Sky Park VOR or GPS-1 question
Old June 4th 04, 02:26 AM
Bob Gardner
Well, I managed to screw that up...looking at a holding pattern book to find
PT airspace. Sheesh!!
Bob
wrote in message ...
Bob Gardner wrote:
There is a definite difference in the airspace protected for a holding
pattern vis-a-vis a procedure turn. Dunno why the missed approach hold
couldn't be on the same side as the PT, though, since the PT eats up
much
more airspace.
Not in this case. This is one of those little tiny 5-mile PT areas, which
they
can design into a CAT A only IAP
Old June 4th 04, 05:44 AM
Bob Gardner wrote:
Interesting. I have an old copy of FAAO 7130.3 and couldn't find a word
about five mile holding patterns, so I was kind of transmitting in the blind
(:-). What template is used?
Not a 5-mile hold; rather a 5-mile procedure turn. TERPs 234b:
"b. Area. The PT areas are depicted in Figure 5. The normal PT distance is 10
miles. See table 1A. **Decrease this distance to 5 miles where only CAT A
aircraft or helicopters are to be operating**, and increase to 15 miles to
accommodate operational requirement, or as specified in paragraph 234d. No
extension of the PT is permitted without a FAF. When a PT is authorized for use
by approach CAT E aircraft, use a 15-mile PT distance."
Old June 4th 04, 04:54 PM
Tim Auckland
Thanks.
Tim.
On Thu, 03 Jun 2004 20:05:29 -0400, Ron Rosenfeld
On Thu, 03 Jun 2004 16:29:05 -0600, Tim Auckland wrote:
Another question about this approach (and I've seen similar apparent
ommisions on other approaches):
Why isn't the initial approach segment from PAWLING marked "NoPT"?
To me, it makes no more sense to do a PT when coming in over PAWLING
than it does when coming in over KINGSTON, yet the KINGSTON IAS is
marked "NoPT", and the PAWLING one isn't.
Is this just a charting error, or is there a subtlety that I'm
missing?
On my Jepp chart dtd 5/21/2004, the segment from PWL IS marked NoPT. So
probably the NACO chart is incorrect.
Old June 4th 04, 09:19 PM
zatatime
On Thu, 03 Jun 2004 22:45:40 GMT, zatatime
I understand what you are saying, but...
If you are established on the 010 Radial inside of NETER and outside
of SAGGI isn't that sufficient to begin a descent to 1800. I realize
a descent anywhere in the hold is not prudent, but I'm having a hard
time rationalizing flying a whole procedure turn if between NETER and
SAGGI a descent to 1800 is allowed.
Maybe there's a subtlety in your reply I did not pick up on, "you can
do a procedure turn however you want." Would this include briefly
flying through the 010 Radial on the inbound turn of the hold and then
re-establish? This would put you on the right (and correct) side of
the radial.
This is a good one.
Thanks for sharing.
z
Nevermind, I printed the plate and studied it. I now understand what
should be done, and it is not what I previously stated.
z
Old June 4th 04, 10:52 PM
John Harper
So here's my swag on this. It looks as though the minimum
altitude on the east side of the final approach course is
2600, and they don't want you descending to 1800
on the east side. 2600 is the altitude inbound from
PWL and the holding altitude, but you are supposed
to cross SAGGI at 1800 on the final. Hence to get
to 1800 you have to fly the PT. Of course in real
life you could safely divebomb from 2600 to 1800
on the final approach course.
Flying as charted from PWL would be entertaining...
intercept the FAC, fly the hold then the PT before
finally crossing SAGGI at 1800.
John
"Roy Smith" wrote in message
The VOR or GPS-1 into Sky Park, NY (46N)
http://www.myairplane.com/databases/...s/05462VG1.PDF has a
note saying "Final approach from Saggi Int holding pattern not
authorized. Procedure turn required". What doesn't make sense about
this is that SAGGI is an IAF, and you're allowed to use a holding
pattern as a PT. So, what's the note all about?
It's also not clear why the PT and missed hold are charted on opposite
sides of the approach course. Let's say you flew the approach, missed,
and entered the hold at SAGGI. The weather got a bit better and you
were cleared for another approach. The maneuvering you've had to do is
absurd. The logical thing would be to just continue in the hold until
you were inbound to SAGGI and continue from there. But, no, you've got
to turn around again, intercept the approach course outbound, do a PT,
re-intercept inbound, and then proceed. What's the point?
This seems like the kind of approach I need to bring a student to, just
to see how they handle it.
Old June 5th 04, 10:26 PM
Iain Wilson
I agree - it's the 2600ft holding pattern alt that's the problem.
Maybe the descent from 2600 ft is outside the specs for an approach?
Iain
"John Harper" wrote in message
news:1086385767.347955@sj-nntpcache-5...
John
Old June 5th 04, 10:49 PM
Roy Smith
In article t,
I had thought of that, but the PT outbound altitude is 2600 as well.
And since you are allowed to fly a racetrack for the PT, if it's OK for
the PT, it must be OK for the hold.
Old June 6th 04, 02:58 PM
Iain Wilson
I was thinking about the descent from the FAF where they've specified 1800.
You'd be at 2600 in the hold and this might be outside the specs.
Iain
In article t,
ALEXIS PARK INN - comments please. plumbus bobbus Home Built 0 January 22nd 04 12:02 AM
ALEXIS PARK INN - comments please. plumbus bobbus Instrument Flight Rules 0 January 22nd 04 12:02 AM
