Third "turbine" on top of large Mil helis?
Old March 17th 06, 04:49 PM posted to rec.aviation.rotorcraft
Default Third "turbine" on top of large Mil helis?
Hi, many of the large Mil helis have what looks like a third turbine
above, and slightly behind the two main turbines. What is it? All of
the specs for these helis say they have two turbines. I can see blades
in some photos, so it's obviously something like a turbine.
Thanks, Justin.
http://soupisgoodfood.net/
Old March 17th 06, 04:58 PM posted to rec.aviation.rotorcraft
Hi, many of the large Mil helis . . . . .
Got a pic?
Old March 17th 06, 06:20 PM posted to rec.aviation.rotorcraft
http://www.airliners.net/open.file/1011699/M/
http://www.airliners.net/open.file/0857039/M/
http://www.airliners.net/open.file/0658477/M/
http://www.airliners.net/open.file/0863587/M/
http://www.airliners.net/open.file/0646747/M/
Old March 17th 06, 06:28 PM posted to rec.aviation.rotorcraft
Oil Cooler fan
Slatts
Old March 17th 06, 06:45 PM posted to rec.aviation.rotorcraft
That is an auxiliary power unit (APU) for pneumatic main turbine starting.
Required for self-contained operations. At least some models of Mil are
equipped with Ivchenko AI-9V APU unit.
Use e.g. Vivisimo meta-search engine www.vivisimo.com and type "Mil Mi APU"
and you get more information about the subject.
JP
kirjoitti
glegroups.com...
Thanks, Justin.
Old March 17th 06, 06:55 PM posted to rec.aviation.rotorcraft
Oil cooler fan mentioned earlier is not a bad idea after all! Some larger
Mil helos may have a main transmission cooling system located just there.
JP
"JP" kirjoitti
APU" and you get more information about the subject.
JP
kirjoitti
glegroups.com...
Thanks, Justin.
Old March 17th 06, 06:57 PM posted to rec.aviation.rotorcraft
Thanks for that. Mystery solved
Old March 19th 06, 02:43 PM posted to rec.aviation.rotorcraft
Justin, Look at first picture. Left rear of cowling shows small exhaust
for APU (I'd guess about 5 in. compared to larger main engines).
Ed R.
Old March 19th 06, 03:26 PM posted to rec.aviation.rotorcraft
"JP" wrote in message
APU"
The APU is behind the transmission.
Slatts
Old March 19th 06, 03:53 PM posted to rec.aviation.rotorcraft
"Sla#s" kirjoitti
where.com...
starting. Required for self-contained operations. At least some models of
Mil are equipped with Ivchenko AI-9V APU unit.
APU"
Slatts
Yes I agree, it seems to be the case. The APU is behind the main
transmission. The "third turbine" has to be an oil cooler fan.
JP
STC to Install a Large Baggage Door on a Baron? JAX Owning 1 November 15th 05 11:41 PM
FA: Vietnam The Helicopter War Large HC Book 189p Disgo Aviation Marketplace 0 February 6th 04 05:19 PM
helis update jorge Rotorcraft 0 October 19th 03 10:26 PM
Invest small Earn Large ($20 000+) promethean General Aviation 0 October 3rd 03 06:08 AM
