If I just want to do IFR approaches at my class D airport of origin,
how should I file? One FSS person suggested that I file McKinney (TKI) direct to a 5 mile on a 360 radial from the airport (which has no VOR) and then back to TKI -- putting "multiple approaches" in the comments section. Any other thoughts? |
how should I file? One FSS person suggested that I file McKinney (TKI) direct to a 5 mile on a 360 radial from the airport (which has no VOR) and then back to TKI -- putting "multiple approaches" in the comments section. Any other thoughts? Unless they've changed the rules recently, you don't have to file if you plan on staying with the controller of your origin airport. You just get on clearance delivery if you have one and tell them you want to do approaches and they will give you a squawk. You then go from there. I think you could file if you want to but it would only be to let the controller know what approach you plan on doing if you lose comms. |
"Nicholas Kliewer" wrote:
One FSS person suggested that I file McKinney (TKI) direct to a 5 mile on a 360 radial from the airport (which has no VOR) and then back to TKI -- putting "multiple approaches" in the comments section. Well, that's one way to do it. If there's no VOR or NDB within a few miles, look on the low altitude chart and pick any nearby intersection to put in the flightplan. You never really have to go there, it's just so you'll have a route to fly in case you lose comm. Do put "multiple approaches" in the comments section. At my class D airport the tower controller will ask which approaches I want and pass them on to the TRACON controller, who will sometimes actually remember them. -- Dan C172RG at BFM |
"Nicholas Kliewer" wrote in message ... If I just want to do IFR approaches at my class D airport of origin, how should I file? One FSS person suggested that I file McKinney (TKI) direct to a 5 mile on a 360 radial from the airport (which has no VOR) and then back to TKI -- putting "multiple approaches" in the comments section. Any other thoughts? That'll work. The flight data processing computer will accept a direction and distance from any stored fix. |
Nicholas Kliewer wrote in
: If I just want to do IFR approaches at my class D airport of origin, how should I file? One FSS person suggested that I file McKinney (TKI) direct to a 5 mile on a 360 radial from the airport (which has no VOR) and then back to TKI -- putting "multiple approaches" in the comments section. Any other thoughts? Just file TKI to TKI and add multiple approaches in the comments box. Your clearance will be something like "cleared to TKI, climb and maintain ...." |
"Andrew Sarangan" wrote in message . 158... Nicholas Kliewer wrote in : If I just want to do IFR approaches at my class D airport of origin, how should I file? One FSS person suggested that I file McKinney (TKI) direct to a 5 mile on a 360 radial from the airport (which has no VOR) and then back to TKI -- putting "multiple approaches" in the comments section. Any other thoughts? Just file TKI to TKI and add multiple approaches in the comments box. Your clearance will be something like "cleared to TKI, climb and maintain ...." Actually, you have to file to some point (VOR, NDB, intersection, etc.) away from the airport and back, otherwise their computers won't accept the flightplan as there is no actual "route". (I've tried this before and had to file to a VOR and back...and once airborne I didn't neccessarily have to go to the VOR). Paul Crawford |
On Mon, 17 May 2004 20:57:04 -0500, Nicholas Kliewer
wrote: If I just want to do IFR approaches at my class D airport of origin, how should I file? One FSS person suggested that I file McKinney (TKI) direct to a 5 mile on a 360 radial from the airport (which has no VOR) and then back to TKI -- putting "multiple approaches" in the comments section. Any other thoughts? In this area there's no need to file a route. Just the origin and destination airports, with multiple approaches in the comments section. It doesn't really matter. Everyone in the loop should know what you are going to do. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
"Andrew Sarangan" wrote in message . 158... Just file TKI to TKI and add multiple approaches in the comments box. Your clearance will be something like "cleared to TKI, climb and maintain ...." That'll work over the phone to FSS, but the computer will reject it. The error response is "zero distance" or something like that. |
In article , Nicholas Kliewer
wrote: If I just want to do IFR approaches at my class D airport of origin, how should I file? One FSS person suggested that I file McKinney (TKI) direct to a 5 mile on a 360 radial from the airport (which has no VOR) and then back to TKI -- putting "multiple approaches" in the comments section. Any other thoughts? According to AvWeb's Don Brown in a column a couple of months ago, you file to the initial approach fix for the airport you want to do approaches to. |
On Tue, 18 May 2004 02:41:06 GMT, "Steven P. McNicoll"
wrote: That'll work over the phone to FSS, but the computer will reject it. The error response is "zero distance" or something like that. That's interesting. I've only filed without a fix via phone, so it must have gotten "fixed" by the person entering the flight plan into the computer. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
| Lycoming CAD file wanted | Dave Driscoll | Home Built | 1 | July 1st 04 02:30 AM |
| Ron Wantaj?? XL file | Jerry Wass | Home Built | 9 | March 3rd 04 04:22 AM |
| how I map my flights | Snowbird | Instrument Flight Rules | 10 | December 1st 03 12:26 AM |
| Don Brown and lat-long | Bob Gardner | Instrument Flight Rules | 30 | September 29th 03 04:24 AM |
| Reflections on first trip to Canada from US | Mike & Janet Larke | Instrument Flight Rules | 1 | August 9th 03 01:57 AM |
