Cracked ribs
Old March 30th 06, 05:05 AM posted to rec.aviation.piloting
Default Cracked ribs
Piper has a new service bulletin, SB1161 that calls for inspection of
the rib just inboard of the landing gear and aft of the main spar.
http://www.newpiper.com/company/Publ...20Insp-Mod.pdf
The SB requires putting the plane on jacks and removing the gear side
brace and bracket.
As 04T is in for the annual, we figured it was a good time to have the
SB performed. It turns out we have cracks on both sides of the rib and
they're bad enough that the repair kit announced in the SB can't be
used. Solution: two new ribs. Cost for parts: 1.1 AMU. Labor is
unknown at the moment but the shop is putting together an estimate.
At least I can split the repair bill three ways...but it's still gonna
put a dent in the flying funds.
Jack Allison
PP-ASEL-Instrument Airplane
Arrow N2104T...soon to have two new zinc chromated ribs!
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old March 30th 06, 05:06 AM posted to rec.aviation.piloting,rec.aviation.owning
Jack Allison wrote:
Oops...meant to post in r.a.o...bah, stupid fingers!
brace and bracket.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old March 30th 06, 04:47 PM posted to rec.aviation.piloting,rec.aviation.owning
Augh! That really, really sucks, Jack.
Two good things:
1. It sounds like the kind of thing that only gets worse over time.
You are wise to get it over and done with now.
2. You caught it far enough before OSH as to not interfere with your
trip. (Well, unless your shop REALLY sucks.) THAT could have ruined
your whole summer.
I'll bet this problem is going to rival the Lycoming crankshaft AD by
the time all is said and done. There are a LOT of Piper retracts out
there.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 30th 06, 05:16 PM posted to rec.aviation.piloting,rec.aviation.owning
Bummer on the rib.
Glad you did the inspection though.
After the repair is done you'll sleep better.
"Jack Allison" wrote in message
brace and bracket.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old March 30th 06, 05:30 PM posted to rec.aviation.piloting
On Wed, 29 Mar 2006 20:05:00 -0800, Jack Allison
wrote in
Have you researched the cost of used ribs?
Old March 30th 06, 09:29 PM posted to rec.aviation.piloting
wrote in
Wouldn't metal fatigue be an issue?
__________________________________________________ _______________
Too much time on your hands? Waste it here!
www.crazydatingstories.com
www.crazykidstories.com
www.crazywarstories.com
Old March 31st 06, 04:00 AM posted to rec.aviation.piloting
Man, that is just painful.
Old March 31st 06, 07:00 AM posted to rec.aviation.piloting
Bad luck Jay. Do they have a theory as to how/why the cracks developed?
....Edwin
"Once you have flown, you will walk the earth with your
eyes turned skyward, for there you have been, there you
long to return."-- da Vinci ... www.shreve.net/~elj
Old March 31st 06, 07:07 AM posted to rec.aviation.piloting
A potential problem with used ribs is how old they are. Newer ribs with
the proper date code don't require the inspection. Replacing the ribs
does the same as applying the repair kit...no more inspection necessary.
IMHO, used parts are ok for some things...but not for this job on our
plane. I'd rather put brand new ribs in despite the higher cost.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Old March 31st 06, 07:14 AM posted to rec.aviation.piloting,rec.aviation.owning
Yes, suckage level is extremely high. Right at the one year ownership
point too. Oh well, I'll have some great show and tell pictures for
Oshkosh. What an excuse to have folks crawl around in the grass under
my plane :-)
Two good things:
Yep, and if it becomes an AD, I'd expect we will have permanently
complied by replacing the ribs.
your whole summer.
Also very true.
there.
It's going to be interesting to see how many folks opt for performing
the SB and how many find cracks. I only know of one other aircraft that
found cracks (Dick Russ's Lance)...but it's still very early with this
one.
I'm also very interested to see if this does become an AD.
Jack Allison
Arrow N2104T
- Leonardo Da Vinci
Cracked cylinder: Typical cause? Peter R. Owning 19 October 9th 04 04:24 AM
Testing Stick Ribs Bob Hoover Home Built 3 October 3rd 04 02:30 AM
How much to replace cracked crankshaft in 1972 skyhawk O-320-E2D engine Dave Gribble Owning 2 February 4th 04 08:30 AM
Heat treating wing ribs Holger Stephan Home Built 13 February 3rd 04 11:59 PM
Is a cracked vent SCAT tube an urgent problem? Ben Jackson Owning 18 September 20th 03 03:31 AM
