Loading TP to Garmin 396
Old March 22nd 06, 05:00 PM posted to rec.aviation.soaring
Default Loading TP to Garmin 396
Does anyone have any experience of loading Turnpoint Exchange turnpoint
files to the Garmin 396? If so what utility and what file format did
you use?
My previous experience is with a Garmin 95XL using the Garmin PCX5
software.
thanks
Andy
Old March 22nd 06, 06:57 PM posted to rec.aviation.soaring
..wpt is for garmin is it not ?
http://soaring.aerobatics.ws/TP/ASA/files.html
Old March 22nd 06, 11:04 PM posted to rec.aviation.soaring
you use?
software.
thanks
Andy
..wpt. I've used Gartrip for many years. www.gartrip.de Works with
Garmin and Magellan receivers.
Chip Fitzpatrick
Old March 23rd 06, 02:33 AM posted to rec.aviation.soaring
http://www.garmin.com/support/collec...t=010-00425-00
Old March 23rd 06, 01:44 PM posted to rec.aviation.soaring
Andy wrote:
I downloaded Gartrip but it won't connect to my 396. Mapsource will
connect so it's not a problem with the PC, GPS, cable, or USB driver.
Mapsource (supplied with the 396) does not appear to accept .wpt files.
It only imports MPS or GDB files and these are not supported by
Turnpoint exchange.
So, once again, has any one actually loaded turnpoint exchange files to
a Garmin 396? If so what PC utility did you use and what file format
was used.
thanks
Andy
Andy,
did you check the comm ports on your pc? And you must set the GPS unit
to the Garmin-Garmin protocol that you would use to transfer data
between Garmin units.
Of course my new PC has no serial ports and I now have to look into
USB/serial converters. Anyone have any recommendations?
Chip F
Old March 25th 06, 02:56 PM posted to rec.aviation.soaring
Thanks for the tip Kirk. I tried it but it won't communicate either.
Mapsource uploads and downloads to the 396 just fine but other apps
seem to have com port problems.
PCX5AVD that used to work on this PC doesn't anymore, perhaps due to an
OS "upgrade" to XP home.
Andy
Old March 25th 06, 03:22 PM posted to rec.aviation.soaring
Update - was able to get both Gartrip and G7toWin to download from the
396 this morning. Don't know what the problem was before but it seems
to have been fixed by a PC reboot (or two).
Thanks for the tips on suitable applications.
Andy
Old April 8th 06, 04:34 PM posted to rec.aviation.soaring
you use?
This all turned out to be a non-problem. I have found that the Garmin
provided utility Mapsource will open the old PCX5 format waypoint
files. So the 396 can be loaded with garmin pcx5 files that are already
available on tp exch.
Andy
Old April 9th 06, 03:21 PM posted to rec.aviation.soaring
I suspect there are very few 396's being used for soaring but was
browsing Garmin for an update to Mapsource and found this
"Changes made from version 6.7 to 6.8.0:
* This will be the last version of MapSource to support
reading/importing PCX5 files. For future compatibility, please migrate
your data to the GPX format."
I have version 6.5. Current version is 6.10.2
Back to G7toWin.
Andy
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Products 10 April 29th 04 06:57 AM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
