66 at the time? You give me hope, Dan!
AJ |
I'm 57 and have been flying for only two years. The sport pilot
definition was just about a perfect fit for my intended use: flying for fun and just lookin' around. An occasional cross country. I've got very little interest in big airports. A little plane is fine with me. Well, at the time I started my training, the sport pilot stuff was under discussion, but not implemented. I didn't want to wait for the beurocrats to work things out, so I went ahead and got my private pilot certificate. Now, 240 hours later, and an owner/builder of a Savannah (similar to Zenith CH701) I'm glad I didn't wait. It's too much fun flying. But if I were starting today, I would probably go sport pilot if training was available in my area. (it still isn't) tom |
("tom" wrote)
I'm 57 and have been flying for only two years. The sport pilot definition was just about a perfect fit for my intended use: flying for fun and just lookin' around. An occasional cross country. I've got very little interest in big airports. A little plane is fine with me. It would have been nice to get the C-150/152's and all of the Ercoupes into the L-Sport category. 1,600 lbs? Oh well. The other is the high end speed limit (138 mph). It would have been nice if that could have been waived for single place planes ...RV-3(B). Again, oh well. http://www.vansaircraft.com/public/rv-3int.htm Montblack |
Well, if you really wanted to fly an RV-3, you could probably hang a 100 hp
engine and a less than optimal prop and stay under the speed limit... "Montblack" wrote in message ... ("tom" wrote) I'm 57 and have been flying for only two years. The sport pilot definition was just about a perfect fit for my intended use: flying for fun and just lookin' around. An occasional cross country. I've got very little interest in big airports. A little plane is fine with me. It would have been nice to get the C-150/152's and all of the Ercoupes into the L-Sport category. 1,600 lbs? Oh well. The other is the high end speed limit (138 mph). It would have been nice if that could have been waived for single place planes ...RV-3(B). Again, oh well. http://www.vansaircraft.com/public/rv-3int.htm Montblack |
![]() "Montblack" wrote The other is the high end speed limit (138 mph). It would have been nice if that could have been waived for single place planes ...RV-3(B). Again, oh well. That's a no brainer! Put a **very**flat pitch prop on it, and it will not go too fast, without over revving the engine. Think of the deck angle you could get, on climbout! About 60 degrees? g -- Jim in NC |
("Lakeview Bill" wrote)
The other is the high end speed limit (138 mph). It would have been nice if that could have been waived for single place planes ...RV-3(B). Again, oh well. http://www.vansaircraft.com/public/rv-3int.htm Well, if you really wanted to fly an RV-3, you could probably hang a 100 hp engine and a less than optimal prop and stay under the speed limit... Would they let [me] build an RV-3(B) and register/fly it as an LSA or E-LSA? Or would they be wise to my attempts? Ok, ok ...smaller engine it is. If it must be toned down, the assumption is that "Total Performance" of the RV-3(B) will get (at least)138 mph ... so, instead, let's aim for super-low fuel burn. Any small diesels out there? :-) Wonder how Van's feels about this option - hanging a 100 hp engine on an RV-3? How would they feel about an 85 hp engine + an optimal prop? Wonder if the FAA has come up against this yet? What I'd want is 138 mph (145 ...Oops.wink) at the very best gph possible AND be FAA approved as an E-LSA. (Single seat preferable) http://www.vansaircraft.com/public/rv-3per.htm RV-3 Performance Solo Weight .....1,050 lbs Empty Weight .....750 lbs. Empty weight and performance measured with fixed pitch wood propeller Speed .................................125 hp ..............150 hp Top Speed ........................195 mph ...........207 mph Cruise [75% @ 8000'] ......185 mph ..........196 mph Cruise [55% @ 8000'] ......166 mph ..........176 mph Stall Speed ..........................51 mph .............51 mph Ground Performance Takeoff Distance .................350 ft ..................300 ft Landing Distance ................350 ft ...................350 ft Climb/Ceiling Rate of Climb ...................1,700 fpm ............2,050 fpm Ceiling ..............................20,500 ft ...............23,500 ft Range Range [75% @ 8000'] ...........640 sm.............595 sm Range [55% @ 8000'] ...........770 sm ............715 sm Montblack |
("Morgans" wrote)
That's a no brainer! Well, now you're in MY wheelhouse! g Whatever would get approved ...AND get, say, 3 gph fuel burn? Is that close to possible with an RV-3(B) ...at 138+ mph cruise speeds? 750 lbs empty weight. Engine .................................125 hp ..............150 hp Top Speed ........................195 mph ...........207 mph Cruise [75% @ 8000'] ......185 mph ..........196 mph Cruise [55% @ 8000'] ......166 mph ..........176 mph The thing stalls at 51 mph, so that's within LSA limits. Montblack |
You will not get it approved as an "e-LSA"
an e-LSA will either be a kit built by a manufacturer who has built at least one sLSA... or a "grandfathered" "ultralight-like" aircraft... the RV-3 is niether. you could very likely build an am-built experimental RV-3 with a 100 HP engine and the proper pitch prop that you test fly and enter in your POH the proper documentation that says it does not fly more than 138mph at sea level on a standard day at your chosen "maximum continuous power" setting and you may fly it as a sport pilot. You are the builder, you test fly the aircraft, YOU put those little color bar on the RPM indicator, yes you could do it, and do it legally. OR just build a Sonex or Zodiac 601 that's sport pilot legal to begin with, or wait a bit for the RV-12. -- -- ET :-) "A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."---- Douglas Adams - "Montblack" wrote in : ("Lakeview Bill" wrote) The other is the high end speed limit (138 mph). It would have been nice if that could have been waived for single place planes ...RV-3(B). Again, oh well. http://www.vansaircraft.com/public/rv-3int.htm Well, if you really wanted to fly an RV-3, you could probably hang a 100 hp engine and a less than optimal prop and stay under the speed limit... Would they let [me] build an RV-3(B) and register/fly it as an LSA or E-LSA? Or would they be wise to my attempts? Ok, ok ...smaller engine it is. If it must be toned down, the assumption is that "Total Performance" of the RV-3(B) will get (at least)138 mph ... so, instead, let's aim for super-low fuel burn. Any small diesels out there? :-) Wonder how Van's feels about this option - hanging a 100 hp engine on an RV-3? How would they feel about an 85 hp engine + an optimal prop? Wonder if the FAA has come up against this yet? What I'd want is 138 mph (145 ...Oops.wink) at the very best gph possible AND be FAA approved as an E-LSA. (Single seat preferable) http://www.vansaircraft.com/public/rv-3per.htm RV-3 Performance Solo Weight .....1,050 lbs Empty Weight .....750 lbs. Empty weight and performance measured with fixed pitch wood propeller Speed .................................125 hp ..............150 hp Top Speed ........................195 mph ...........207 mph Cruise [75% @ 8000'] ......185 mph ..........196 mph Cruise [55% @ 8000'] ......166 mph ..........176 mph Stall Speed ..........................51 mph .............51 mph Ground Performance Takeoff Distance .................350 ft ..................300 ft Landing Distance ................350 ft ...................350 ft Climb/Ceiling Rate of Climb ...................1,700 fpm ............2,050 fpm Ceiling ..............................20,500 ft ...............23,500 ft Range Range [75% @ 8000'] ...........640 sm.............595 sm Range [55% @ 8000'] ...........770 sm ............715 sm Montblack |
("ET" wrote)
OR just build a Sonex or Zodiac 601 that's sport pilot legal to begin with, or wait a bit for the RV-12. For some reason my sights are set on a single seater. Thanks. Mont |
![]() "Montblack" wrote in message ... ("ET" wrote) OR just build a Sonex or Zodiac 601 that's sport pilot legal to begin with, or wait a bit for the RV-12. For some reason my sights are set on a single seater. Thanks. Mont Build a 601 and call the other seat a baggage area. |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
LSA instructor? | [email protected] | Piloting | 43 | August 12th 05 03:17 PM |
FAA has temporarily withdrawn the proposed Sport Pilot rule | Larry Dighera | Piloting | 2 | March 27th 04 06:23 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
