Drains in Wing Tanks
Old April 3rd 06, 07:37 AM posted to rec.aviation.homebuilt
Default Drains in Wing Tanks
Wag-Aero has a special this month on quick drains:
http://www.wicksaircraft.com/catalog...879/index.html
I'm building a mongrel dog of a low wing airplane that uses wing tanks,
pretty much like the Hummel Ultracruiser Plus. The tanks themselves
are .032 aluminum. The question of the day is how to mount the drains
to the tanks.
2 styles and several sizes of drains are offered. The use either
tapered pipe thread or straight threads.
Obviously, a doubler will be needed to provide enough meat to fasten
the drains to. The question is to whether to make a fairly thick
doubler, and tap it for the tapererd pipe thread, or to use a somewhat
thinner doubler, tap it for straight threads, and put a shear nut on
the inside of the tank, before pro-sealing it up.
How thick should a piece of 6061-t6 be in order to securely hold 1/8"
NPT threads? I think I'm leaning toward that solution, with the
doubler OUTSIDE the tank skin to keep the un-usable fuel down a bit.
Looking at my "Machinery's Handbook", I'd need 0.2639" for full thread
engagement. Can I live with less than that? What do RV's use in this
area?
OR, am I barking up the wrong tree entirely, and I should grab a
welding flange, drill some holes in it, and slap it on with rivets and
pro-seal, and let it hang down.
http://www.aircraftspruce.com/catalo...alumflange.php
Old April 3rd 06, 02:47 PM posted to rec.aviation.homebuilt
On 2 Apr 2006 23:37:06 -0700, "flybynightkarmarepair"
to the tanks.
area?
My murphy rebel uses a welding flange pro-sealed and rivetted on. Pipe
threads are the way to go cuz sooner or later you're going to have to
replace that valve and it would suck if you had to open the tank to do
it.
Old April 3rd 06, 06:44 PM posted to rec.aviation.homebuilt
to the tanks.
area?
a/c building is like plumbing work; sometimes it pays to just pay
instead of doing it yourself.
Van's a/c has pipe threaded flanges, predrilled with rivet holes just
for this purpose. s&h will probably cost more than the parts.
Old April 3rd 06, 09:59 PM posted to rec.aviation.homebuilt
Seeing how I'm near this stage: How would you handle this in a
fiberglass tank?
Old April 6th 06, 10:35 PM posted to rec.aviation.homebuilt
You could:
+ ignore the problem. Most fiberglass homebuilt tanks I've seen don't
have quick drains; they're relying on the gascolator to stop the water.
+ use the aluminum welding flanges, and either embed them in the layup,
or flox them in place, after drilling holes in the flange for the flox
"rivets" to squeze through.
+ use polysulfide (Pro-Seal is one (un)popular brand) to glue a welding
flange onto a completed tank, again, after drilling holes in the
flange.
I'm going to take the previous posters advice and rivet some flanges on
my tanks, with closed end pop rivets, dipped in MEK to degrease them
first, and everything slathered in Pro-Seal.
Old April 6th 06, 11:43 PM posted to rec.aviation.homebuilt
Forgive my ignorance, but is this proseal safe to use with alcohol in the
gas? If not, nowadays, that seems to be taking a very big risk.
Jim in NC
Old April 7th 06, 06:45 PM posted to rec.aviation.homebuilt
What sealent would you recommend?
Old April 7th 06, 08:12 PM posted to rec.aviation.homebuilt
google "Fuel tank sealant" +Alcohol
About 100 hits
this was the first one...
http://www.motoroilcompanies.com/fue...ueltanksealer/
Old April 8th 06, 02:15 PM posted to rec.aviation.homebuilt
"Lou" wrote in message
Good welding?
Jim in NC
Old April 8th 06, 05:32 PM posted to rec.aviation.homebuilt
Polysulfides like Pro-Seal are resistant to fuel and alcohol.
Poly Vinyl Alcohol used to be the favored pour-in fuel tank sealer; no
more since alcohol has creapt into gas many places.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
Grob G102 Setup BDS Soaring 11 August 30th 05 03:42 PM
F-104 in Viet Nam Question Don Harstad Military Aviation 2 August 28th 04 08:40 AM
