phil collin wrote: Ok, Glen, would you agree with Jack on the aero tow speed? seems a bit on the high side that's all. We fly IS30's, IS28's, Blaniks, Darts, Pirats, Skylarks, libelles etc and we generally tow them all at 60 Knots without any issue, does the PiK fly better with a quicker tow? also, the reading I've done suggests best L/D at 63 Knots, does that sound right? Thanks to you and Jack I fly a 301 Libelle, towing on the CG hook. It's the CG hook that is the issue with slow tows. Gliders generally have small elevators, some smaller or less effective than others. Towing on the CG hook loads up the tailplane more than towing with a nose hook, so, at low tow speeds, one can run out of elevator authority. This is especially dangerous in gusty conditions where there may be momentary hard yanks on the tow line adding to the tendency to pitch up. God help you if you have an aft CG in that situation. I have had a tow or two where the speed got down below 50 knots. That was very uncomfortable and I was reaching for the tow release in each case while yelling at the tuggy for more speed. |
Phil, I've been away for the day and I see much good info has been added. I
forgot to mention the CG hook considerations. I have never felt the need to specify a tow speed. The tow pilots in my club deal with a lot of glass ships and whatever they are using for an average has been fine for me. I would say this is typically 60kt or so. I have experienced no problems with the CG hook, but respect the slow tow and gust advice that others have given - make sure the trim is full forward for takeoff. I usually tow with +8 flap for over the nose visibility (this is at/after liftoff - the full neg on takeoff roll definitely applies). I will amplify the advice about not trying to limit your flap setting for your first pattern. Use whatever it takes! I will also amplify the bit about not having extra speed in the flare - you can/will go a long ways in ground effect if you flare with extra speed. I try to hold 55kt in the pattern, which will let me roll flaps in and out at will. No matter what the previous part of the approach has been like, I find that I usually have 90deg rolled on for touchdown. This provides a consistency in control sensitivity. Almost immediately after touchdown I roll the flaps back up to full neg to maintaian roll control. As far as max l/d speed, it depends on your weight and model, but I use 54 kts at 35.1 kg/sq m. This is a PIK-20A - no flap interconnect or carbon. Glen "phil collin" wrote in message ... Ok, Glen, would you agree with Jack on the aero tow speed? seems a bit on the high side that's all. We fly IS30's, IS28's, Blaniks, Darts, Pirats, Skylarks, libelles etc and we generally tow them all at 60 Knots without any issue, does the PiK fly better with a quicker tow? also, the reading I've done suggests best L/D at 63 Knots, does that sound right? Thanks to you and Jack Phil |
Hi
Go to Jim Tsillas homepage http://www.appledor.net/tsillas/soaring/ . Here you find good descriptions on take off and landing, and much useful information on the Pik. Matts phil collin skrev: I'm about to become the owner of a PiK20b. I have never flown one before and wondered if there were any owners/pilots of this particular model who could offer some words of wisdom on what to expect. I've read with interest the "pat your head rub your tummy" stories of flaring and winding the flaps up to negative to weight the tail at the same time so you can use the nose wheel. I'm guessing 30 to 45 degrees of flap on the approach is going to be like spoilers. Looking forward to some responses. I take delivery this Saturday and the met looks great at the moment. Phil |
Phil,
One more thing that should be mentioned... I was given a blessing the first time I assembled the PIK alone. One of the pip pins that connect the flaps and ailerons was not through the ball, but looked OK from the outside. Upon towing the glider to the flight line, one of my flaps drooped a bit, showing me just how easily it is to make a mistake in rigging the wing-flight controls. Please check and double check... and enjoy your new ship. Jack |
Thank you for the link. Good information!
I have never flown a PIK-20B. My flap-only sailplane experience is in a Schreder HP-16T and a HP-14. A few years ago Bob Kuykendall wrote an article to assist new Schreder pilots. Much of the information should also apply to the PIK-20B. http://www.soaridaho.com/Schreder/St..._HP_flight.htm Wayne HP-14 N990 "6F" http://www.soaridaho.com/Schreder wrote in message ups.com... Hi Go to Jim Tsillas homepage http://www.appledor.net/tsillas/soaring/ . Here you find good descriptions on take off and landing, and much useful information on the Pik. Matts phil collin skrev: |
PDA mount in PIK20B | Derrick Steed | Soaring | 1 | May 22nd 04 02:31 AM |
