I understand that it is not automatic. that you would have to do the
paperwork, inspections, approvals, etc. But how do people make alterations to their Standard certification gliders? If I want to add winglets to my LS-3a, you are saying that it cannot be done (legally, of course)? Confused, Larry " wrote in message : "01-- Zero One" wrote: If I want to do major modifications to my "Standard" aircraft (ie, wing extensions, winglets, tailplane redesign, etc.), does it not then become "Experimental"? You can't just make the mods and assume it will be legal and flyable as an experimental. There are three common types of Experimental Certifications. Amateur Built is the best known, and it's not available unless it's amateur built it and an amateur did 51% of the building tasks. Exhibition and Racing is the next most common, and it's the category in which most factory built gliders without a standard type certificate are registered (e.g. my Ventus C). It's my understanding that it's not available if the aircraft ever had a standard registration. The last is research. At least in theory, you could modify an aircraft with a standard registration and get it into this experimental category, but you wouldn't want to. The requirements, paperwork and limitations on flight are extremely onerous. -- T o d d P a t t i s t - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) |
"T o d d P a t t i s t" wrote in message ... "01-- Zero One" wrote: No, I'm not saying it can't be done legally. I was commenting on the conversion process from a standard type cert to experimental. As far as I can tell, that's extremely difficult to near impossible. (I'd be interested in hearing from anyone who's done it.) However, there are other routes to modifications of a standard certified aircraft. If the proposed change is a major modification under Part 43, you'll need a 337 approval or a Supplemental Type Certificate from the FAA. If not, then it's easy. -- T o d d P a t t i s t - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) I once owned an SGS 1-23 that had had the wing extended. The tip extensions were removable. Due to this mod the aircraft was converted from "Standard" to "Experimental, Exhibition and Racing". The most interesting thing about this airworthiness certificate was that it specifically stated that the aircraft reverted to "Standard" when the tips were removed. To my knowledge this "dual certification" was a unique case. This was done quite a while ago, and by someone (Paul Bickle) with impeccable credentials and very good FAA contacts. Modern era "Experiment" operating limitations are supposed to have an item stating that: "The cognizant FAA FSDO must be notified, and their response received in writing, prior to flying this aircraft after incorporation of a major change as defined by Part 21.93". This requirement is the substitute for the 337. (I personally would seek their advice and okay before performing the mod to avoid unpleasant, and expensive, surprises.) |
Why doesn't somebody cook up an inspection plan, run it by the FSDO for an
STC? Make a list of inspection items and extend life 500 hours or 1 callendar year. If I owned one of these. I'd look at this as an option........ -- Have a great day Scott "Michael McNulty" wrote in message news:wKkXf.4461$Iw2.3339@fed1read05... "T o d d P a t t i s t" wrote in message ... "01-- Zero One" wrote: No, I'm not saying it can't be done legally. I was commenting on the conversion process from a standard type cert to experimental. As far as I can tell, that's extremely difficult to near impossible. (I'd be interested in hearing from anyone who's done it.) However, there are other routes to modifications of a standard certified aircraft. If the proposed change is a major modification under Part 43, you'll need a 337 approval or a Supplemental Type Certificate from the FAA. If not, then it's easy. -- T o d d P a t t i s t - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) I once owned an SGS 1-23 that had had the wing extended. The tip extensions were removable. Due to this mod the aircraft was converted from "Standard" to "Experimental, Exhibition and Racing". The most interesting thing about this airworthiness certificate was that it specifically stated that the aircraft reverted to "Standard" when the tips were removed. To my knowledge this "dual certification" was a unique case. This was done quite a while ago, and by someone (Paul Bickle) with impeccable credentials and very good FAA contacts. Modern era "Experiment" operating limitations are supposed to have an item stating that: "The cognizant FAA FSDO must be notified, and their response received in writing, prior to flying this aircraft after incorporation of a major change as defined by Part 21.93". This requirement is the substitute for the 337. (I personally would seek their advice and okay before performing the mod to avoid unpleasant, and expensive, surprises.) |
I still don't have my paperwork but I do recall that the Operating
Limitations for the Experimental - Exhibition/Racing certificate included No Night Flying, No Towing of Gliders and No Passengers for Hire. That nearly prevented me from buying the glider but the price was too good to pass up. No geographical limits, though. I guess things were a bit different way back in the '70s. Mike |
| Thread Tools | |
| Display Modes | |
| Pegasus life limit | Mark628CA | Soaring | 2 | March 30th 06 11:37 PM |
| Pegasus life limit | 01-- Zero One | Soaring | 0 | March 30th 06 11:25 PM |
| Cirrus Airframe Life Limits | Dave | Piloting | 16 | April 27th 04 06:58 PM |
| Jantar life limit - Janusz? | tim | Soaring | 2 | November 4th 03 10:10 PM |
