Would this plane have flown?
Old March 23rd 06, 06:58 PM posted to rec.aviation.piloting,rec.aviation.owning
Default Would this plane have flown?
Wing stiffness has more to do with control reversal, flutter
has to do with harmonics and balance.
If I had a question about a control surface and I had to fly
the airplane, I would limit speed to Va so that even a full
deflection of the control would not break the airplane.
I've seen pictures of a C210 [old plane with struts] that
took off from a strip near Tulsa with just a little ice on
the ailerons. I got to cruise speed and crashed shortly
there after, the outer wing panels looked like a Navy
fighter with the wings folded.
James H. Macklin
ATP,CFI,A&P
"nrp" wrote in message
| But I understand flutter also relies on the original
torsional
| stiffness of the wing being preserved. That if it is not
(i. e. a
| wrinkled wing skin) the flutter margin is reduced. Might
even a
| properly balanced control surface still flutter if the
primary wing
| stiffness is compromised? or is the control surface CG the
only
| determining item? THX
  #72
Old March 23rd 06, 07:06 PM posted to rec.aviation.piloting,rec.aviation.owning
then what was your question, should you have just flown it away
without any work/inspection or repair?
Jim, again quoting from the original post..
"From a simply academic point of view I"m curious what you guys think."
I was just curious how it would have flown since I obviously did not
fly it.
Again, I was very offended by your comment.
-Robert
  #73
Old March 23rd 06, 07:21 PM posted to rec.aviation.piloting,rec.aviation.owning
In article .com,
"nrp" wrote:
But I understand flutter also relies on the original torsional
stiffness of the wing being preserved. That if it is not (i. e. a
wrinkled wing skin) the flutter margin is reduced. Might even a
properly balanced control surface still flutter if the primary wing
stiffness is compromised? or is the control surface CG the only
Flutter can also result from unusual airflow exciting a surface (such as
the rather large dent in the aileron tip). It is a function of
stiffness, true airspeed, balance and external excitations.
The owner did the conservative thing -- after all his insurance company
was there to stand behind him. Yes -- the whole thing was obviously a
major PITA, but everyone came out fine. Congratulations!
  #74
Old March 23rd 06, 07:33 PM posted to rec.aviation.piloting,rec.aviation.owning
And I didn't say people should call ahead at every airport they land on.
"Steve Foley" wrote in message
news:RJiUf.2575$3t1.120@trndny08...
I don't call ahead and make arrangements for a mechanic at every airport I
land at. If something goes wrong, I'll deal with the problem.
"Juan Jimenez" wrote in message
om...
Purely from an academic standpoint, I'm curious why people go into remote
areas of a foreign country (particularly one like Mexico) without some
way
of calling for help if they get stuck, not having made
arrangements/contacts
with a local mechanic in case there were some kind of problem, etc.
People
who can afford having an A&P come down to Mexico to fix a problem ought
to
be able to afford a little planning ahead for eventualities just like
this
one. Academically speaking, of course.
Juan
http://www.thegaryhouse.com/aircraftdamage/
I was down in a remote area of Mexico this last weekend and a truck
backed into my aileron. I was lucky that the driver had a sat phone and
I was able to call an A&P to come down to Mexico and swap it for me.
However, all the local pilots, and the A&P who came down seemed to
think it would have flown ok as was. From a simply academic point of
-Robert
*** Free account sponsored by SecureIX.com ***
*** Encrypt your Internet usage with a free VPN account from
http://www.SecureIX.com ***
*** Encrypt your Internet usage with a free VPN account from http://www.SecureIX.com ***
  #75
Old March 23rd 06, 07:47 PM posted to rec.aviation.piloting,rec.aviation.owning
That it may be illegal and that it needs another log entry are two separate
issues. There's also nothing wrong with using a Mexican mechanic if he/she
is an FAA-certified A&P. You can download the airmen database from the
FAA.GOV website and check for certified mechanics living there (as well as
in any other country, they even separate the files for you, domestic and
foreign), or you can go to places like...
http://www.landings.com/evird.acgi$pass*81558983!_h-www.landings.com/_landings/pages/search/certs-ap.html
....and search for COUNTRY = MEXICO and off you go.
Also, if you do a little bit of research you'll find this interesting
document...
http://www.bajabushpilots.com/news-pop.php?NewsID=44
....which contains this interesting little tidbit of useful information:
"2) A&P mechanics working on US aircraft in Mexico
Requested by the BBP (Baja Bush Pilots) at the meeting, the DGAC (Dirección
General de Aeronáutica Civil), after consulting with their legal persons (at
the meeting) indicated that this requirement was not a rule or law and that
US A&P mechanics can work on US aircraft in Mexico without the presence of
or signing off by a Mexican A&P. This major change will make repairs much
simpler and less expensive for anyone who has a problem in Mexico. The DG
indicated that he will be sending a message to all ICAO airports addressing
this situation this week."
All of this is academically-speaking, of course. Don't take it personally,
I'm just trying to show the benefits of doing a bit of googledigging before
heading off in that nice Mooney of yours to a remote location in a foreign
country.
Juan
not having made arrangements/contacts
Having a local mechanic work on your plane only solves 1/2 the problem
because the plane is again illegal as soon as you get back to the
states since you would need another log entry from a U.S. mechanic. I
think its better to skip the Mexican mechanic and just have the A&P do
the work and don't let the Mexicans find out.
-Robert
  #76
Old March 23rd 06, 07:51 PM posted to rec.aviation.piloting,rec.aviation.owning
om...
way of calling for help if they get stuck
What would you suggest? Satellite phones are pretty much the only
solution that I see and they are quite expensive. They are also a
relatively recent invention (especially with respect to consumers like
us), and somehow people managed to get by without them prior to their
availability.
There are other solutions, such as portable radios of various types, as well
as arrangements to have someone come down to the location if you haven't
been heard from in x number of hours or days.
, not having made arrangements/contacts with a local mechanic in case
This is an even more bizarre thought, IMHO. Do you arrange for a local
mechanic at every location to which you fly? I sure don't. I doubt many
pilots do.
What is bizarre is reading what I said and translating that into "every
location to which you fly." That is absurd. Note that the original post
mentions a REMOTE LOCATION IN MEXICO. Enough said.
People who can afford having an A&P come down to Mexico to fix a problem
ought to be able to afford a little planning ahead for eventualities just
like this one. Academically speaking, of course.
"People who can afford"? My understanding is that Robert wasn't the one
footing the bill.
I didn't get that at all from what I read. Did the insurance company pay for
the A&P coming down to the "remote location" in Mexico to make the repairs,
including the cost of the parts? The point is there are quite a few A&P's in
Mexico proper, FAA-certified. Just because someone is Mexican doesn't mean
he/she can't do repairs on N-reg aircraft.
Juan
  #77
Old March 23rd 06, 07:54 PM posted to rec.aviation.piloting,rec.aviation.owning
And we have your name. Guess which one more people will remember?
"Jim Macklin" wrote in message
news:FdCUf.454$t22.144@dukeread08...
Then you answered the question, IF you really had a complete
repair and the A&P did make a "return to service" entry. If
he did all that and you did a test flight [you really should
not have carried a passenger, which the A&P would be] and
made the pilot's return to service after test flight, then
As for your family, my comment was about your judgment, if
you want to substitute three strangers from the beach,
that's fine with me.
BTW, since some FAA types read these groups, they have your
N number.
| Was it repaired and completely inspected or were more
| repairs done on return to the USA? The indications that
I
| had from the thread was that more repairs/inspections
were
| done on the airplane after it returned to the US. Yet
you
| carried your family after major repairs caused by
damage.
| Quoting from the original post "I was able to call an A&P
to come down
| to Mexico and swap it for me." Sadly, the other Mooney
owners wants his
| back (go figure) so yes, more repairs were also done back
home (like
| ordering a factory new aileron for me, paint etc). Yes it
was
| inspected in Mexico by the A&P doing the work and all wing
panels
| relevant to aileron control were removed before the A&P
got in the
| plane with me and we performed the test flight. I honestly
don't know
| what else to do with regard to inspection other than
having had the A&P
| look at it. I could ask Mooney if they want to send an
engineer down
| but I don't think that is going to happen.
| Jim, I'm still highly offended by your comment about my
family.
| -Robert
  #78
Old March 23rd 06, 08:13 PM posted to rec.aviation.piloting,rec.aviation.owning
Nice research.
om...
are two separate
mechanic if he/she
database from the
there (as well as
you, domestic and
interesting
| document...
information:
the DGAC (Dirección
legal persons (at
the presence of
make repairs much
Mexico. The DG
airports addressing
take it personally,
| country.
| Juan
problem, etc
1/2 the problem
back to the
U.S. mechanic. I
have the A&P do
| -Robert
  #79
Old March 23rd 06, 08:16 PM posted to rec.aviation.piloting,rec.aviation.owning
I meet people all the time who say, "Hey Jim, didn't you go
to Spartan 35 years ago?" or some other such. I always use
my real name, Google for "James H. Macklin" (use the quotes)
and I'm not the Ph.D from California.
om...
remember?
| "Jim Macklin" wrote
in message
complete
If
should
and
then
away
if
your
| N number.
that
| I
repairs/inspections
| were
Yet
| you
| damage.
A&P
| to come down
| owners wants his
back
| home (like
Yes it
| was
wing
| panels
A&P
| got in the
honestly
| don't know
| having had the A&P
| engineer down
my
| family.
| | -Robert
  #80
Old March 23rd 06, 09:34 PM posted to rec.aviation.piloting,rec.aviation.owning
Been thinking about a test flight to test any airplane after
such damage repair, before carrying passengers.
A full range of control inputs at no more than Va for the
weight, followed with autopilot operation. Then in small
steps of increasing speed up Vne with moderate control
displacement.
James H. Macklin
ATP,CFI,A&P
"Jim Macklin" wrote
in message news:gnDUf.476$t22.101@dukeread08...
use
quotes)
| om...
| remember?
|| "Jim Macklin"
wrote
| in message
| complete
entry.
| If
| should
| and
| then
| away
| if
| your
|| N number.
more
| that
|| I
| repairs/inspections
|| were
| Yet
|| you
|| damage.
| A&P
|| to come down
Mooney
|| owners wants his
| back
|| home (like
| Yes it
|| was
| wing
|| panels
| A&P
|| got in the
| honestly
|| don't know
|| having had the A&P
an
|| engineer down
| my
|| family.
|| | -Robert
Cirrus chute deployment -- an incredible story Michael182/G Instrument Flight Rules 48 July 14th 05 03:52 PM
My first lesson Marco Rispoli Aerobatics 3 May 17th 05 08:23 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
