"Newps" wrote in message
. .. Officially a retractable 182 is an R182. The turbo model is the TR182. It is common to see 182RG and T182RG but to Cessna these are wrong. Doesn't surprise me. I just wanted to alert John that there are people like me going around using unofficial terms. ![]() |
![]() "Peter Duniho" wrote in message ... "Newps" wrote in message . .. Officially a retractable 182 is an R182. The turbo model is the TR182. It is common to see 182RG and T182RG but to Cessna these are wrong. Doesn't surprise me. I just wanted to alert John that there are people like me going around using unofficial terms. ![]() For FAA/ATC purposes, it's designator is C82R. |
NW_PILOT wrote:
TR 182 Exelent Airplane! If we could rate Usenet posts like customers do for Amazon.com's product reviews, I would have to choose, "Not Helpful." -- Peter |
We have run both the R182 and the TR182, and found that the
turbo and its systems gave some trouble. The exhaust piping runs hotter and springs more leaks, the wastegate linkage can be troublesome, and the carb is really hard to get at, as is the dual magneto. Many scratches on the arms and hands and a temptation to use inappropriate language. The gear needs watching. The pivot has to be kept properly adjusted or the airplane's weight ends up on the wrong place on the trunnion and cracks it, letting out the brake fluid which runs through a channel drilled in it. The nosegear has a locking pin that's subject to cracking and falling out. That's all from my standpoint as a mechanic. If you have $30K to spend, someone else will fuss with those problems. From my other position as a pilot, the turbo makes high-altitude cruising possible, if you have oxygen, and this airplane is a sweetheart to fly, with no bad habits other than a wicked float if you don't get intelligent about approach speeds versus weight, and that float usually means a faster-than-normal touchdown and flat-spotted tires because the tires are small and the brakes are powerful. The airplane's Vso is 37 knots, so you have to land it when it's ready to land. Not before. The 15x6.00-6 tires cost a lot more than the ordinary 6.00-6's. Dan |
I've owned a TR182 for about five years. Here are a few impressions:
1) The turbo is HOT, and the heat causes some engine problems. I've replaced the turbo once, and had various waste gate and hose problems along the way. Not a huge concern, but has probably averaged $500-700 a year over the five years. 2) The oil cooler is not efficient. Climb out on a hot day (especially in Colorado, where I live) generally has to be done as a step climb to keep the oil cool enough. There is an STC to add an additional cowling hole in front of the oil cooler, but I believe it would trim a few knots off the plane as well. 3) Given that the engine runs hot, it is a good idea to try and avoid shock cooling. Plan ahead. 4) There is a carb heat knob. I've never used it. (See engine runs hot, above....) 5) Always, always, always let the engine idle for at least four minutes before shutdown to keep the turbo alive another day. 6) The turbo is, of course, a normalizer. I get 31" on climbout up to about 8,000 feet. 28" at about 10,000. 17" at FL180. Obviously different numbers in summer and winter, but that's a general idea. 7) Cruise speeds do not really match the book, at least in my plane. I get roughly 140 at 5.000, 150 at 10,000, 160 at 17,000. 8) Although everyone talks about it, I've never had a landing gear problem, except one self-induced problem when I did a carrier landing after encountering some low wind shear and I got a hairline crack in part of the gear. That was expensive - around $1,500 I believe. 9) I don't have a lot of experience with other planes, but I have to say that the 182 is a very simple IFR platform. Very stable, trim works excellently, easy to nail the ILS almost hands off. 10) Along the same lines, it is a very forgiving airplane. Having the gear to drop is like being able to throw out an anchor - makes speed management and descents pretty simple. 11) It can haul a lot of weight. Although I have not, of course, ever exceeded the weight part of the W&B, no matter what load has been in the plane I have been able to get 600 fpm climb out of my 5,000 foot airport on a hot summer day. Alone on a cold winter day I can be at 17,000 feet in less than 15 minutes. 12) Fit and finish is typical of a 25 year old Cessna. Lots of air leaks. Luckily it has a good heater. Don't expect to stay dry flying through heavy rain. 13) I've run the engine at all types of settings, but I feel most comfortable about protecting the cylinders by running about 100 degrees rich. This gives me fuel burn of about 15gph at 10,000 and about 13 gph at 17,000. You can certainly run it much leaner, but I believe it will show up in the annual compression checks. By the way, the $160 K is high (although I wish it wasn't). There's probably more, but I can't think of it off the top of my head. Feel free to email me off line. Michael |
ups.com... We have run both the R182 and the TR182, and found that the turbo and its systems gave some trouble. The exhaust piping runs hotter and springs more leaks, the wastegate linkage can be troublesome, Yup, that matches my experience with my turbocharger. But wouldn't it be the same issue whether we're talking about a TR182 or a T210? and the carb is really hard to get at, as is the dual magneto. No carb on my airplane, but it has the dual magneto. Tucked under the turbo discharge of course. Mechanics just *love* working on that thing. ![]() Many scratches on the arms and hands and a temptation to use inappropriate language. Like I said. ![]() The gear needs watching. The pivot has to be kept properly adjusted or the airplane's weight ends up on the wrong place on the trunnion and cracks it, letting out the brake fluid which runs through a channel drilled in it. The nosegear has a locking pin that's subject to cracking and falling out. Isn't the retractable gear on the 182 similar to the gear on the 210? That was my point, that yes these problems exist, but I think that going with a TR182 doesn't reduce one's exposure, compared to a T210. That's all from my standpoint as a mechanic. If you have $30K to spend, someone else will fuss with those problems. From my other position as a pilot, the turbo makes high-altitude cruising possible, if you have oxygen, After having flown my turbocharged airplane for almost 12 years now, I would not own a normally-aspirated airplane except as a local-hop toy. The turbo is just WAY too useful, whether for high-altitude airports or the big boost in cruise speed at altitude. and this airplane is a sweetheart to fly, with no bad habits other than a wicked float if you don't get intelligent about approach speeds versus weight, Heh...never occurred to me to complain about float for any Cessna. But yes, I suppose if you land with way too much speed, you'll spend your sweet time slowing down. Heck, in my early years of flying, I once managed to use up nearly all of an 1800' runway in a C172. No, there was no 50' obstacle. So anything's possible. But then that's an issue with any airplane. Too-high approach and landing speeds result in much-longer-than-necessary landing distances. I wouldn't call that a "bad habit" on the part of the 182. If anything, I'd say the 182's short-field capability is one good selling point over the 210 (which is no runway hog itself). Pete |
I haven't owned a TR182 but I did own a 182 for 7 years and now a
Bonanza. After reading the info below I cannot believe anybody would pick the TR182 with these deficiencies listed below. I'm assuming the OP had to have a turbo because the list below just screams "don't buy me." So you are considering a slow plane that you can't climb because it will burn up. It leaks air like a sieve and oh, by the way, don't land too hard or you'll crack the gear and all the brake fluid will leak out. It's no wonder I never considered a Cessna when it was time to upgrade. Michael 182 wrote: I've owned a TR182 for about five years. Here are a few impressions: 1) The turbo is HOT, and the heat causes some engine problems. I've replaced the turbo once, and had various waste gate and hose problems along the way. Not a huge concern, but has probably averaged $500-700 a year over the five years. 2) The oil cooler is not efficient. Climb out on a hot day (especially in Colorado, where I live) generally has to be done as a step climb to keep the oil cool enough. There is an STC to add an additional cowling hole in front of the oil cooler, but I believe it would trim a few knots off the plane as well. 3) Given that the engine runs hot, it is a good idea to try and avoid shock cooling. Plan ahead. 4) There is a carb heat knob. I've never used it. (See engine runs hot, above....) 5) Always, always, always let the engine idle for at least four minutes before shutdown to keep the turbo alive another day. 6) The turbo is, of course, a normalizer. I get 31" on climbout up to about 8,000 feet. 28" at about 10,000. 17" at FL180. Obviously different numbers in summer and winter, but that's a general idea. 7) Cruise speeds do not really match the book, at least in my plane. I get roughly 140 at 5.000, 150 at 10,000, 160 at 17,000. 8) Although everyone talks about it, I've never had a landing gear problem, except one self-induced problem when I did a carrier landing after encountering some low wind shear and I got a hairline crack in part of the gear. That was expensive - around $1,500 I believe. 9) I don't have a lot of experience with other planes, but I have to say that the 182 is a very simple IFR platform. Very stable, trim works excellently, easy to nail the ILS almost hands off. 10) Along the same lines, it is a very forgiving airplane. Having the gear to drop is like being able to throw out an anchor - makes speed management and descents pretty simple. 11) It can haul a lot of weight. Although I have not, of course, ever exceeded the weight part of the W&B, no matter what load has been in the plane I have been able to get 600 fpm climb out of my 5,000 foot airport on a hot summer day. Alone on a cold winter day I can be at 17,000 feet in less than 15 minutes. 12) Fit and finish is typical of a 25 year old Cessna. Lots of air leaks. Luckily it has a good heater. Don't expect to stay dry flying through heavy rain. 13) I've run the engine at all types of settings, but I feel most comfortable about protecting the cylinders by running about 100 degrees rich. This gives me fuel burn of about 15gph at 10,000 and about 13 gph at 17,000. You can certainly run it much leaner, but I believe it will show up in the annual compression checks. By the way, the $160 K is high (although I wish it wasn't). There's probably more, but I can't think of it off the top of my head. Feel free to email me off line. Michael |
Michael 182 wrote:
6) The turbo is, of course, a normalizer. I get 31" on climbout up to about 8,000 feet. 28" at about 10,000. 17" at FL180. Obviously different numbers in summer and winter, but that's a general idea. Interesting. My Bonanza V35 is equipped with a Tornado Alley turbo-normalized IO-520 and MP remains at 29.92 (top of the green arc) from sea level to roughly FL200. Above this altitude, MP begins to drop off. I am not a qualified mechanic, nor do I have years and years of aviation experience in many different aircraft, but the idea of losing MP at 8,000 feet in a turbo-equipped aircraft just doesn't seem right to me. -- Peter |
![]() Peter R. wrote: Michael 182 wrote: 6) The turbo is, of course, a normalizer. I get 31" on climbout up to about 8,000 feet. 28" at about 10,000. 17" at FL180. Obviously different numbers in summer and winter, but that's a general idea. Interesting. My Bonanza V35 is equipped with a Tornado Alley turbo-normalized IO-520 and MP remains at 29.92 (top of the green arc) from sea level to roughly FL200. Above this altitude, MP begins to drop off. I am not a qualified mechanic, nor do I have years and years of aviation experience in many different aircraft, but the idea of losing MP at 8,000 feet in a turbo-equipped aircraft just doesn't seem right to me. Smaller turbo, yet another reason to scratch your head and say why? |
Some additional comments to this excellent list.
I had a turbo normalized Mooney. Did not have an inter cooler which would have helped reduce some heat especially CHT on climb out. I'm here in Houston and in summer time I'd climb 10-15 mph faster than published figures to keep engine well below red line (baby that baby). This of course caused more time to altitude. At destination I'd pull MP back 5 or so inches (keeping good power on engine to prevent cooling shock) and run AS up to yellow line for descent. My block time was as good or better than published even with the very slow climb. On comment #5. 100% on the mark. This relates directly to $ and down time to replace the turbo. Cool that baby off before shut down. Additional. Don't over boost the engine. Again more $ exposure and possible failure when you don't want a failure if you have stressed the engine. The Bo's a good bird. Most accidents in it are related to pilot proficiency and bad decisions. I'd get a pencil and paper and lay out the good and bad of the 210-182-Bo for my requirements before I put my money down. I've got time (and instructed in) 182-210 and a little in Bo. Also T-34 time). All good birds if maintained properly. If I were going to lay out hard cash I'd go fly (rent) each bird that I didn't have time in and fly it on a typical mission to see how it fit my requirements. Keep the fan turning and the beer cold ![]() Big John `````````````````````````````````````````````````` ````````````````````````` On Mon, 27 Mar 2006 10:28:26 -0700, Michael 182 wrote: I've owned a TR182 for about five years. Here are a few impressions: 1) The turbo is HOT, and the heat causes some engine problems. I've replaced the turbo once, and had various waste gate and hose problems along the way. Not a huge concern, but has probably averaged $500-700 a year over the five years. 2) The oil cooler is not efficient. Climb out on a hot day (especially in Colorado, where I live) generally has to be done as a step climb to keep the oil cool enough. There is an STC to add an additional cowling hole in front of the oil cooler, but I believe it would trim a few knots off the plane as well. 3) Given that the engine runs hot, it is a good idea to try and avoid shock cooling. Plan ahead. 4) There is a carb heat knob. I've never used it. (See engine runs hot, above....) 5) Always, always, always let the engine idle for at least four minutes before shutdown to keep the turbo alive another day. 6) The turbo is, of course, a normalizer. I get 31" on climbout up to about 8,000 feet. 28" at about 10,000. 17" at FL180. Obviously different numbers in summer and winter, but that's a general idea. 7) Cruise speeds do not really match the book, at least in my plane. I get roughly 140 at 5.000, 150 at 10,000, 160 at 17,000. 8) Although everyone talks about it, I've never had a landing gear problem, except one self-induced problem when I did a carrier landing after encountering some low wind shear and I got a hairline crack in part of the gear. That was expensive - around $1,500 I believe. 9) I don't have a lot of experience with other planes, but I have to say that the 182 is a very simple IFR platform. Very stable, trim works excellently, easy to nail the ILS almost hands off. 10) Along the same lines, it is a very forgiving airplane. Having the gear to drop is like being able to throw out an anchor - makes speed management and descents pretty simple. 11) It can haul a lot of weight. Although I have not, of course, ever exceeded the weight part of the W&B, no matter what load has been in the plane I have been able to get 600 fpm climb out of my 5,000 foot airport on a hot summer day. Alone on a cold winter day I can be at 17,000 feet in less than 15 minutes. 12) Fit and finish is typical of a 25 year old Cessna. Lots of air leaks. Luckily it has a good heater. Don't expect to stay dry flying through heavy rain. 13) I've run the engine at all types of settings, but I feel most comfortable about protecting the cylinders by running about 100 degrees rich. This gives me fuel burn of about 15gph at 10,000 and about 13 gph at 17,000. You can certainly run it much leaner, but I believe it will show up in the annual compression checks. By the way, the $160 K is high (although I wish it wasn't). There's probably more, but I can't think of it off the top of my head. Feel free to email me off line. Michael |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
