#81
Newps wrote:
It is agreed upon by all parties that it is the largest facilities that have the problems. Then why is it that the FAA is implementing this restriction across all towered airports? Also, are there cases where airports can get a waiver and continue P&Hs (such is apparently the case of the previous posters airport)? I am curious why airports such as my class C wouldn't apply for one, rather than choose to eliminate them per this requirement. -- Peter |
#82
![]() Peter R. wrote: Newps wrote: It is agreed upon by all parties that it is the largest facilities that have the problems. Then why is it that the FAA is implementing this restriction across all towered airports? This is actually the second time this has happened. A few months ago, maybe six, we got a memo from the region asking us to justify why we need position and hold. Presumably all facilities made their arguments. They let us continue as normal. But the big facilities continue to screw up so they are going to make it hard to use. The only problem is the big facilities won't have to change much, if anything, to keep qualified to use P&H. Therefore nothing will change. Also, are there cases where airports can get a waiver and continue P&Hs (such is apparently the case of the previous posters airport)? I am curious why airports such as my class C wouldn't apply for one, rather than choose to eliminate them per this requirement. A facility will be required to keep all positions in the tower open to be able to use P&H. For example we have a position called clearance delivery. It is always combined with ground control. Bingo, no P&H allowed. That's why virtually no class C's will be using P&H anymore, they don't keep all their positions open. |
#83
What if the position is eliminated? Then you'd be legal for P&H, no? Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
#84
Newps wrote:
For example we have a position called clearance delivery. It is always combined with ground control. Bingo, no P&H allowed. That's why virtually no class C's will be using P&H anymore, they don't keep all their positions open. That explains it. At Syracuse, the ground control position is almost always combined with tower, even during their so called busy periods. -- Peter |
#85
![]() Jose wrote: For example we have a position called clearance delivery. It is always combined with ground control. Bingo, no P&H allowed. What if the position is eliminated? Every tower has a clearance delivery position, some staff it, some don't. |
#86
Last Friday afternoon (10 MAR 2006) I was holding short at 17L at PWA, while a
Hawker was on short final. As he touchdown, the tower told me to taxi into position and hold. I guess we haven't got the word. It was Friday afternoon and from the sound of things, I think he was the only one in the cab. The bus-jet were coming home for the weekend and the recreation pilots were get out of town for the weekend, and we were closed pattern on 17R, and a T-6 from Vance AFB did a missed approach. The controller was doing a good job of handling the traffic and TIPH just another tool to get everybody taken care of. GeorgeC |
#87
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 NATCA is now getting involved, making the plot thicker... http://www.avweb.com/newswire/12_10b.../191727-1.html There has also been a GENOT sent out that specifies this. I'm trying to find a link to it now. But I guess for most airports that qualify for this, they will be doing the paperwork for the waiver, and will be business as usual for them. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.2.2 (GNU/Linux) iD8DBQFEFhOiyBkZmuMZ8L8RAkExAKCYgXNc7gEx9quvzOf98B jmCYQVJgCgtp2f MlAJJhP2pjh+9xanwjEMvTs= =jK+Q -----END PGP SIGNATURE----- |
#88
![]() A Guy Called Tyketto wrote: But I guess for most airports that qualify for this, they will be doing the paperwork for the waiver, and will be business as usual for them. The new rules start Monday. All facilities were told to file for a waiver, hows that for typical FAA dumbass? Here, we will be eliminating the cab coordinator position thus obviating the need for a waiver. |
