OLC
Old April 2nd 06, 07:47 PM posted to rec.aviation.soaring
Default OLC
Anyone else having problems viewing igc files on OLC? I had no
problems until the requirement to enter the letters and digits
(security codes?) but now it rejects me...in German.
I have tried both upper and lower case ..nada. What's the problem? I
emailed the OLC manager address......no reply.
LL
Old April 2nd 06, 08:27 PM posted to rec.aviation.soaring
Default OLC
LL
Worked for me just a minute ago . . .
Old April 2nd 06, 10:42 PM posted to rec.aviation.soaring
Default OLC
Clearly, people stealing OLC files is almost as big a problem as people
faking them.
Where exactly is this black market in stolen IGC files?
Old April 3rd 06, 02:38 AM posted to rec.aviation.soaring
Default OLC
Well you could make your own .wt1 files from the IGC data !
Old April 3rd 06, 02:49 AM posted to rec.aviation.soaring
Default OLC
Also the system has suddenly taken a dislike to my Volksogger record,
downloaded via SeeYou. Quote:
"File integrity is not OK !
The signature is invalid.
Either the G-records of the IGC-file have been changed
or the FR's electronic security seal has been broken.D:443.TMPecho
'' out.txt"
Enough of this crap!!!! If those in charge can't write software that
recognizes valid files something is really screwed up.
Fix it or we'll just go our own way.
Mike
Old April 3rd 06, 03:09 AM posted to rec.aviation.soaring
Default OLC
'' out.txt"
Mike
It is possible that it failed the security test due to a glitch in the
VL file. I had a similar situation with a Cambridge 302 file a couple
of months ago.
Are you running SeeYou or Strepla on a PDA? If so, you might try to
upload that file to OLC.
Old April 3rd 06, 05:46 PM posted to rec.aviation.soaring
Default OLC
My particular problem is that I can't view anyones igc flight on See
You. When I click on their igc file number, I get the random security
codes to enter, enter them, and am rejected.
OLC manager emailed..twice...no answer.
Probably my computer, but very frustrating.
LL
Old April 3rd 06, 06:29 PM posted to rec.aviation.soaring
Default OLC
"Bernie" wrote in message
LL
Must be your computer. I just downloaded Billy Hills' flight from Sunday
and it opened nicely in CU..
Old April 3rd 06, 07:42 PM posted to rec.aviation.soaring
Default Turf status?
Anyone from the sunny state have some insight?...a
cursory check of soaring cyberspace indicates possible
bad news.
Old April 4th 06, 06:03 PM posted to rec.aviation.soaring
bad news.
I've heard some things via the "grapevine", but their website doesn't
indicate anything. What did your cursory check of cyberspace show that
was "possible bad news"?
