I see this alot in SoCal. Areas with tons of 24 hr Radar coverage.
You go missed, turn to the VOR and Call., |
I've seen this before in SoCal -- esp with lots of Radar coverage - 24
hrs a day. You go missed - turn to the VOR and call. |
True - but EMT is towered
Sorry - did not mean to relay that - I meant that there's radar
coverage - maybe limited coverage in the tower - but still radar, so when you go missed, even if you are restricted in climb as you are at EMT in the missed, you're talking to the tower 1st, who can vector you if needed. So, no pre-designated hold is needed on the chart. That's how I interpret it.! |
![]() Just because an airport has a tower doesn't mean it had radar coverage. An an example, SAF (Santa Fe, NM) is a Class D towered airport with a number of instrument approaches and....no radar. -- Dane In article .com, wrote: Sorry - did not mean to relay that - I meant that there's radar coverage - maybe limited coverage in the tower - but still radar, so when you go missed, even if you are restricted in climb as you are at EMT in the missed, you're talking to the tower 1st, who can vector you if needed. So, no pre-designated hold is needed on the chart. That's how I interpret it.! |
![]() Even if radar coverage were good, I don't believe a VFR tower can provide any type of radar vector to an IFR aircraft. It depends on what the approach control and the tower have worked out between themselves. They certainly may do a limited amount of vectoring, usually with the departures. Sorry ... what's a VFR Tower? Any tower that isn't at the main airport for class B or C. |
Missing in Action Serviceman Identified | Otis Willie | Naval Aviation | 0 | March 18th 05 11:58 PM |
missing man formation for Reagan | Paul Hirose | Military Aviation | 1 | June 14th 04 12:50 AM |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
Search for missing plane | C J Campbell | Piloting | 2 | March 4th 04 01:42 AM |
Ellery Queen and the Case of the Missing Magneto Gear Teeth | MikeremlaP | Owning | 3 | July 26th 03 03:01 AM |
