F18 dogfighting
Old March 26th 06, 04:37 PM posted to rec.aviation.military.naval
Default F18 dogfighting
TV wrote:
The question speaks to turning engagements in the visual arena.
Objectively, the F/A-18 is a better turning fighter than the F-14A, but
thrust to weight of the B/D makes it a more difficult opponent.
The lack of compressor stalls in the B/D also probably helps .
Has the Hornet had a history of engine problems? Or were you referring
to the problems of older F-14's?
Old March 26th 06, 07:52 PM posted to rec.aviation.military.naval
Doug "Woody" and Erin Beal wrote:
Most F-14 squadrons are getting full transitions from Tomcat to F/A-18E/F.
Of course, some aviators are always left on the table during the transition.
But is it so simple now, in the times of Fleet Response Plan?
Actually, the F/A-18E/F FRSes (VFA-122 or VFA-106) get the first Super
Hornets with markings of those new squadrons (VF becoming VFA) some
weeks before the squadron is back from their last F-14 deployment.
Right, those birds are formally assigned to the FRS then. But later on,
when the cruise ends, the squadron has to remain in readiness for any
surge deployments for some time.
For example, when VF-11 and VF-143 returned from ther last Tomcat
deployment, F/A-18E/Fs with VFA-11 or VFA-143 markings were already
flying, but F-14Bs were still seen at Oceana, as the "surge deployment
readiness" asset.
So, sorry, but this is still unclear to me - which were the real
squadron staffs - these still flying Tomcats, or those already
transitioning to Rhinos? I guess the latter was finally replacing the
former, so indeed, not all aviators were transitioning...
Kind regards,
Jacek
Old March 26th 06, 08:58 PM posted to rec.aviation.military.naval
Default Who Will Transition to Hornets and Who Won't? [was F18 dogfighting]
the first thing we need to remember here is that the unclassified specs
tell us very little about
missile performance. e.g. what is the burn time - how well can it hack
a beam manouver or
chaff and jamming - what kind of spike are you getting of a tomact
shooting this thing - what
sort of end game maneuver can it handle. - how much range do you kill
with an early
drag or beam. I'm not saying it is a bad missile - i'm sure Woody would
agree that depending
on your shot doctrine, an AMRAAM aware opponent can trash shots quite
easily if he
understands how the AMRAAM works. I'm just saying that with a "smart"
bandit (if there are
any left) he may be able to drag out and defeat these long range shots
and be able to beam
and get to the merge. Guys can sometimes do that to an AMRAAM shooting
Hornet in training
so I'm sure it could happen to a Phoenix shooter too. I'm not sure but
I would guess that the
missile is more designed for long range shots against less manouverable
bombers.
Old March 26th 06, 10:54 PM posted to rec.aviation.military.naval
On 3/26/06 12:52 PM, in article
readiness" asset.
Kind regards,
Jacek
Jacek,
Strictly case by case.
When a squadron transitions, just as you noted, the whole squadron goes
through the FRS for the CAT-2 syllabus.
For instance, if they're returning from deployment, their senior Department
Heads and JO's will rotate out to their follow-on assignments. Some of them
will end up transitioning through an FRA instructor tour.
The remainder of the squadron will stay for the transition, complete the FRS
together, pick up their new CAT-1 pilots and WSO's, and continue to a
follow-on deployment or sustainment.
There's no set formula though.
--Woody
Old March 26th 06, 11:21 PM posted to rec.aviation.military.naval
The delivery of a squadron's-worth of F/A-18E or F takes time. The first
examples you see are usually flown at VFA-122 to train whatever Super Hornet
pilots are on the pipeline at the time. When the core pilots of the
transitioning squadron are back from deployment, a few more birds will
hopefully be available, and the squadron will begin to take shape, under the
RAG's wings. Things start to get "ship-shape" when they get their
safe-for-flight certification, which means they will be responsible for
their own flights henceforth.
_____________
José Herculano
Old March 27th 06, 07:50 AM posted to rec.aviation.military.naval
Mike Weeks wrote:
There are only two left now, VF-31 and 213, and as been reported, one
will transition immediately, one later; guess which one has the
"immediate duty" as part of FRP? The latter squadron.
Hello Mike!
I am not sure if I understood you correctly: As far as I heard in the
news, VF-213 was to enter the transition in April 2006 (some photos of
the brand new VFA-213 CAG bird can be seen at:
http://www.alert5.com/gallery/VFA-213 ), whereas VF-31 (the third
Tomcat squadron to transition to F/A-18E; VFA-22 giving them their Es
and getting Fs instead) is going to stay within the Air Wing for surge
phase until October. So that would be the other way round than you
said...
When VF-213 is out of CVW-8, another Oceana squadron might be
temporarily assigned to fill the gap. I am not sure about the status of
VFA-15 - it was slated to transition in FY 2006, but now it looks
VFA-105 took its place.
Best regards,
Jacek Zemlo
Old March 27th 06, 08:22 PM posted to rec.aviation.military.naval
Hello Mike!
said...
Best regards,
Jacek Zemlo
Jacek -
By "latter" it was simply meant whichever CVW-8 F-14 squadron would
transition second, that's all.
MW
Old March 28th 06, 04:34 PM posted to rec.aviation.military.naval
Mike Weeks wrote:
Jacek -
MW
Aaah! Sorry, I did not notice "the latter" refers to "one later", not
strictly to VF-213;-)))
Jacek Z.
Dogfighting US jets make villagers run for cover, By Nick Britten Otis Willie Military Aviation 0 January 15th 04 10:10 PM
AIM-54 Phoenix missile Sujay Vijayendra Military Aviation 89 November 3rd 03 09:47 PM
