#11
We have plenty of VFR aircraft talking to Salt Lake Center passing thru
my airspace. Sometimes we take a point out and let ZLC work them, sometimes we will work them. The pilot is under no obligation to contact me directly if he is talking to ZLC. Robert M. Gary wrote: In some sense the letter seems to be a bit BS. How is the pilot to know what LOA are in place between the facilities? In some very busy areas (So Cal) its very common for approach to not hand you off to another tower (not theirs) until they put you almost on downwind. It will be interesting to hear from the controllers on the list. In non-busy airspace it would be easy to immagine being able to get enough radio time to query. -Robert |
![]() "skym" wrote in message oups.com... Interesting query. At first I wondered how this situation ever arises, then I remembered my VFR flight into Troutdale (TTD) which is in a class D airspace that partially underlies and actually seems to invade the overlying Class C of Portland (PDX). No invasion. There is a hierarchy of airspace, lower classes of airspace give way to higher classes. PART 71-DESIGNATION OF CLASS A, B, C, D, AND E AIRSPACE AREAS; AIR TRAFFIC SERVICE ROUTES; AND REPORTING POINTS § 71.9 Overlapping airspace designations. (a) When overlapping airspace designations apply to the same airspace, the operating rules associated with the more restrictive airspace designation apply. (b) For the purpose of this section- (1) Class A airspace is more restrictive than Class B, Class C, Class D, Class E, or Class G airspace; (2) Class B airspace is more restrictive than Class C, Class D, Class E, or Class G airspace; (3) Class C airspace is more restrictive than Class D, Class E, or Class G airspace; (4) Class D airspace is more restrictive than Class E or Class G airspace; and (5) Class E is more restrictive than Class G airspace. I was on flight following from the southwest and couldn't find the TTD airport, so PDX approach was kindly giving me help... "it's about 2 miles at 12 o'clock." (Don't laugh; they're not always easy to find.) When he told me to contact TTD tower, I got a rather exasperated reply on my callin that I should have called them earlier. I meekly replied that I was with PDX approach until then, and he said "Oh well, that was ok." So, I guess I technically busted the Class D by not contacting them while I was still talking to approach (within Class C) but was already within 5 miles of the Class D airport. Frankly, since I was on radar with approach control I felt it was safer for everyone to stay with them until told to contact the local tower at TTD. You can't bust Class D airspace while you're in Class C airspace. If you were two miles southwest of TTD between 1700 and 4000 MSL you were in Class C airspace. If you were below 1700 you were in Class D airspace. |
![]() "Robert M. Gary" wrote in message oups.com... The confusion may come from that fact that if you are receiving flight following (or IFR) from center or some other facility and you fly through the class C you are ok, it is there responsibility to coordinate with the class C controllers for you or to hand you off. True in some cases, such as when part-time facilities are opening for the day. But that's pretty much it. If you're about to enter Class C airspace you shouldn't be talking to any facility other than the one responsible for the Class C airspace. |
![]() "Robert M. Gary" wrote in message oups.com... No, the approach controller was responsible for either coordinating your transition through the class D or handing you off. In truth, I believe there are areas of the class D that approach has agreements to send arrivals. Radar facilities are required to coordinate the transition of thruflights, but not of VFR arrivals. |
![]() "Gary Drescher" wrote in message . .. But its being their responsibility doesn't mean that it isn't still the pilot's responsibility too (in the case of VFR flight following). In fact, the AIM (3-2-1d) says "It is the responsibility of the pilot to insure that ATC clearance or radio communication requirements are met prior to entry into Class B, Class C, or Class D airspace. *The pilot retains this responsibility when receiving ATC radar advisories*." (emphasis added). So even when I'm receiving flight following, I assume I need to talk to the tower or approach controller of the facility whose airspace I'm about to transit, except if the chart notes otherwise (for example, in the case of several satellites whose Class D airspace is underneath Boston's Class B, the chart says to contact Boston Approach to transit the Class D above a certain altitude). In practice, though, I can't recall any time that the controller giving me radar advisories wasn't already the one I needed to be in contact with. A radar controller is required to coordinate the transition of Class D airspace with the control tower when providing radar traffic advisories. You are not expected to contact the tower yourself. FAA Order 7110.65R Air traffic Control Chapter 2. General Control Section 1. General 2-1-16. SURFACE AREAS a. Coordinate with the appropriate nonapproach control tower on an individual aircraft basis before issuing a clearance which would require flight within a surface area for which the tower has responsibility unless otherwise specified in a letter of agreement. REFERENCE- FAAO 7210.3, Letters of Agreement, Para 4-3-1. 14 CFR Section 91.127, Operating on or in the Vicinity of an Airport in Class E Airspace. P/CG Term- Surface Area. b. Coordinate with the appropriate control tower for transit authorization when you are providing radar traffic advisory service to an aircraft that will enter another facility's airspace. NOTE- The pilot is not expected to obtain his/her own authorization through each area when in contact with a radar facility. c. Transfer communications to the appropriate facility, if required, prior to operation within a surface area for which the tower has responsibility. REFERENCE- FAAO 7110.65, Radio Communications Transfer, Para 2-1-17. FAAO 7110.65, Surface Area Restrictions, Para 3-1-11. FAAO 7110.65, Application, Para 7-6-1. 14 CFR Section 91.129, Operations in Class D Airspace. |
![]() "Peter R." wrote in message ... I have read of pilots experiencing this at Caldwell, New Jersey, a class D airport here in the busy northeast US. IMO, a crazy and potentially dangerous way (added frequency congestion, distracted controller, 180 degree turn in busy airspace) to demonstrate a point. Crazy and potentially dangerous because of the 180 degree turn or because you arrived unexpected and unannounced in busy airspace? What else would you expect the tower controller to do at that point? |
![]() "Robert M. Gary" wrote in message oups.com... In some sense the letter seems to be a bit BS. How is the pilot to know what LOA are in place between the facilities? Why would the pilot need to know? In some very busy areas (So Cal) its very common for approach to not hand you off to another tower (not theirs) until they put you almost on downwind. It will be interesting to hear from the controllers on the list. In non-busy airspace it would be easy to immagine being able to get enough radio time to query. First of all a "handoff" is strictly a radar function. It is the action taken to transfer the radar identification of an aircraft from one controller to another if the aircraft will enter the receiving controller's airspace and radio communications with the aircraft will be transferred. It is NOT the transfer of radio communications. If you're arriving VFR and you're almost on downwind within Class D airspace and still on Center/approach frequency it's because the radar controller forgot about you or was too busy with other duties to tell you to contact the tower. Don't get into that position. Before entering Class D airspace tell the radar controller bye-bye and contact the tower. If frequency congestion does not permit the bye-bye then just contact the tower. |
In article . net,
"Steven P. McNicoll" wrote: "Robert M. Gary" wrote in message oups.com... The confusion may come from that fact that if you are receiving flight following (or IFR) from center or some other facility and you fly through the class C you are ok, it is there responsibility to coordinate with the class C controllers for you or to hand you off. True in some cases, such as when part-time facilities are opening for the day. But that's pretty much it. If you're about to enter Class C airspace you shouldn't be talking to any facility other than the one responsible for the Class C airspace. What happens if you're within the lateral and vertical boundaries of a part-time Class C when the tower opens in the morning? |
you arrived unexpected and unannounced in busy airspace? What else would you expect the tower controller to do at that point? Personally, (as you know) I expected the RFD approach controller to be on the same sheet of music as the JVL tower controller. They are 25.6 miles apart, and work together hand-in-glove MOST of the time. Just not that day... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message oups.com... Personally, (as you know) I expected the RFD approach controller to be on the same sheet of music as the JVL tower controller. They are 25.6 miles apart, and work together hand-in-glove MOST of the time. Just not that day... What same sheet of music did you expect them to be on? You were operating VFR in Class E and D airspace. There was no requirement for you to be in contact with RFD approach at any time, there is a requirement for you to contact JVL tower prior to entering Class D airspace, yet you blame RFD approach for dumping Mary into the Class D airspace. Is RFD approach directly responsible for the operation of the airplane when Mary is flying? |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 02:29 AM |
