![]() John Bell wrote: The ODP out of MMK for runway 36 reads, "climbing left turn to 1800 via 325° bearing from MMK NDB before proceeding on course". It seems to me that the easiest way to fly that with a GPS would be to create a user waypoint which is a 325 bearing, 20 (or whatever) mile offset from MMK NDB and insert that into your flight plan before the first real waypoint in your clearance. Take off, track to the user waypoint until reaching 1800, then do "direct" to the next waypoint. Can anybody think of a good reason not to do it that way? There are a couple ways of navigating this with the GPS, The best method depends on what kind of GPS you are using. Here is my $.02 worth of opinion: If you have an IFR certified panel mounted GPS, I would execute a direct MMK and use the OBS mode. If I read the AIM correctly, it appears that you would have to have the CDI mode set to terminal sensitivity (normally 1 to 1.25 nm) to use the GPS for navigation without having an ADF (AIM 1-1-19f, http://www.faa.gov/ATpubs/AIM/Chap1/aim0101.html#1-1-19). All the IFR units are 1.0 mile in terminal. 1.25 is in some VFR-only units. The procedure requires you set the unit to terminal mode in an RNAV DP. Those VA legs (leg to altitude) expect you to use the OBS mode or some similar open track mode. |
Direct To a waypoint in flightplan on Garmin 430 | Andrew Gideon | Instrument Flight Rules | 21 | February 18th 04 01:31 AM |
Victor Airways in Clearance | Wyatt Emmerich | Instrument Flight Rules | 50 | February 15th 04 06:42 PM |
Anywhere WX users - free tool for easier e-mail, waypoint entry, etc... | Mark Astley | Instrument Flight Rules | 0 | February 7th 04 02:17 PM |
Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 05:29 PM |
