Safety wiring oil filters?
Old March 20th 06, 03:49 PM posted to rec.aviation.homebuilt
Default Safety wiring oil filters?
A question for those flying auto converisons - how do you secure the
oil filter?
Aviation oil filters have safety wire tabs. FRAM HP filter, which for
various reason are what I need to use on my VW based conversion, no
got. Oil filters typically go on finger tight. Losing your oil filter
could ruin your WHOLE day.
Anybody got any ideas how to secure this bad thing? I've thought about
forming a little "hat" out of a stainless steel mixing bowl that would
at least keep it from falling off. And silver soldering on some
tabs...
Any ideas?
Old March 20th 06, 03:54 PM posted to rec.aviation.homebuilt
oil filter?
tabs...
Any ideas?
Put a big ole adel clamp around the filter and viola, a safety wire tab.
Dan, U.S. Air Force, retired
Old March 20th 06, 03:56 PM posted to rec.aviation.homebuilt
Just answered my own question with a web search, which is what I should
have done first.
http://www.sportrider.com/tech/146_0002_hand/
put a hose clamp around the filter, then wire the hose clamp to the
filter adapter.
Or, buy a K&N filter, which has the high pressure properties of the
FRAM HP series, plus safety wire tabs.
Old March 20th 06, 06:28 PM posted to rec.aviation.homebuilt
I selected a filter that has a hexagonal nut on the end as a part of the
body. I drilled a safety wire hole thru the nut (it doesn't leak). Been
doing this for about 3years with no problem.
Stu Fields
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
(760) 408-9747 general and layout cell
(760) 608-1299 technical and advertising cell
www.vkss.com
www.experimentalhelo.com
"flybynightkarmarepair" wrote in message
have done first.
filter adapter.
Old March 20th 06, 09:10 PM posted to rec.aviation.homebuilt
On 20 Mar 2006 07:49:04 -0800, "flybynightkarmarepair"
oil filter?
tabs...
Any ideas?
BIG hose clamp around the flter - tie off the clamp.
*** Free account sponsored by SecureIX.com ***
*** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
Old March 20th 06, 09:11 PM posted to rec.aviation.homebuilt
On Mon, 20 Mar 2006 10:28:53 -0800, "Stuart & Kathryn Fields"
The old Hastings filters were nice that way - you could easily drill
the "nut"
Old March 21st 06, 02:36 AM posted to rec.aviation.homebuilt
I agree with Dan, the Adel clamp generally has a rubber piece attached that
would prevent the clamp from chafing the filter or puncturing the filter
from vibration.
oil filter?
tabs...
Any ideas?
Old March 21st 06, 03:04 AM posted to rec.aviation.homebuilt
oil filter?
You're right that losing one could ruin your whole day.
My question is: "How many automotive oil filters do you know of that have
fallen off?" I don't know of a single one.
Some of the things we safety in aviation vs some of the things we don't are
pretty interesting.
For instance, we don't safety the AN fittings on fuel and oil lines. Why
not? What makes these different from the oil filter?
KB
tabs...
Any ideas?
Old March 21st 06, 05:22 AM posted to rec.aviation.homebuilt
On Mon, 20 Mar 2006 22:04:36 -0500, "Kyle Boatright"
oil filter?
I was on a long road trip in my 1979 Camaro when I happened to look under the
car during a rest stop and spotted oil dripping. My filter had backed off.
Hadn't fallen away, but it sure wasn't sealing.
Old March 21st 06, 06:20 AM posted to rec.aviation.homebuilt
are
pretty interesting.
Darned good observations, that I have also thought about.
Ever slightly over tighten an oil filter on a car? I'm talking about just a
half turn too much?
It will cost you many minutes of severe language, and a loss of patience.
I've had to pound a screw driver through them, when a strap filter would not
get a grip. I've had that not work, and end up crushing the end of the
filter with a giant pair of channel locks, to grip it well enough to turn.
So what is the answer? It prolly would not need to be safety wired, but
would I, if I was flying an auto conversion? Prolly would. g
Jim in NC
