GSC prop as wind turbine???
Old March 17th 06, 03:06 AM posted to rec.aviation.homebuilt
Default GSC prop as wind turbine???
A bit off topic - but what kind of power and speed might I expect to
get out of a GSC 68" 3 blade prop used as a wind terbine?
*** Free account sponsored by SecureIX.com ***
*** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
Old March 17th 06, 06:41 AM posted to rec.aviation.homebuilt
"what kind of power and speed might I expect to get out of a GSC 68" 3 blade
Are you trying to create wind or electricity?
Colin
Old March 17th 06, 12:24 PM
Chris Wells Chris Wells is offline
Senior Member
First recorded activity by AviationBanter: Oct 2005
Propellers can't be used as wind turbines (at least not efficiently) because they're turned the wrong way.
Old March 17th 06, 02:45 PM posted to rec.aviation.homebuilt
clare at snyder.on.ca wrote in message
Assuming that you are trying to generate power from wind, the short answer
is "not much". Your prop has the wrong airfoil for that job. A good place to
ask questions about wind turbines is alt.energy.homepower and
alt.energy.renewable.
Vaughn
Old March 17th 06, 03:21 PM posted to rec.aviation.homebuilt
A GSC prop is a wooden ground-adjustable prop, isn't it? By
making the necessary pitch adjustment so that the wind is against the
bottom of the foil and the leading edge moves forward, it should work.
Ordinary fixed-pitch props won't work; they're great for driving, lousy
when driven.
Dan
Old March 17th 06, 07:31 PM posted to rec.aviation.homebuilt
To do this, he'd have to be able to take the prop to
significant negative pitch. I'd be surprised if a prop
intended for an airplane would have sufficient negative
adjustment range for this application.
Some of those props had blades with round roots clamped into a
hub, and the blade could be turned all the way around. The Warp Drive
prop is similar.
It occurred to me that the blade's twist would be all wrong for
the wind turbine application, anyway. The blade would have to turn a
lot to get the root to the right angle, and by that time the tip would
be close to feathered, just the opposite of what we need.
Dan
Old March 17th 06, 08:10 PM posted to rec.aviation.homebuilt
On Fri, 17 Mar 2006 06:41:21 GMT, "COLIN LAMB"
Colin
Put it this way - not wind.
Old March 17th 06, 08:11 PM posted to rec.aviation.homebuilt
On Fri, 17 Mar 2006 12:24:26 +0000, Chris Wells
So you turn them around. Flat side to the wind, fat side to the wind.
Old March 18th 06, 01:21 AM
Senior Member
Nope, twist is the wrong way.
Old March 18th 06, 02:44 AM posted to rec.aviation.homebuilt
The optimum wind generator blade in terms of efficiency is a thin two bladed
prop. It will have about 70% efficiency. The power output depends upon
wind speed and will increase based upon the square of the wind speed.
However, a governor is required to prevent overspeed.
An efficient 68" two bladed prop would have about 5 watts output with a 5
mph wind, 100 watts with about a 14 mph wind and 500 watts with a 24 mph
wind.
I have both commercial and home built wind generators and what has been said
about using an aircraft propellor is true, they are not good wind generator
blades. It is fairly easy to carve a blade and I have made them with a
table saw and hand plane.
But, you cannot simply put the system up without a bit of thought. My first
wind generator I installed was a "temporary" one. Just a hand carved blade
attached to an electric motor. We normally do not have much wind, but that
night we had a 30 mph wind. The next morning I noted the blade was missing
on the wind generator. I looked for a month before I found the blade lodged
in a tree about 100 feet away.
Two bladed props are most efficient, but they create havoc. They shudder
when the wind changes direction and create stresses on the entire mechanism.
3 bladed props solve that problem, but are harder to make at home. Another
problem area is the gear boxes. Alternators like higher rpm than created by
the blades and the varying wind can put terrific loads on the gear boxes.
Many of the early commercial units suffered gearbox problems. A low rpm dc
motor can be used as an efficient generator. One of my home built designs
uses a 36 volt 900 rpm permanent magnet motor and works quite well.
Wind generators need a governor. Otherwise, high or medium winds will tear
it apart. In that situation, they can become lethal.
They are certainly fun to watch. Much more fun than a soap opera.
Colin
Headwinds, always Paul kgyy Piloting 36 June 9th 05 01:05 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
