With the wind?
Old April 2nd 06, 10:40 PM posted to rec.aviation,rec.aviation.piloting
Default With the wind?
I will not take a 10knt tailwind to land a conventional geared aircraft..
I will take an occasional 10knt tailwind on a 6000ft runway for most of the
other light tri-cycle geared GA aircraft I fly.
Can I send the bill to the local home owners association for extra wear on
brake pads?
BT
"smallg" wrote in message
Thanks Jim, this makes perfect sense, as noise has
been an issue there for years. I just had the idea
that tailwind landings and takeoffs were never allowed,
as the FAA traditionally seemed pretty strict.
BTW, airport is Peachtree-Dekalb (Atlanta metro
area); here's a page on noise abatement there that
I found just now: http://www.pdkairport.org/abatement.htm
Jay McKenzie
http://home.bellsouth.net/p/pwp-wstviews
Old April 3rd 06, 12:06 AM posted to rec.aviation,rec.aviation.piloting
You're welcome.
| Jay McKenzie
Old April 3rd 06, 03:44 AM posted to rec.aviation,rec.aviation.piloting
"Jim Macklin" wrote in message
news:ZPVXf.7715$t22.1714@dukeread08...
If a tower phrased a take-off clearance "cleared for |
downwind takeoff" it would be because the pilot requested
that runway and the tower was getting it on tape, that the
pilot knew and accepted the procedure.
The phraseology is just "cleared for takeoff", the pilot's request would
already be on the tape so adding "downwind" would accomplish nothing..
Old April 3rd 06, 05:44 AM posted to rec.aviation.piloting
Jay McKenzie
It's got a 6000 ft runway. You could land a Boeing 737. A 10 knot tail
wind is not going to make much difference to most small airplanes.
Old April 3rd 06, 03:11 PM posted to rec.aviation,rec.aviation.piloting
Newps wrote:
We're not you're mother. If traffic allows and you want a 20 knot
tailwind the runway is all yours.
And so are the blast pad, the approach lighting system, and the trees at
the opposite end.
Peter
Old April 3rd 06, 03:26 PM posted to rec.aviation,rec.aviation.piloting
It works the other way too. I've seen HPN using 34 with a slight
tailwind and somebody says they need to use 16 for operational
requirements (or maybe it was the other way around). They get what
they ask for.
Old April 3rd 06, 03:50 PM posted to rec.aviation,rec.aviation.piloting
they ask for.
But not always. If it's busy you may have to land with a 5 knot tailwind.
Old April 3rd 06, 04:02 PM posted to rec.aviation,rec.aviation.piloting
The pilot always makes the final call. If it's busy, you may have to wait
to land without a tail wind. If you are low on fuel that may force you to
divert to another airport. But an air traffic controller can not dictate
which runway you are to use.
Mike Schumann
"Newps" wrote in message
they ask for.
Old April 3rd 06, 04:12 PM posted to rec.aviation,rec.aviation.piloting
they ask for.
ATC can't force you to do something contrary to your opspecs.
Old April 3rd 06, 04:34 PM posted to rec.aviation,rec.aviation.piloting
Baloney. If you get a chance go to any big airport on a day with light
winds. Most of these airports have preferred runways, landing in a
particular direction is preferred by the controllers for any number of
reasons. If the wind shifts to make that runway a tailwind, but it's
only 5 knots or so, you will land with a tailwind or you will go
somewhere else. Same as my previous example about the crosswind.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 02:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Outfly the wind Doug Piloting 7 July 6th 05 03:18 PM
LX4000 wind calculation AttentionLEcureuil Soaring 2 June 23rd 04 04:33 AM
