Would you fly this Aircraft?
Old March 19th 06, 05:29 AM posted to rec.aviation.piloting
Default Would you fly this Aircraft?
I'd be interested in "go/no-go" opinions of others, based solely on the
following information ...
"Naturally aspirated, carburated, light twin (C172 engines) - hasn't been
flown for 3 weeks - at the conclusion of last flight was fueled to the max.
Has since been observed to have fuel dripping from the right-hand engine
nacelle. Has been checkd by engineer who has put it down to "full tanks +
volume change due to temperature changes".
No other information available.
My initial thought was "why wouldn't the excess fuel get forced out through
the tank vents, rather than through "something" within the engine bay.
How many of you would / would not fly this aircraft based on the above info?
(I appreciate that more info would be nice, but it's all I have available).
Many thanks,
Cheers,
Old March 19th 06, 05:49 AM posted to rec.aviation.piloting
Based on that, I would NOT fly the aircraft UNTIL I had
personally inspected it to see what was leaking and from
where. If the float valve was leaking, the fuel level would
rise and over-flow from the vent on the carb. That is an
easy fix. If a fuel line is leaking, it is also an easy
fix. If a crack is in the float bowl, you replace the carb,
also easy but more expensive.
What is the history of the airplane before and on the last
flight? Was is parked with the fuel valves OFF or ON?
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"C J Southern" wrote in message
solely on the
fueled to the max.
right-hand engine
to "full tanks +
forced out through
engine bay.
on the above info?
have available).
| Many thanks,
| Cheers,
Old March 19th 06, 06:12 AM posted to rec.aviation.piloting
"Jim Macklin" wrote in message
newso6Tf.118036$QW2.75471@dukeread08...
Several years ago the aircraft showed the same symptoms - on that occasion
the leak was due to a fractured primer line.
Prior to the last flight there were no know issues.
Aircraft is always parked with fuel selectors ON, but following the leak the
right hand fuel selector has been turned off to stop any more leakage.
Personal investigation would be difficult - it would require removal of the
cowling (which presumably the engineer has done). If the cowling isn't
removed, then the only place you can see anything is via the oil filler
flap - which lets one see very very little.
Old March 19th 06, 06:33 AM posted to rec.aviation.piloting
"Naturally aspirated, .......
Pointless question. Insufficient data for any kind of decision.
Presumably, you'd preflight the aircraft anyway, which obviates your above
question.
Old March 19th 06, 06:51 AM posted to rec.aviation.piloting
The crux of the question really is "if the licenced and qualified engineer -
who would get paid for fixing the problem if there was a problem - says that
it's OK, does one trust that?
Do you trust the FBO? Why or why not? Follow the money.
Part 2 of the question is "why would full tanks cause this - why wouldn't
the excess get squeezed out the tank vents"?
That by itself, and no explanation from the "licensed and qualified
engineer" as to what caused it, would cause me to let somebody else be
the guinea pig.
Jose
Nothing takes longer than a shortcut.
Old March 19th 06, 06:54 AM posted to rec.aviation.piloting
"John Gaquin" wrote in message
question.
Not really. For me, the question is do I bother making the trip to the
airport, or do I wait for someone else to be the "canary in a cage". I've
also got a slightly nervous a passenger to consider - last thing I want is
an engine fire with a nervous passenger sitting right next to it.
it's OK, does one trust that? As a pilot I won't be able to see where the
leak is coming from without removing the cowling - which is engineer only
territory.
Old March 19th 06, 07:23 AM posted to rec.aviation.piloting
Removal of the cowling is required and I would want to
either do it or be present. Fuel lines can leak due to
loose fittings, broken lines that crack from fatigue or
abrasion. I would want to visually inspect for any signs of
fuel stains and any damage.
The problem is not just possible engine failure, but fire
and explosion inside the wing or cowling.
Since mechanics {engineers} often won't fly in airplanes
they have performed maintenance upon, you, the PIC must be
able to inspect the airplane and satisfy yourself.
James H. Macklin
ATP,CFI,A&P
some support
| "Jim Macklin" wrote
in message
last
on that occasion
more leakage.
cowling isn't
the oil filler
Old March 19th 06, 07:26 AM posted to rec.aviation.piloting
#2 Full tanks increase fuel pressure, a poor seal on the
carb float needle valve will leak and fill the bowl, which
then over-flows. The tanks have about 10-15% free space
even when full to allow parking on non-level surfaces before
the tank vents begin to drain.
James H. Macklin
ATP,CFI,A&P
some support
decision.
obviates your above
| question.
trip to the
in a cage". I've
thing I want is
to it.
problem - says that
to see where the
is engineer only
| territory.
this - why wouldn't
Old March 19th 06, 07:48 AM posted to rec.aviation.piloting
Fuel has weight, a little less than .5 pounds per foot of
distance. A high wing Cessna has about 3-4 feet between the
fuel tank and the carb float. The float in the bowl is
raised by the liquid fuel in the bowl and by a lever,
presses the needle valve closed, stopping the flow of fuel
by gravity.
If the needle valve is leaking, there are two problems,
during engine operation, the fuel level will be too high
making the mixture too rich, although this can be manually
leaned, but the bowl may still fill to over-flow and this
will cause a lose of fuel which can result in an fuel
starvation accident.
When parked, it can cause a fire hazard and certainly waste
expensive fuel.
For a science experiment, take a straw and place it in a
glass of water and place your finger over the end of the
straw. When you lift the straw, the water won't flow out of
the straw because it isn't vented, but the pressure of the
water is due to the weight of the water caused by gravity.
Low wing airplanes and some high wing airplanes with carbs
also have fuel pumps, all fuel injected engines have pumps
because gravity is not powerful enough to operate the
injection system.
James H. Macklin
ATP,CFI,A&P
Just to explain this, ATP is Airline Transport Pilot
CFI, I have Gold Seal Airplane SMEL and Instrument
A&P Airframe and Powerplant mechanic
some support
"Morgans" wrote in message
| "Jim Macklin" wrote
in message
| news:II7Tf.118045$QW2.26850@dukeread08...
which
before
| Hold the phone, here.
| You mean fuel tanks can build up pressure with functioning
vent lines?
| Hummm.
| If it is a bad (plugged) vent, then I'm not going to fly
it until *that*
| detail is fixed.
| Jim in NC
Old March 19th 06, 07:56 AM posted to rec.aviation.piloting
question.
Insufficient date, yes.
Do tell, what is preflighting the aircraft going to tell you, other than
there is fuel leaking from a "bad place (tm) and to get to the bottom of it,
some dissassembly will be required?
Sounds like a no go, to me.
Jim in NC
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
