylinder layout (believe or not). Capacity 24,4 litres, dry weight 425
kg. Power output 450 hp.
Check out this link. It has a picture of the engine.
http://www.planes-and-tanks.com/EngineShop/lorraine.htm
"Montblack" kirjoitti
What is it?
Montblack
Old March 12th 06, 03:24 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Yes, that's it...
"JP" wrote in message ...
"Montblack" kirjoitti ...
What is it?
Montblack
Old March 12th 06, 04:52 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
I agree, looks like JP gets the gold star! I found the picture in a
motorcross safari website that specializes in motorcross tours in
Cambodia. The engine is from a downed aircraft in that area.
Great job JP!
The Monk
Old March 12th 06, 04:59 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Thanks! My pleasure.
"Flyingmonk" kirjoitti
legroups.com...
Great job JP!
The Monk
Old March 12th 06, 05:13 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
("JP" wrote)
60+60=120 degrees most probably), but instead of 6-cylinder configuration,
it's a 12-cylinder layout (believe or not). Capacity 24,4 litres, dry
weight 425 kg. Power output 450 hp.
Thanks for the link!
About the web page:
When you click on "Aircraft Engines" to see more engines - that link doesn't
work.
Simply turn the capital "E", in the web address, into a lower case "e" for
the "Aircraft Engines" link on the Lorraine page to work. (IE 6.0 and
Firefox/Mozilla)
1922 (French) Lorraine aircraft engine in Cambodia
940 lbs
450 hp
12 cylinder
Montblack
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
