Capstone
Old May 28th 04, 09:51 AM
Dave S
I dont understand why anonymous is such a point of contention. You have
to have a license plate on your car, dont you? and an N number on your
plane? A mode S transponder is the electronic equivalent of a license
plate. Even if it DOES seem big brother-like. Flying is a priveledge,
which can be granted or disallowed. I am of the mindset that positive ID
while excercising that priveledge is perfectly acceptable.
Ok.. if they want to charge fee's for service.. then let them charge..
they do in europe, dont they? Of course, if it costs 100 bux to file a
flight plan, I would expect everyone to stop filing flight plans.. (I'm
sure a more reasonable (for GA) solution would be a fee based on seats
or gross weight).
And the "stop the noise" zealots already CAN get your N-Number. With a
Mark 1 Mod A optical sensor (Eyeball) and pair of binoculars. While I am
a member of AOPA and I do pay my dues, I really dont see how GA/AOPA
fighting mode S tooth and nail is really doing us any benefit. There are
other issues that are more important in my mind (controller shortages,
inconsistent enforcement and PFR's) and that need to be addressed.
Dave
Scott Moore wrote:
Bob Noel wrote:
In article yjstc.9901$Ly.7087@attbi_s01, Scott Moore
o Allow "anonymous mode-s", and so remove the light pilot/AOPA objection
to mode-s ? This has been proposed many times in many places. Apparently
the FAA would rather die than this, but why are they (apparently) going
to allow UAT to so do, but not mode-s ?
Mode-S doesn't have a provision for "anonymous." And changing
the specs for Mode-S would be, ahem, challenging. It's not
actually an FAA issue.
Well, I do understand the issue, but not why anonymous is so hard. The
shop programs the N number, right ? What is to prevent them from declaring
a "universal" N number (the equivalent of 1200) and just programming all
"protestants" with that on request ?
o Require UAT on airlines, so that everyone speaks the same language,
and
UAT eventually replaces mode-s as a more advanced method ? I could
hardly
blame the airlines for fighting that one. The FAA just got through
requiring
them to buy into mode-s. It would put the airlines into the position
of buying the "black box of the month" as the FAA changes with the wind.
bingo. The airlines had to install expensive tcas systems and
have to have Mode-S for that and other systems (for flight in Europe
and other areas). The airlines will fight tooth-n-nail requirements
to install duplicative systems.
In any case, it appears that the FAA, the AOPA and the airlines have all
already come to the solution:
not much of a solution...
Old May 28th 04, 01:44 PM
Richard Kaplan
"Scott Moore" wrote in message
news:yjstc.9901$Ly.7087@attbi_s01...
fees and misuse (imagine the "stop the noise" zelots having the ability
to get an N number automatically).
This is already possible at least for IFR flights if you sign up for
www.fboweb.com and do an "Area Track" -- just enter a zip code and desired
radius and you will see all the IFR flights and their altitudes,
destinations, and registered owners.
Richard Kaplan, CFII
www.flyimc.com
Old May 28th 04, 01:51 PM
Richard Kaplan
Light airplanes unlucky enough to have high altitude capability would
need both mode-s and UAT. This would also apply to a huge number of
Do you know the definition of high-altitude capability?
A turbocharged piston airplane may very well be capable of flying above
FL300 although it is rare for piston airplanes to actually do so.
www.flyimc.com
Old May 28th 04, 02:04 PM
Teacherjh
Ok, what's a UAT? acronymfinder.com doesn't have it (or I don't recognize it
there)
Jose
(for Email, make the obvious changes in my address)
Old May 29th 04, 01:35 AM
Gerry Caron
newstttc.5331$eY2.1195@attbi_s02...
You're confusing the "Flight ID" variable with the ICAO 24-bit ID. For most
GA aircraft, both are programmed at install. The flight ID is set to the
N-number and the 24-bit ID is set. In air transport A/C, the Flight ID can
be set from the flight deck to reflect the current Flight ID.
The difference is that the Mode-S system doesn't care what the N-number or
Flight ID is (tho the controller might), it's just a variable to be
transmitted. The ICAO 24-bit ID is a different story. It is the "network"
address for your transponder. It is embedded in all Mode-S communications
to and from your transponder. For the system to work, the 24-bit IDs have
to be unique. For comparison, you can think of it as a hard-coded IP
address.
If you've done much network support, you'll know what kind of problems occur
when there are duplicate addresses in the system. To insure the system
works, ICAO assigned blocks of the 24-bit addresses to each member state,
who is then responsible for assigning them to specific aircraft. The FAA
assigns one to an aircraft when it is registered (whether it has a Mode-S
transponder or not). Look in the registry database if you want to know
yours.
The problem with 'anonymous' IDs is managing them so that you can have a
randomly assigned ID without a chance of duplication. You could conceivably
create some Mode-S equivalent to DHCP, but that is a) non-trivial, and b)
wouldn't necessarily provide anonymity. In the end, it would be a lot of
work for a feature that would just make the units more expensive to satisfy
a small vocal segment of the customer base.
Gerry
Old May 29th 04, 02:56 AM
Gerry Caron
I cleaned up my language a bit, then sent my tirade off to Phil Boyer :-)
He gave me a short note, then promised me an "in depth" note from their
staff expert on the subject. I believe the gist of it is that the AOPA
has fought tooth and nail to keep the mode-s requirement out of light
airplanes due to individual airplane ids and their potential for for
True. Cost is also an issue.
I don't mind adding a UAT, if that is what it takes. I mind the apparent,
from reading the FAA material, dogma that light airplanes shall have
UAT and big airplanes shall have mode-s, and the FAA shall act as the
bridge between the two (ha !).
It's not FAA dogma. It's a reasonable compromise to gain concensus from two
diverse groups, each of which has its own needs within the airspace. The
FAA actually hasn't mandated either one for any specific group. The
statement that GA will have UAT and airliners have 1090ES, is merely a
generalization of expected market response. There is nothing that requires
anyone to select one over the other. Nor is there anything that prevents
you from equipping with both.
All kinds of "what to do" things occur to me, but each seems to be
centered around a group with an interest who does not want to move.
Mode-Select (Mode-S) was designed twenty years ago for a very specific set
of needs. It does that very well. It is an addressed communication system.
Trying to make it do something for which it wasn't designed could compromise
the system or at best add a lot of expense and complexity.
UAT was created about 8 years ago specifically to support ADS-B, TIS-B, and
FIS-B. Note the "-B" in all the systems -- that stands for broadcast. UAT
is a non-addressed broadcast system. Basically it's a half-duplex radio
modem. When you transmit, you have no ability to determine who is
receiving. Likewise, in receive, you'll receive anybody within range.
o Require UAT on airlines, so that everyone speaks the same language, and
UAT eventually replaces mode-s as a more advanced method ? I could hardly
requiring
Airlines have Mode-S because it's a required part of a TCAS system, which is
mandated. TCAS will not be going away. ADS-B may augment TCAS, but it
won't replace it. Adding ADS-B to the Mode-S system is the most
cost-efficient route if you already have the Mode-S/TCAS equipment.
o Require light airplanes to have both ? Time for us to scream, I guess,
but
that is where I am headed anyways, since I was stupid enough to buy mode-s
(for TIS).
As I said before, you're not required to have either one. And I wouldn't
say you are stupid for buying into Mode-S for TIS. TIS is a very good
service. While it is limited to areas of Mode-S radar coverage, it allows
you to see any aircraft the radar is capable of tracking. While ADS-B
doesn't need radar, if the other guy isn't equipped, he's invisible.
o Airlines have mode-s, we have UAT, and the friendly FAA will translate
between the two, but only under radar control (neatly severing the
non-radar
reliant feature off ADS-B). The theory is, I guess, that airlines allways
travel under radar so it won't matter in any cass.
Major point here. The ADS-B repeater/translator is NOT radar based. It is
a 1090MHz receiver and a UAT receiver to "collect" ADS-B broadcsts from
aircraft in the vicinity. The data is then broadcast out on both 1090 MHz
and UAT (this broadcast is called TIS-B -- this is not the TIS you currently
have.) These are relatively cheap (a couple orders of magnitude cheaper
than a radar) autonomous ground stations that can be stuck pretty much
anywhere, including places where there is no radar coverage. This is
exactly what they did in Alaska for Capstone.
o Light airplanes unlucky enough to have high altitude capability would
jets and even heavy aircraft, since there are a lot of light jets and
passenger aircraft servicing smaller, non-radar fields.
No. You can pick one, or neither, or both. While you may need a basic
Mode-S transponder for some high altitude airspace (RVSM), that does not
mean you have to have a 1090ES ADS-B system.
A fine point here. Your GTX330 is a long way from a 1090ES ADS-B system.
It currently provides only elementary surveillance support. It would
require an upgrade to support full ADS-B broadcast. Once you did that, you
could provide ADS-B broadcasts, but you'd still have to get a 1090 MHz
receiver to be able to receive ADS-B or TIB-B over 1090. (Your TIS data
comes up from the ground radar on 1030 MHz using the Mode-S comm-b
protocol.) Adding that receiver will not be cheap. The receiver and
transponder upgrade will likely cost as much or more than a UAT.
Gerry
Old May 29th 04, 06:23 AM
Scott Moore
address.
yours.
Gerry
Its simple. An installing shop gets a block of numbers to issue, then gets
another block when the numbers run out. And they keep no record of the
numbers. There is a need for the numbers to be unique, but they don't have
to be indicative of the particular aircraft. Even if the FBI or whatever
insists they have to be trackable, they can be kept on the books of the
installer to be revealed by court order. As it is, publishing them online
sure isn't going to be anonymous, but that system is easily changed. We
aren't out of numbers, and you could request a change to an anonymous id,
while turning your current ID back in, to be added back to the pool.
The system won't change because the FAA and powers that be don't want it
to change.
Again, I doubt the working requirements of a UAT are much different. It
probally has a need for a unique code as well.
Old May 29th 04, 07:16 AM
Scott Moore
mode-s ("squitter") is also designed with these properties. The proposal to
add ads-b to mode-s originally had the mode-s transmitter start transmitting
asyncronously if the unit was not swept within a given period of time. Ie.,
lacking radar, the unit would switch to true ads-b mode.
I would say that at this state of the technology, that mode-s is going to be
the most cost effective for everyone. UAT is brand new, untried technology.
mode-s already has a lot of units and support. UAT is simply going to cost
more, for a while.
Having a defacto requirement that you need both mode-s and UAT on a light
airplane is certainly not going to help costs for light airplanes. And it
will be the defacto requirement once pilots find out they really should
have both to prevent being run over by a transport aircraft under all
conditions, including no radar and radar shadows.
Still means that you need a ground based translator to get from light airplanes
to transport aircraft. ADS-b's best feature was that it didn't need to depend
on ground stations. That ground station adds a new point of failure to the
system, as well as being a fickle one. I don't care how high tech digital
you get, that signal is not going to go through a mountain, whereas I have
never heard of a midair collision where the colliding aircraft went through
a mountain, ie., generally you have line of sight for an aircraft you are
colliding with.
When ADS-B is required on class A airspace, then high altitude light planes
are going to need it as well. Unless you can think of a class A requirement
that was excepted for light aircraft ?
Gerry
Good point (didn't know that), but it isn't going to change the fact that you
will need both systems. No, the airlines are not going to care, they simply
want uncontrolled airplanes out of their way no matter what. But as the
ramifications of having two "separate but equal" ADS-B systems work in,
its going to be understood that you better have both systems to be really
safe.
I disagree that it had to be this way. The FAA cannot even create one standard
for a brand new system ? No, what they did is throw a special interest party,
and give everyone what they wanted (even though they don't work together).
It stinks. Sorry, it just does.
"We like standards. In fact, we like them so much we think everyone should
have their own..."
