Would this plane have flown?
Old March 23rd 06, 04:04 AM posted to rec.aviation.piloting,rec.aviation.owning
Default Would this plane have flown?
I don't think you EVER want to disconnect a control surface or even a
trim tab. Any Aero engrs out there want to comment?
  #52
Old March 23rd 06, 04:18 AM posted to rec.aviation.piloting,rec.aviation.owning
Not to discount your point about the potential of harm to the interior
wing structure (which is valid IMHO), but I'll bet you could take one of
those 1 inch aluminum poles and easily bend it over your knee.
Nope -- I tried.
Actually, now that I think about it, they had to be bigger than 1 inch.
More like 1.5 inch.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #53
Old March 23rd 06, 04:53 AM posted to rec.aviation.piloting,rec.aviation.owning
"george" wrote
Nowadays I'd wait for repairs but a neighbour spent 5 years driving
various two and four engined bombers over Occupied Europe and had a
series of photos of just how little you -really- need in the way of
contol surfaces
THEY had no choice, but to fly back home, while they were hit over enemy
territory. This fella did have a choice.
My take on it? He got lucky, and I'm glad he did.
I would say the chance of having a problem is low, less than 10%, most
likely. That means if 10 guys got hit like he did, one would not make it
home. Put in those terms, would you want to be that 1 out of 10? Even if
it was 1 out of 100, it would be too high, when there is a choice.
If it were me, I would have done as detailed inspection (removing access
covers, whatever) as possible. Perhaps, I even would have disconnected that
side at the yoke, or first belcrank, and bolted that aileron stationary.
Flutter scares the crap out of me.
Whatever, I would not have made any decision's based on what the insurance
company said.
Jim in NC
  #54
Old March 23rd 06, 07:16 AM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary wrote:
http://www.thegaryhouse.com/aircraftdamage/
I was down in a remote area of Mexico this last weekend and a truck
backed into my aileron. I was lucky that the driver had a sat phone and
I was able to call an A&P to come down to Mexico and swap it for me.
However, all the local pilots, and the A&P who came down seemed to
think it would have flown ok as was. From a simply academic point of
view I"m curious what you guys think.
I would not have felt qualified to determine whether it was flyable or
not, so I probably would not have flown it without getting an opinion
and a ferry permit from an A&P (and I am not above making the A&P fly
with me). My main concerns would be weakened attach points and possibly
some sort of flutter induced by disrupted airflow over the aileron.
  #55
Old March 23rd 06, 10:52 AM posted to rec.aviation.piloting,rec.aviation.owning
I would strongly doubt (based on what I know) that there was even the
remotest chance of flutter. From what I understand, flutter would
require the flexing of the wing structure in such a way to cause the
whole thing to oscillate. This happens with experimental airframes (or
used to happen) because the whole surface or wing would warp under
aerodynamic loads in such a way that you'd get the oscillation. A dent
in a Mooney aileron isn't going to cause that.
Dylan Smith, Port St Mary, Isle of Man
Flying: http://www.dylansmith.net
Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de
Frontier Elite Universe: http://www.alioth.net
  #57
Old March 23rd 06, 02:40 PM posted to rec.aviation.piloting,rec.aviation.owning
"Dave Butler" wrote in message
news:1143124006.95524@sj-nntpcache-5...
FWIW, Mooney ailerons are required to be rebalanced after they are
*painted*.
As are almost all flight control surfaces on most all aircraft.
  #58
Old March 23rd 06, 03:22 PM posted to rec.aviation.piloting,rec.aviation.owning
*painted*.
OK, I thought this requirement came from manufacturers service letters and the
like. I know about Bonanza and Mooney. Is there some other more general requirement?
  #59
Old March 23rd 06, 03:27 PM posted to rec.aviation.piloting,rec.aviation.owning
*painted*.
and the like. I know about Bonanza and Mooney. Is there some other more
Here's a quote from http://www.avweb.com/news/maint/182829-1.html "Getting Good
Paint" by Paul Bertorelli:
"Guenther and better shops insist—rightly—that controls be removed, stripped,
inspected and, most important, rebalanced after painting. On some
controls—Bonanza ruddervators and Mooney ailerons—this is a critical task and
shouldn’t be skipped. But it should still be standard on all aircraft. Guenther
goes so far as to record the balance data in the aircraft logbook, along with
the signoff for the paint itself."
which makes me think this is not a general requirement or practice.
  #60
Old March 23rd 06, 03:45 PM posted to rec.aviation.piloting,rec.aviation.owning
Flutter is determined by the torsional stiffness (and mass) of the wing
section. In this case, that did not seem to be compromised - i. e.
there were no diagonal wrinkles across the wing panel. If there were
diagonal wrinkles, flutter would be a real possibility. But dropping
the airspeed greatly helps the flutter margin, just as increasing the
max speed quickly reduces the flutter margin. I understand that during
each new aircraft's flight at the factory, the test pilot must dive it
to 110% of the indicated red line speed. The survivors are certfied.
There were diagonal wrinkles across the aileron panel, but I don't
think the aileron in itself can flutter. The question in this case
would be the aileron control integrity. Someone earlier suggested
blocking or locking one aileron. That could have all sorts of
interesting changes and very definitely I would not recommend.
Cirrus chute deployment -- an incredible story Michael182/G Instrument Flight Rules 48 July 14th 05 03:52 PM
My first lesson Marco Rispoli Aerobatics 3 May 17th 05 08:23 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
